11-29-2011, 06:41 PM
#91 |
Oddometer: 356
There was no real definitive anwser other than the Stator wiring is suspect. The author noted that a call to BMW for parts yielded a cost of over $900 large as it was a complete charging system... but all that is needed is a Stator.
The good news is that he found a Stator only at Ricks Motorsports Electrics for $165 !!! http://www.ricksmotorsportelectrics.com/ Hope this helps!
2010 Lava F800GS...AKA "Dirty Harry" 1998 R1200C Classic Black...AKA "Dick The Cruiser" BMW_BIKER_KEITH screwed with this post 11-29-2011 at 06:47 PM |
11-29-2011, 08:02 PM
#92 | ||||||||||||||||||||||||||||||||
Oddometer: 41
That part from Ricks is available from Parts Unlimited too. Same price. Read the article and agree, nothing not discussed here.
Not sure where the $900 comes from. There may be some parts you need besides the two mentioned. Both the gasket for the cover and the generator comes to just under $800. The warranty from BMW is 2 years. Not sure about the Ricks warranty. Probably at least 1 year. I would bet that the stator will be available soon from BMW as a single part.
Total $793.66 |
11-30-2011, 03:31 PM
#93 |
Oddometer: 3,441
12-01-2011, 10:44 AM
#94 | |
Oddometer: 4,914
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
12-01-2011, 03:56 PM
#95 |
back in the saddle again
Oddometer: 590
I am not an engineer, just a dumb shade tree mechanic who looks at stuff without counting the binary numbers. When I pulled my dead stator at 50,000 miles all the windings were black and it smelled like fried electrics. I had it re-wound... and that didn't work (bad winding job or somthing). Bought Ricks stator and am using it now. Look at the placement of the exhaust tubes.... too damn close to the alternator for my taste. You know that exhaust tube gets MIGHTY damn hot.... tell me it does not effect the alternator. I suggested heat wrap on the exhaust around the alternator area - but have been too busy to try it.... it might be a simple fix.
TheCowboy |
12-01-2011, 06:02 PM
#96 |
Oddometer: 356
Damn good idea Cowboy... damn good observation.
2010 Lava F800GS...AKA "Dirty Harry" 1998 R1200C Classic Black...AKA "Dick The Cruiser" |
12-01-2011, 07:33 PM
#97 |
Oddometer: 3,441
It sure as hell can't hurt ....
I was in O'Reilly auto parts the other day and they had the stuff hanging on the shelf ... I think I'll go back and get some... It looks like it will require removing the headers to do the wrapping.... We'll need a pair of new gaskets P/N: 18217672804 to go between the pipes and the cylinder head? |
12-01-2011, 09:21 PM
#98 |
Advenchaintourer
Oddometer: 1,993
If I was going to go that far I'd get mine jet-hot coated.
http://www.jet-hot.com/coatings/ Reduces heat, looks good & comes in various colors. Looks better than a wrapping. |
12-01-2011, 09:48 PM
#99 |
Earthbound Misfit, I
Oddometer: 163
Jet hot sounds like a good idea. I had been wrapping my header pipe on the dirtbike and it's been great! No burned leg/pants when i get pinned to it. BUT it clogs up with mud too easy and the mud soaks right through, not to mention moisture/water. Some said it will breed corrosion. At the end of it all i took it off and learned to ride better. It may be a solution for those who don't venture in a lot of mud/water... But then, caked on mud... Bad idea or just bad looks+weight?
12-04-2011, 07:55 PM
#100 |
Oddometer: 41
What about a simple exhaust pipe heat shield of SS on the upper (closer) pipe to deflect the heat away from the cover. Won't absorb water like the wraps. Besides, there is not enough room to wrap only the upper pipe. You would have to wrap both. The distance between the pipes is not large enough to get the wrap between.
A Ti cover would look good but CF would disipate heat better. |
12-04-2011, 08:26 PM
#101 | |
Oddometer: 2,823
Erling |
12-07-2011, 07:37 PM
#102 |
Danger: Keep Back 500 Ft.
Oddometer: 997
12-12-2011, 03:55 PM
#103 |
Oddometer: 3,441
I wonder if a layer or two of this stuck to the bottom part of the stator side cover would be worthwhile:
http://www.thermotec.com/products/14...mo-shield.html Note that this particular product is NOT meant for wrapping exhaust pipes! But this company does sell that stuff as well.... |
12-12-2011, 04:25 PM
#104 | |
Advenchaintourer
Oddometer: 1,993
"One motorcycle racing team that employed the system used a laser-guided thermometer and found that while the exhaust can have an internal temperature of around 150 degrees Centigrade, the outside temperate can be low enough for the exhaust pipe to be removed WITHOUT using gloves." "Lower temperatures also increase the durability and effectiveness of engine and transmission oils, improve engine cooling and help to protect ancillaries such as starters, regulators, wiring and modern alarm and ignition systems from the degrading affects of excessive heat." Starting to think about doing this. |
12-12-2011, 06:52 PM
#105 |
Lost
Oddometer: 519
Cush |
