Old 04-04-2012, 01:08 PM   #916
RichardU
Let's Ride
Oddometer: 875
Originally Posted by blacktiger View Post
To answer that take a look at how far back your chain adjusters are. Mine are quite a way back already so I'd probably have to remove a link. YMMV.
I would use the stock chain length until I knew I couldn't tighten the chain enough. Even if the adjusters are far back, removing a link might make it too short.
RichardU is offline   Reply With Quote
Old 04-04-2012, 01:48 PM   #917
MisterPX
Oddometer: 141
Where are you guys on your alignment marks currently? I'm at 3rd dot from the rear, with a 16T. Put on a 15T, and was at 2 dots from the rear. Put the 16T back on for a trip, and back to 3rd dot. Swapping sprockets takes about 5 minutes, not including chain adjustment.
MisterPX is offline   Reply With Quote
Old 04-05-2012, 05:54 PM   #918
easypeasy
Oddometer: 23
Question
Originally Posted by Rob Dirt View Post
I don't know where to find it yet, but I plan on putting dual brake lines on my front. These pictures show the split at the top & the lines run down one on each tube. That way you can run without a front fender and nothing will happen.
I have a local company ready to make my braided dual brake lines for about $120.00 and I am ready to pull the trigger on this but, I can not find any braket for the lower end of the fork for the brake lines to go through. Anybody know who might make what I need ?
easypeasy is offline   Reply With Quote
Old 04-05-2012, 06:47 PM   #919
fbj913
fbj913's Avatar
Oddometer: 1,841
do you have ABS?
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 04-05-2012, 06:48 PM   #920
easypeasy
Oddometer: 23
Originally Posted by fbj913 View Post
do you have ABS?
no
Old 04-05-2012, 06:58 PM   #921
fbj913
fbj913's Avatar
Oddometer: 1,841
no
just use some zip ties, here is some more pics.
http://www.advrider.com/forums/showthread.php?t=740549
Ride 365 LLC
Braaaap!
Old 04-05-2012, 07:59 PM   #922
easypeasy
Oddometer: 23
Yah but that would be to easy. I would think that there would be some sort of clamp or guide available that would fit the forks and also hold the brake line. Sure would not want the brake line to slip and catch a nobbie, that would kind of defeat the whole purpose...
Old 04-05-2012, 08:17 PM   #923
DirtRoamer
BeerMeister
Oddometer: 13
Is there a problem doing the brake line replacement if I have abs? If not I'd like to order a pair as well and ditch my front fender...
DirtRoamer is offline   Reply With Quote
Old 04-06-2012, 01:28 AM   #924
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,505
Send a message via Yahoo to blacktiger
Take a trip round your Enduro bike dealer. I remember my XR Hondas having a steel loop around the fork legs with a plastic insert to guide the brake line. More modern bikes should have something similar.
2002 Tiger955i in black, 68500 miles.
2012 Tiger800XC in black, 19000 miles.
Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)...
blacktiger is offline   Reply With Quote
Old 04-06-2012, 03:45 AM   #925
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,253
Easypeasy, you want the brake line slack to be at the top. I have not done mine yet, but you should be able to install everything with the front tire off the ground (forks fully extended) & have the correct amount of slack.
DirtRoamer, the ABS version will require running the brake lines to the ABS unit & from the unit to the front wheel. Also, to correctly bleed the ABS unit you will need a dealer tool.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 04-06-2012, 06:10 AM   #926
fbj913
fbj913's Avatar
Oddometer: 1,841
yah what he said
Ride 365 LLC
Braaaap!
Old 04-06-2012, 07:26 AM   #927
shadygrady
Oddometer: 59
I used a KTM brake hose guide and attached it to the fender mounting bracket http://www.ktm-parts.com/60013025100.html
Here's where I got the idea: http://www.advrider.com/forums/showthread.php?t=41610
If you're only changing the lines, there shouldn't be a need to bleed the ABS. (This from 2 Triumph techs). The ABS unit is a closed system until the servo's are activated. Just bleed the brakes the normal way.
shadygrady is offline   Reply With Quote
Old 04-06-2012, 07:55 AM   #928
shadygrady
Oddometer: 59
I personally think the low fender is hideous and takes away from the 'bad ass-ness' of the bike, but you might want to reconsider getting rid of the fender all together. That beak is prob not going to keep much off of you or the bike, especially when you turn the wheel to the side. There are some advrider threads that discuss some high fender options on different bikes that you can get some ideas from so you can get rid of that ugly low fender without sacrificing rain/mud protection.
What I did in an effort to salvage and save money, is cut the fork guards off the fender. I reinforced them so they wouldnt vibrate against the forks and mounted them. I relocated the fender under the lower triple tree with U bolts. Looks much much better. I have parts getting painted right now so I haven't been able to give it a thorough test. We'll see how it works and holds up!
shadygrady screwed with this post 04-06-2012 at 02:23 PM
Old 04-06-2012, 11:31 AM   #929
fbj913
fbj913's Avatar
Oddometer: 1,841
What I did in an effort to salvage and safe money, is cut the fork guards off the fender. I reinforced them so they wouldnt vibrate against the forks and mounted them. I relocated the fender under the lower triple tree with U bolts. Looks much much better. I have parts getting painted right now so I haven't been able to give it a thorough test. We'll see how it works and holds up!
PICS!!!
Ride 365 LLC
Braaaap!
Old 04-06-2012, 01:54 PM   #930
fbj913
fbj913's Avatar
Oddometer: 1,841
52 rear
Ride 365 LLC
Braaaap!
Times are GMT -7.   It's 11:07 PM.
