Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 12-11-2013, 02:15 PM   #2401
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,157
Or just have a really long brake line made that still loops over the tire, but all the way up one fork leg, across lower triple tree, and down the other fork leg. No need to over engineer.
"I refuse to tiptoe through life only to arrive safely at death"
'13 Tiger 800XC, '14 Street Triple, '00 KLR 650(current project), and a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 12-11-2013, 04:57 PM   #2402
T
stay classy
T's Avatar
Oddometer: 5,266
Yeah- Something like D_U's idea.
Right side stock- double banjo
[IMG][/IMG]
Left side union block
[IMG][/IMG]
Inconsequential Adventurer
T is offline   Reply With Quote
Old 12-11-2013, 09:20 PM   #2403
Rodeogeo
Oddometer: 1
Something I've learned and something to share.
I always wondered how the tip of my beak cracked off. The TT front fender extenders extend too much?
Also, the front fender has brackets with tabs that hold or contain the front brake lines. There is a tab on the back of the bracket that I cut off. After 6,000 miles, the brake lines still stay in the bracket. But if the front fender flies off I probably won't even notice it since the brake lines aren't attached the to the front fender.
I cut the tabs as I was attaching the TT extenders and wondering why I even bought them.
Rodeogeo is offline   Reply With Quote
Old 12-11-2013, 09:29 PM   #2404
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,311
I'm thinking the best deal for the front for mud and real offroad would be to mount the back of a sumo fender up high in conjunction with the beak...do away with the lower fender. Double brake lines to keep them out of the way of the wheel.
Welcome to ADVrider.com.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 12-12-2013, 07:50 AM   #2405
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,565
I just move the brakeline out of the groove in the front fender when riding mud or rocks. No need to cut anything. Pop it back in for regular use.
Heart of Dixie
Rob Dirt is online now   Reply With Quote
Old 12-20-2013, 10:20 PM   #2406
ElJefeATX
Morally correct
ElJefeATX's Avatar
Oddometer: 4,077
Dumb question:
Can you remove the tank with fuel in it?
ElJefeATX is offline   Reply With Quote
Old 12-20-2013, 10:22 PM   #2407
klinquist
übergeek
klinquist's Avatar
Oddometer: 1,095
Originally Posted by ElJefeATX View Post
Dumb question:
Yes. Connector on the bottom self-seals when it is disconnected
My 2013 Tiger 800 "Off-Roadie" (plate GETLOZT) - My 2003 DRZ (plate LV DRT RD) - My 2003 E350 Adventure Van (plate ADV VAN) - Amateur Radio W1ADV
klinquist is offline   Reply With Quote
Old 12-20-2013, 10:58 PM   #2408
ElJefeATX
Morally correct
ElJefeATX's Avatar
Oddometer: 4,077
I figured, but, y'know...
Thanks. Should be an interesting day tomorrow. Heated grips as well as other stuff going on.
Old 12-21-2013, 03:13 PM   #2409
y0y02369
y0y02369's Avatar
Oddometer: 1,186
There is a forum on a guy who did the fog light... Step by step. It's pretty much the same as heated grips but was real useful for tips and stuff.
Drive?! Why?! Cars have too many wheels... just makes me feel... awkwardly stable... I'll ride thank you!v
Not knowing where you are going in part of the adventure! :loll
Daisy the Tiger and Frenchie
y0y02369 is offline   Reply With Quote
Old 12-23-2013, 03:47 AM   #2410
KildareMan
KildareMan's Avatar
Oddometer: 649
Dumb question:
Yes but don't try a full tank unless you really like weight training and have plenty of space, as you stagger around trying not to drop the tank.
TIP: When disconnecting the fuel connector push it in slightly to release physical pressure on the two tabs that you have to press to release the connector.
KildareMan is offline   Reply With Quote
Old 01-31-2014, 09:06 AM   #2411
satrider
Oddometer: 69
Originally Posted by stevedo View Post
Looking to buy a UNI Filter pre-filter in the UK. Does anyone know if/where they can be purchased. if not in the UK, where would be best/easiest to source one?
Steve
Does anyone know the UNI filter pre-filter part number to fit the Tiger 800xc?
satrider is offline   Reply With Quote
Old 01-31-2014, 09:26 AM   #2412
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
NU 3704
There was an earlier NU 3703, but I believe that the 3704 will fit all of the Tiger 800s.
Old 01-31-2014, 09:42 AM   #2413
satrider
Oddometer: 69
Thank you, Yossarian. I wonder where one can purchase from in the U.S. Did a Google search, and nothing real turned up. Can someone please post a description and dimensions of the filter? It would be nice to find a replacement for it :-)
satrider screwed with this post 01-31-2014 at 09:51 AM
Old 01-31-2014, 11:30 AM   #2414
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 379
Here you go:
http://www.uniflow.com.au/contents/en-us/d341.html
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 01-31-2014, 11:39 AM   #2415
Baja Dad
Baja Dad's Avatar
Oddometer: 1,959
Okay guys needle help here
I've looked back to the thread a little bit but still cannot find what I'm looking for
Can someone please post what parts are needed and where to get them
to install dual brake lines on a tiger 800xc with ABS
I would really appreciate it it will help with my conversion for the two bikes I am building
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Times are GMT -7.   It's 07:27 AM.
