Old 09-27-2012, 06:11 PM   #1396
ducnut
Oddometer: 2,482
Originally Posted by sTE610vE View Post
maybe I have overlooked the Triumph, the 3 cylinder engine just seemed to be big and bulky but if they can do this (i know these are pro riders) I guess I might need a test ride.
Take a look at one, in person. The 675/800 triple is actually quite narrow. Triumph routed the frame tubes over the top of the engine, to help keep it slim.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 09-28-2012, 04:47 PM   #1397
burmbuster
burmbuster's Avatar
Oddometer: 907
Originally Posted by rustynut2 View Post
how loose is the chain, looks excessive.
Is the center stand worth buying, its on my list of goodies unless its more trouble than its worth.
John,
The only reason I purchased the center stand was ease of changing tires and tubes. Some say its hard to get the bike on it. I am not a big guy and have no problems getting the Tiger on the stand. I will say that it can be a pita to install.
burmbuster is offline   Reply With Quote
Old 09-28-2012, 06:29 PM   #1398
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,550
Originally Posted by burmbuster View Post
John,
I found the install easy by slinging the bike off a post in the shop. The spring was a little fiddly.
I had to post on the owners thread about getting the f'cker up on there and it turned out to be technique - stand facing the front of the bike and pull back instead of lift. That did the trick. It is a tough one to get on the stand. But it's very stable once there. It takes some effort to get it down too. Maybe I'm just not used to a 475lb motorbike.
browneye is online now   Reply With Quote
Old 09-29-2012, 12:49 AM   #1399
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 2,566
Send a message via Yahoo to blacktiger
1, the long travel suspension requires a good amount of slack in the chain. Although this one isn't as bad as what the Tiger955 needs.
2, yes, it's worth buying. It just makes maintenance, puncture repairs (wheel removal) and loading so much easier.
2002 Tiger955i in black, 69000 miles.
2012 Tiger800XC in black, 19000 miles.
Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, KTM600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)...
blacktiger is offline   Reply With Quote
Old 09-29-2012, 02:28 PM   #1400
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,550
UniFilter Group Buy
So got my pre-filter from Pyg - thank you!
Thought I would tear into it today, check the airfilter to make sure it wasn't full of dirt already (3K miles) and check out the infamous steppermotor thingy.
Holy crap, 35 screws to remove the tank and airbox?? Check the air filter??? This thing is definitely not a dirtbike!
Airfilter was pretty clean. But I don't know how they expect you to fit the prefilter in where the snorkel was without removing the airbox cover and the support over the ABS unit. Still took me ten minutes to fit it in there. And they say 10 minutes to RR and clean it without opening the airbox. Geez, I dunno.
Decided to pull the whole airbox and check out the stepper. Lubed the linkage and the throttle works easier. Stepper motor shaft, but didn't think to remove the boot over the stepper shaft. Guess I shoulda done that.
Buttoned'er back up. At least I got to see what's in there. All the bodywork is unbelievable to just service the filter.
Old 09-29-2012, 07:01 PM   #1401
Meles meles
Oddometer: 161
Chain slap
Crappy hand-held video but skip to the last 5 secs and you can see the center stand is fairly stable while the chain is slapping all over the place. This was before the center stand spring upgrade too.
http://www.youtube.com/watch?v=qtMbbQeDm8s
Meles meles is offline   Reply With Quote
Old 09-30-2012, 05:50 AM   #1402
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,479
Interesting, but I wouldnt expect it to be any other way. As a comment on the amount of slack, my Tiger 955 has almost 1.5 inches and IIRC the Trophy, America, and RS prior to that were about the same. Always ran them on the loose side of the spec. Never had a problem and alway had great chain life.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 09-30-2012, 07:01 AM   #1403
Androu
Androu's Avatar
Oddometer: 20
Man, I remember when I was young and I could eat it like that and just pick up the bike and keep riding. Now I'd be in traction for a month :)
Androu is offline   Reply With Quote
Old 09-30-2012, 05:19 PM   #1404
gregdee
Motocampist
gregdee's Avatar
Oddometer: 188
Maybe a Tiger for me
I took my Sprint ST in for a service the other day and I took home a Tiger 800 XC for the evening. Somehow my ride home turned into a 100 mile test ride.
I did a route that was familiar to me, one that I have ridden it on my KLR several times this summer. The route consisted of highway, super tight twisties with significant elevation change and lots of blind turns, some mellow dirt road to some more technical dirt road across an Indian Reservation and out to an interstate highway. After 5 miles on the freeway at 80 mph I was back on a dirt road with lots of rain ruts and washed out sections. I managed to haul at comfortably at about 40-60 mph along this section, about what I do on the KLR. I ended back on a nice set of twisty pavement back home just as it was getting dark.
This bike was 100% stock. Instantly I knew I would remove those stupid rubber pads from the foot pegs and I would raise the bars. I didn't like the windscreen all that much as it seemed to blast air right to my forehead - I kept checking the vents in my helmet as this was an odd sensation. But overall I was pleased by the smoothness of the ride and the pleasant reassuring manner the Tiger had off-road. The tires were OK but they did track funny on pavement. I had no issues with them off-road as they handled dirt, rocks, sand, and everything in between just fine. No mud on this ride.
My biggest let down was the lack of power - and I ride a 2002 KLR as my DS rig. So what gives? It felt like I really had to want it to get the Tiger moving. My trusty salesman at the shop said people bitch about this initially but then they just get used to it. I really want to like this bike and trade in my Sprint for one but right now I might just have to hold out for the Big Tiger to come out in April. Don't get me wrong, this bike is way nicer than my beater KLR but for 7x the price I expected more.
gregdee is offline   Reply With Quote
Old 09-30-2012, 05:46 PM   #1405
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,685
A new klr is $6500. A new tiger is not $45,000.
A lot of your complaints seems to not take into account not everyone likes the same thing i.e. windshield type, rubber vibration isolators on the footpegs (which are removable). Some people like those things as is. Others change them for little cost.
The motorcycle needs to be revved to create power. It's not thumper. Maybe your klr just suits you better.
swimmer is offline   Reply With Quote
Old 09-30-2012, 07:02 PM   #1406
ducnut
Oddometer: 2,482
The 800 engine is a stroked 675. It definitely doesn't have the power characteristics of your Sprint. When I rode the 800, I just had to keep reminding myself that it's more like my Daytona 675 was than what my Tiger 1050 is. The low-end torque of the 1050 spoils those who have one and, then, get on something smaller.
'96 Ducati 900SS
Old 09-30-2012, 07:45 PM   #1407
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,550
Tiger Impressions.
The torque curve is very linear and flat. It's done intentionally to make it a good distance bike and more tractable offroad. Once they are broken in and you hit 6G's, it does have a noticeable boost. It's not a hot-rod bike but it can be if you choose to rev it.
I think it's brilliant. And very easy to live with.
I threw the foot peg rubbers away the day I got it. Stock screen is fine unless it's blustery out or over 80. Otherwise I find it adequate, and it gets the pressure off your chest.
It is a little over twice the price of a KLR and well worth it. 50% more than a Vstrom, and well worth it. I compare it to a GS, and it's 30% less than one of those.
It's not a liter bike. It doesn't weigh like one either
Old 09-30-2012, 08:27 PM   #1408
burmbuster
burmbuster's Avatar
Oddometer: 907
I came from a Sprint as well. Just sold my '07. Ride a few other adventure bikes and you will see the power is actually great. The Tiger is the best bike I have ever owned. Bar none.
_______________
2012 Tiger 800 XC
Old 09-30-2012, 08:30 PM   #1409
burmbuster
burmbuster's Avatar
Oddometer: 907
Browneye,
I am installing mine tomorrow. You should have been able to just fold the flange and install it by just removing the seat?
_______________
2012 Tiger 800 XC
Old 09-30-2012, 09:54 PM   #1410
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,550
Unifilter install
Browneye,
Uh...no.
Let us know how it goes for you.
Times are GMT -7.   It's 10:12 PM.
