Old 10-01-2011, 09:54 AM   #91
ebrabaek
Oddometer: 4,710
Originally Posted by tmotten View Post
Fair enough. I've decided to go with a female mould for this fairing. Will need to cut some of the inside panel for access though, but that's there for aesthetics only anyway. This will make it easier to layup wet and produce a heaps better finish with no worries about degassing.
What's your opinion on more layers with lighter fabrics vs less with heavier fabrics?
The thickness of the fabric... Is usually determined by the kinks and crazy angles it has to conform to..... Like thinner fabric conforms easier than thick..... But takes longer labor..... Either is fine.. Like what ever you can get the cheapest.... 90% of my projects are done with 6 ounce fabrics.... ( either carbon fiber or kevlar) It`s a great all around thickness to work with..... I use twill. 2x2.
Erling
ebrabaek screwed with this post 11-08-2011 at 06:52 PM
ebrabaek is online now   Reply With Quote
Old 10-02-2011, 08:38 AM   #92
Orangecicle
Orangecicle's Avatar
Oddometer: 2,447
Twill fabric is fairly easy to "bend" around odd corners, like you see on your fairing. Some fabrics, such as the checkerboard pattern, can be really hard to bend around odd shapes.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 10-02-2011, 09:40 AM   #93
Orangecicle
Oddometer: 2,447
Vacuum regulators
I'm looking for a decent vacuum regulator. I've found decently vacuum pumps at reasonable prices, and I'm going to build my own vacuum tanks: http://www.joewoodworker.com/veneering/whybuild.htm
(borrowed photo)
But now I'm looking for an electro-mechanical valve that will cut off the pump when the vacuum hits about 25" Hg. Any ideas? I started trying to find a good regulator, but the only regulators I'm finding are really expensive at over $200, and that doesn't include a cutoff valve to shut the pump down when the pressure gets high enough:
http://www.smcpneumatics.com/irv-series.html
Maybe it's cheaper in the end to just buy a more expensive regulated pump? I don't know.
Orangecicle screwed with this post 10-02-2011 at 09:47 AM
Old 10-09-2011, 12:56 PM   #94
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
Here's my finished project of a custom fiberglass, pop up camper on my Samurai.
trackhead is offline   Reply With Quote
Old 10-09-2011, 09:09 PM   #95
HickOnACrick OP
Groovinator
HickOnACrick's Avatar
Oddometer: 2,507
Trackhead,
This is really nice work. I can't wait to see the inside. Did you use foam as your mold? If so, where did you find pieces large enough?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 10-10-2011, 07:08 AM   #96
HickOnACrick OP
Groovinator
Oddometer: 2,507
(borrowed photo)
I bought a Harbor Freight pump over a year ago. I have used it for multiple projects and it is still going strong. It was on sale at the time for around $130, and I believe building one yourself will cost nearly as much.
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 10-10-2011, 07:59 AM   #97
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
Originally Posted by HickOnACrick View Post
Trackhead,
Home Depot polystyrene, the pink stuff.
Old 10-22-2011, 08:38 AM   #98
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
Hey Hick, what do you think of those pumps that work off of an air compressor? I have a decent compressor in my garage already.
Old 11-08-2011, 05:54 PM   #99
flemsmith
lurk
Oddometer: 594
Finally gave it a try....
Post # 36 I printed it and was waiting til I actually got the bike running again before I messed with the sidebags. Plastic Enduro's that someone jigsawed an inside corner out of. I've never done any fiberglass work, didn't even know how to buy it. So I read the detailed instructions and gave it a try....unfortunately I was using Bondo gel resin, and it's boucoup thick. It did manage to plug the hole from the inside, but on the outside (which luckily won't show when it's mounted) I still ended up with a thick mess that I couldn't really smooth when 'wet', so I sanded it and went to Home Depot to buy the 3M version, which went on much more like your description.
http://flemsmith.smugmug.com/Other/M.../IMG3678-M.jpg
Here's a pix of the rough dried fiberglass before any sanding or painting. (assuming I did the picture link properly). The green color is from the bondo resin, I can't see using that again.
The main point is that I really do appreciate the great advice available on this site, For almost any topic! Thanks!
roy
flemsmith is offline   Reply With Quote
Old 11-09-2011, 10:18 AM   #100
redprimo
Oddometer: 403
Here are a couple of tips:
Use large diameter shallow containers vs small diameter deep containers to extend the pot life of polyester resin. epoxy is less sensitive to this.
You will get better results with spraying pva by not thining it and spraying with a non hvlp gun. The best pva gun I had was an old binks model 7.
Tape down some heavy plastic over a table and lay your cloth flat to wet it out then pick it up and place it in the mold. On choped and thicker cloth pour/paint some resin on the plastic before placing the cloth on the table. Large pieces of pre wetted cloth can be transered to the mold by rolling or folding up the cloth to avoid streatching and distortion. Doing this will speed things up and can help reduce resin pooling in the bottom of your mold.
Tap Plastics in California is a great resource for all things composite. their house brand of epoxy is very similar to system 3. In addition to the 3 hardeners having different working times the most important difference is they produce 3 different levels of stiffness.
redprimo is offline   Reply With Quote
Old 11-09-2011, 08:26 PM   #101
HickOnACrick OP
Groovinator
Oddometer: 2,507
Do you have this backwards? I am under the impression that the greater the surface area exposed to air, the shorter the pot life??
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 11-11-2011, 12:38 PM   #102
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
He might have been talking thermal runaway? Dunno.
bxr140 is offline   Reply With Quote
Old 11-11-2011, 03:33 PM   #103
redprimo
Oddometer: 403
Not for polyester resin. Polyester resin is an exothermic reaction and heat is also an accelerant to the reaction. if you contain the heat it will go off faster. That is why resin in any bucket always goes off before the lay up. Likewise if you use a large diameter bucket and increase the surface area and minimize the thermal mass you will extend the pot life. My tip about pre weting the cloth is also a way to extend the pot life. The pre wetted cloth if left flat will not go off as fast as the resin in the bucket.
I used to have my own pattern and mold business and before I had any employees large layups would get a bit crazy. I would mix resin and paint some on the mold then wet out a piece of cloth and fold it up and transfer it to the mold and un-fold it but not roll it out, then pre wet another layer and leave it on the table while I rolled out the first piece of cloth.
I have never used a paint roller to apply resin, it is too slow. I aways pre-weted the cloth by pouring the resin on and then using a bondo spreader to move it around. When I mention rolling out the cloth I am refering to using a ribed metal roller to get rid of any air bubbles.
All that I have written also applies to epoxy but the effect of using a shallow bucket on 40 minute epoxy is less than on polyester resin.
You may be refering to high humidity reacting with epoxy resin and making it kick faster. I live in California and have no experiance with this so some one who does will have to chime in.
Old 11-11-2011, 05:47 PM   #104
HickOnACrick OP
Groovinator
Oddometer: 2,507
Cool. Thanks for clearing that up. Do you think one could pre-wet some layers, then toss them in a fridge for 30 minutes or so until he got all the layers ready, then lay up he piece?
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 11-11-2011, 08:30 PM   #105
ebrabaek
Oddometer: 4,710
There are a lot of good user input in this thread. A subject that most books....dvd's or course's don't cover..... "The spills and thrills" But as with many people trying their own phase of work..... they venture out to try new things.....and all are not good.... and so it goes that mis information.... Or things that is not necessary the way things work correctly can be misinterpret, and discourage others that thought this is the way. So with all these different advises......available....I encourage all to test new methods ( wherever they are found) on a test batch of any kind.... Before moving onto the piece you are making.......as you are running a risk of destruction and failure...... Which to the newcomer can be detrimental. Many things work great...but perhaps not for each project... So that goes for every project.... Test your methods on a ....uuuummm test bed before moving on to your project...... That said.... Onward with the layups.....
Erling
Times are GMT -7.   It's 01:55 PM.
