Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 04-06-2012, 09:11 PM   #931
easypeasy
Oddometer: 28
Originally Posted by Rob Dirt View Post
Easypeasy, you want the brake line slack to be at the top. I have not done mine yet, but you should be able to install everything with the front tire off the ground (forks fully extended) & have the correct amount of slack.
DirtRoamer, the ABS version will require running the brake lines to the ABS unit & from the unit to the front wheel. Also, to correctly bleed the ABS unit you will need a dealer tool.
Ok I have installed my dual front brake lines, and well, It was easypeasy. And at this point I am using zip ties to hold the lines against the fork tubes but I am not sure that I even need em. The lines seem to stay clear of the tire. I will think on some ideas and appreciate all the input, for now I am happy with the way the lines sit. Now for test riding and tinkering.
easypeasy is offline   Reply With Quote
Old 04-06-2012, 09:18 PM   #932
refokus
Just Learning
refokus's Avatar
Oddometer: 2,513
Let's see some photos of your handy work.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 04-06-2012, 11:32 PM   #933
easypeasy
Oddometer: 28
Ok I went ahead and made some brackets for the brake lines. Now the lines move up and down with the wheel. One of the brackets is already on the bike (where the brake line junction comes together on the left front fork) and then I made another one from some shit I had laying around. I will figure out how to post a picture tomorrow. Stay tuned.
easypeasy screwed with this post 04-08-2012 at 10:10 PM
Old 04-07-2012, 06:41 AM   #934
refokus
Just Learning
refokus's Avatar
Oddometer: 2,513
Old 04-08-2012, 10:15 PM   #935
easypeasy
Oddometer: 28
Check out brake line pictures in previous post. See above post
Old 04-09-2012, 06:47 AM   #936
refokus
Just Learning
refokus's Avatar
Oddometer: 2,513
Looks good.
Old 04-09-2012, 07:05 PM   #937
Burren Rider OP
Aussie Adventurer
Burren Rider's Avatar
Oddometer: 1,819
A few photo's of the Safari Tank prototype mould.
Cheers,
Danny
Burren Rider screwed with this post 04-09-2012 at 07:19 PM
Burren Rider is offline   Reply With Quote
Old 04-09-2012, 07:07 PM   #938
Burren Rider OP
Aussie Adventurer
Oddometer: 1,819
Absolutely. I've been extremely happy with dyna beads in my tubes. I'm only using them in the front of the Tiger. Just make sure you remove any weights on the rim.
Thanks for the feedback Rob, I will try to track some down here in Australia and give them a whirl.
Cheers,
Danny
Old 04-09-2012, 08:01 PM   #939
RichardU
Let's Ride
Oddometer: 903
I've always felt dynabeads rely on a high level of placebo effect. If you hunt around the web you will find people who have tested them mechanically and found they do not balance the wheel.
RichardU is offline   Reply With Quote
Old 04-09-2012, 08:44 PM   #940
The Breeze
Oddometer: 212
Cheers,
Danny
Nice Thanks for the pix
Looks like the tank is coming along nicely. Really looking forward to having some serious range on my bike. I'll definitely own one of these, when available.
Please keep us posted regarding updates/new developments.
The Breeze is offline   Reply With Quote
Old 04-09-2012, 08:52 PM   #941
the_babaji
the_babaji's Avatar
Oddometer: 288
Silly Question?
Would they be available in a selection of colours?
the_babaji is online now   Reply With Quote
Old 04-09-2012, 09:00 PM   #942
The Breeze
Oddometer: 212
Originally Posted by the_babaji View Post
Silly Question?
I'm sure there will be several colors including translucent (so you can visually see how much fuel you have left). Keep in mind that these will be molded plastic tanks......and therefore, they will be "molded in color". So it won't be a beautiful metallic paint job, like on the OEM tank......it'll be more like a plastic dirt bike tank.
Old 04-09-2012, 10:49 PM   #943
the_babaji
the_babaji's Avatar
Oddometer: 288
Well as long as they offer one in black. I would hate to put a clear translucent one on this beast 'o mine.
Old 04-10-2012, 12:28 AM   #944
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,868
Well you might "feel" the placebo effect but I'm not feeling any vibration or unbalance in my front wheel since changing the tyre. So, unless it's a fluke that it's balanced without needing weights (unlikely) the Dynabeads must be doing their job.
Don't forget, these beads need some speed to throw them into the right place within the tyre/tube. I wonder if those people testing them "mechanically" get enough speed into the spin. Dynabeads will not balance a wheel by the static balancing method as they're mobile inside the tyre/tube.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 04-10-2012, 01:24 AM   #945
Windy Rider
Pussy Power
Windy Rider's Avatar
Oddometer: 378
The tank has come up great, nice lines. I think this is going to have to go on my bike too. Can't wait to see one on a bike.
2011 Triumph Tiger 800xc
Windy Rider is offline   Reply With Quote
Times are GMT -7.   It's 06:33 AM.
