Old 07-19-2011, 10:02 PM   #1
the octopus OP
The Chef
the octopus's Avatar
Oddometer: 106
Cool2 Bazzaz Performance Z-Fi MX and Z-AFM for the KTM 990 Adventure Review
Well, I think it's about time I write a review of the products I had Chris at Bazzaz fit to my 990.
First, a little background on Bazzaz. They are one of the few manufacturers of piggy-back systems that are actually worth using (in my opinion). Plus, they have a tried and true auto-tune setup that is utilized by racers (both on and off-road) all over the world. Though modifying the ECM directly is always my preferred plan of action, the ease with which the auto-tune system works makes it a serious consideration for most normal riders. More serious track bikes can make use of their quickshift and traction control features, but for those of us on the 990 Adventure, the Z-Fi MX is a perfectly acceptable unit (though it lacks gear and cylinder trim).
Now to the good part: what Bazzaz put on my bike.
The Z-Fi MX:
The Z-AFM:
In addition to the Z-Fi MX and the Z-AFM (plus AF sensor), Bazzaz built a plug-and-play harness, and included O2 eliminators and an SAS pump eliminator. I'm not sure if the latter two will be included in the final kit.
Installation is simple, and instructions come with the units. The Z-AFM's AF sensor is placed in the front O2 bung, since the front cylinder runs leaner than the rear. The Z-Fi MX and Z-AFM are powered by the ABS wiring under the seat, but do not delete ABS functionality.
An initial map was built for my 990R with FMF Q4 Ti exhausts on the dyno in the shop. This map will be supplied with all the Z-Fi MX units sold for the 990 Adventures.
Here is the HP and torque dyno map comparing stock the new map:
Here is the AF map (which I think is much more impressive):
Auto-tuning is accomplished by turning on logging via the Z-AFM and related sensor, then accepting the changes it suggests for specific regions of the map in the Bazzaz software. This can be done on a dyno or a wide open stretch of pavement.
Now to the important part: how does it run? The truth is that I'm not a huge proponent of removing O2 sensors on any bike. With that said, the bike is so incredibly smooth it's unbelievable. Hard to say whether the power and torque increase is noticeable, but I could care less about that (never been a numbers queen). I've ridden the bike at sea level and then gained 4000 feet in elevation, and the bike has performed well in both environments. The powerband is usable both on and off-road. I also dumped the bike real hard (and broke my foot) on a ride a couple weeks ago, and the units still work great.
My only issue is that every now and then, the bike shuts down every now and then mid-idle after first start in the morning. My bike did this a couple times before the Bazzaz units were installed, but it has become more noticeable since.
I'm not sure what the price is going to be on the final kit, but I think it will be a good solution for many riders. The auto-tune functionality will allow each rider to customize a map to his or her bike, and his or her environment without needing to buy additional datalogging equipment and analysis software. That, alone, is an amazing feature.
the octopus is offline   Reply With Quote
Old 07-19-2011, 11:09 PM   #2
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,291
Thanks for the write up oh eight-legged one.
That A/F plot sorta tells an interesting story. Do you have many tanks of gas through the beast yet? I ask because holy mackerel Batman, that stock setup is wayyyyyy rich. No wonder there's herky jerky low-throttle behavior, and totally shitty gas mileage on these bikes! I'm guessing your "new" bike now RIPS from cracking the throttle on up, with no blubber, stumble, etc.??? I also guess your gas mileage may improve a skosh....or even two skoshes....
Thanks again, and heal up so you can get back on the scoot!
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 07-19-2011, 11:20 PM   #3
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 773
yep, keep the info coming.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 07-20-2011, 02:17 AM   #4
Kenbike
Oddometer: 718
Was happy to get the ride report, but very sorry to hear you broke the foot. Is it healing ok?
I will call Chris at Bazzaz and to check pricing and what will be included in the kit. One real advantage with the Bazzaz unit is future changes to the bike with intake, exhaust, valves ect. can easily be tuned and your are back with a perfect map.
If a person wanted a quick shift they could purchase the other Bazzaz controller and add that feature. This could be a real plus for guys on Super Dukes, and Super Moto bikes. I pretty sure this will work on the 690 series of bikes also.
Did you get to check your mileage?
If you are not on a dyno, what steps do you take to accept the changes the unit recommends to the map?
Thanks!!
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 07-20-2011, 09:07 AM   #5
the octopus OP
The Chef
Oddometer: 106
Thanks for the well-wishes guys. It was just a mild hairline fracture, so it's healing fairly quickly. I'm back to being able to put weight on the foot, and am fairly mobile. Probably should have let the doctor put a cast on me....but I don't like being restricted.
The bike had 3300 miles before the Bazzaz setup was installed. I was averaging 35.7 mpg with the stock setup. Now, with the exhaust change and fueling modules, I'm sitting at about 44 mpg. I've only put 5 tanks through the bike with the Bazzaz stuff on, so I'm sure that number will shift around a bit. After another 1000-2000 miles, I'll report back with a more reliable fuel economy value.
Power delivery is indeed FAR more immediate with the current setup. Low-RPM stumbles are more or less gone, and it's smooth throughout the whole RPM range. I'm a happy camper with the results, to be sure.
Ken is right. The ability to remap on the fly is great. That means any change to the setup can be matched with a fairly rapid change to fueling.
Without a dyno or track to do the logging on, I would suggest people stick to the same principle used to obtain datalogs on any fuel injected engine: very slow changes in throttle position, trying to hit the full range of RPM/TPS values. I usually tell my customers (I have a small business tuning Buells) that the best method is to look at the map on your computer and write down each of the RPM values on a post-it, then stick it to the speedo. Find a nice long uncongested stretch of road, get into a high gear, and start at the lowest RPM value. As you slowly increase throttle (slow is key), you progressively ride the rear brake harder and harder. This locks the bike to the RPM you've initially targeted while enabling the Z-AFM to log data over a wide TPS range for that specific RPM value. Finding a nice long stretch of road going up a hill is even better, to increase load on the engine. Of course, this method eats up rear brake pads and makes the engine work harder than it normally does. Equally, it should be done entirely at your own risk. The beauty of datalogging and tuning on the road is that it reflects your bike's normal operating conditions and operating environment. No matter how high tech a dyno is, it will never be able to recreate that. There's actually a strong argument for datalogging in the normal environment OVER tuning on a dyno.
Old 07-20-2011, 09:09 AM   #6
the octopus OP
The Chef
Oddometer: 106
Oh, and I should add that the software allows you to create an AFR bin so that it can use the Z-AFM data to calculate new fueling values. This is very nice, because it allows you to target different AFRs at different RPM/TPS ranges. For example, you could create a bin that would allow you to get maximum fuel economy at cruise and maximum power at high RPM. No need to be stuck to targeting just one value.
Old 07-20-2011, 11:09 AM   #7
fast4d
Oddometer: 2,456
I really like the wideband option. makes tuning so much easier. I've been thinking about it for the RC8 but not sure if it's available yet.
quickshifter would be awesome too.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 07-20-2011, 12:20 PM   #8
Sock Monkey
Corporate slave
Oddometer: 2,291
OOH OHH......pick me....piiiiick me....
So, is there a way to change maps on the fly? If so, it would be saweeeet to be able to use the "high mileage" map while slogging to/from the good stuff, and the "get out my way foo!!!" map for the real fun.
And daaaaamn....a 10(ish) mpg improvement?!?! If that number pans out, getting this setup (Fi + AFM) would pay for itself in fuel cost savings in just a few years, assuming 10k miles per year and current fuel prices (at least here in the USA). And all the while, you're getting WAY better performance. Now THAT'S what I call "win win".
-SM
aka NoVector
Old 07-20-2011, 12:55 PM   #9
the octopus OP
The Chef
Oddometer: 106
They've had items available for the RC8 for quite a while.
The only way to change maps on the fly is using the software and a laptop. You can save and load maps within the software, so switching between then would be fairly painless. There is, however, a way to get around this. The harness has a plug with a jumper wire that, when plugged in, uses the Z-Fi to modulate fueling parameters. When unplugged, however, it bypasses the Z-Fi and uses stock mapping on the ECM. You could, ostensibly, tune the Z-Fi using one AFR bin, then use the percentage values that it calculates to actually modulate the map using TuneECU (or some comparable program) within the ECM itself. In this way, you'd have a baseline tuned map already on the ECM which would be active with the jumper cable unplugged. Then, you could create a separate map on top of this using a different AFR bin with the Z-Fi and Z-AFM that would be active with the jumper cable plugged in. Then swapping between the two would be as simple as removing the seat and plugging or unplugging the jumper cable.
Old 07-20-2011, 12:58 PM   #10
the octopus OP
The Chef
Oddometer: 106
Here's what the software looks like:
Now, remember that the Z-Fi MX does not have cylinder or gear trim, so some of the options seen in the above screen will not be available for the 990. The "Self-Mapping" tab is where the Z-AFM comes into play.
Old 07-20-2011, 01:08 PM   #11
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,892
Subscribed
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 07-20-2011, 01:09 PM   #12
fast4d
Oddometer: 2,456
will it work on the dual spark engines on the 2011 model.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2013 KTM SMT 990
Old 07-20-2011, 01:13 PM   #13
the octopus OP
The Chef
Oddometer: 106
Their website only shows support up to 2010 models. Call in and check with Tech Support. They should be able to answer that for you.
Old 07-20-2011, 02:29 PM   #14
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,892
KTM 990 Kit
I emailed Bazzaz on availability & pricing and got the following response....
__________________________________________________ ___________________________________
Yes, we should be releasing it in 1 to 2 weeks. Part number is F582 and the price is $324.95.
The Z-AFM is a separate, optional unit and it is $299.95
Here are some notes I have on the kit:
Notes:
Increases torque and hp
Significant improvement in throttle response
Includes two O2 eliminators. Use front cylinder when self-mapping
Secondary Air Separator (Pair Valve Eliminator)
-Provides more stable Air/Fuel Ratio (AFR), resulting in a better tune.
-Sold separately
Tracey de Martini
Executive Assistant / Sales
15330 Fairfield Ranch Rd., Suite E
Chino Hills, CA 91709
P - 909.597.8300 x-24
F - 909.597.5580
www.Bazzaz.net
Bazzaz - Word of a kit (Z-Fi MX, Z-AFM & Harness) has hit the pages of ADVRider.com.
Is there any pricing and availability information you could give me?
Thanks - Mike
Mike
Reinheitsgebot
Bonsai Elephant - "
Michhub screwed with this post 07-21-2011 at 11:12 AM Reason: text color
Old 07-20-2011, 02:39 PM   #15
the octopus OP
The Chef
Oddometer: 106
That's a great price on a full kit.
Also, nice reference to the German Purity Laws in your signature Michhub.
Times are GMT -7.   It's 08:24 PM.
