Old 07-19-2012, 02:57 PM   #136
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,120
Well I'd just to say I. SWEEEEEEET. Time to empty my bank account once again . I may have started it but you perfected it. . Where is discovery channel with rally bike build off ,
Mudguts is online now   Reply With Quote
Old 07-19-2012, 03:10 PM   #137
Evil Invader OP
Evil Invader's Avatar
Oddometer: 696
Cheers mate!
Rally bike build off? I´m in!!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 07-27-2012, 02:22 PM   #138
Evil Invader OP
Oddometer: 696
Originally Posted by r'elise me View Post
referring back to the very first thing you did on this bike (awesome bike BTW), how does the crankcase vent if you block off the valve cover SAS hole?
This comment made me think, together with what r'elise me said in another thread.
Venting hot oily fumes from the crank to airbox ain´t exactly...the best solution.
So, time to rework. Any comment on this is most wellcome!
From crank to "oilbox" to atmosphere
Got some "leftovers", recycling is the word, right?
Cut and trim to better size
A leftover sas hose: cut to size
This plug that sits in the back can´t be fitted there in my setup. So replacing it to one of the bigger outlets, with a hose attached to it.This will be for venting out.
What do you think, should i connect a filter in the end of the hose, or is it not necessary?
This is where it places in the frame
setup
M Motoadventures
Old 07-27-2012, 07:10 PM   #139
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,015
I split (pryed with a small chisel) this piece open (looks like it was just melted together) and stuffed the labrynth inside full of universal air filter material and then used plastic epoxy to put the 2 pieces back together. No it is not serviceable this way, but it kept me from adding more junk onto the outside of it and it will keep the big chunks from falling in. Realistically I'd bet that it wouldn't have been much of an issue seeing as how the crankcases expanding hot air will blow out and not suck anything in, but adding the foam helped me sleep at night.
The Letter J is offline   Reply With Quote
Old 07-28-2012, 05:50 AM   #140
Evil Invader OP
Oddometer: 696
Cheers mate. The fact that it looks like some kind of labrynth inside makes me think the exit hose can be routed down towards the rear shock area and no dirt/water will get in.
M Motoadventures
Old 07-28-2012, 10:59 AM   #141
Uller
Uller's Avatar
Oddometer: 1,681
Don't know if you noticed my version of the vent hoses in the main thread so, I'll post here.
I used a part from the SAS system mounted to one of the outlets from the collector box that you modified and a small K&N Breather Element.
Uller is offline   Reply With Quote
Old 07-28-2012, 12:25 PM   #142
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,006
Outstanding
Èllo
MAN did this thread go haywire!!
Sorry for late replies, being busy working and looking after my son....
Not easy be a father, but great fun!
Nope. Will rework it when winter arrives, and think I will still use the Suzi quad pump, and have a vaccumpump help feed it. Really would like the fuelpump out from the tank...
But would still be nice to se Speedi´s sollution.
But for now I just wanna ride the darn thing!
Nice to see I can stir the pot a bit. Remember Mudders, You started it!
Lookin forward for your buildthread!
Still no bashplate though....starting to loose hope on RRUK now...
Got some stickers made for it. Wadayathink?
Oh, and I run mousse!
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is online now   Reply With Quote
Old 07-30-2012, 01:45 PM   #143
Evil Invader OP
Oddometer: 696
Thumb
Yes remember that one. Really neat and well thought through.
M Motoadventures
Old 08-28-2012, 07:17 AM   #144
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 6,054
Originally Posted by LukasM View Post
Paul,
I haven't tried it but yes, I do believe the rim lock shrader valve will seal sufficiently once it is tightened.
Beaney is right though, let's get this back on topic. Sorry Evil Invader for the minor diversion.
Here is the now finished 690 Adventure R owned by David Jenni from Enduristan, next to Despres Rally. It was built by KTM Basel with OEM 450 Rally parts and they are thinking about making it available as a kit:
That is good lookin!!
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 11-21-2012, 09:38 AM   #145
Mike_MRS
Oddometer: 382
Evil, what bars are you running? Dakar high? If so are you ok with the sweep?
Mike_MRS is offline   Reply With Quote
Old 11-26-2012, 12:40 PM   #146
Evil Invader OP
Oddometer: 696
Hello BigMike!
Its a Renthal RC high. Like it a lot.
M Motoadventures
Old 11-26-2012, 12:49 PM   #147
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Wow... great work on your KTM, looks really cool! Awesome pics of your kiddo too
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 01-03-2013, 11:45 PM   #148
Mudguts
Mudguts's Avatar
Oddometer: 2,120
Guess what I picked up today ............one RH tank and seat still waiting on left tank ordered these in August .
So it's 42deg C today sweating my arse off in a garage looking and seeing what has to be done next
Also got some goodies from KTMTwins , Fastway Adv pegs , sigtech clutch slave, and CA fuel pump .
Now I've been thinking of a fuel pump set up like the 950's with the pump up front down low with all tanks draining
Into the pump manifold then pumped to the throttle body ?
Also had to check whether the rally tanks will fit on the 500 .........No
Old 01-04-2013, 02:14 AM   #149
Evil Invader OP
Oddometer: 696
Cool! To bad you missing one tank, but with the seat and RH tank there is a lot to start with.
Lookin forward to your build!
M Motoadventures
Old 01-31-2013, 01:33 PM   #150
Hemskesven
Oddometer: 15
Dude, i had no idea you where in the middle of the build when we rode in Härjedalen this summer.
Nice project! I actually thought you had bought another pro built Dakar bike!
See you on the trail when (if ever) spring comes around :)
/ Thomas Lindström
Hemskesven is offline   Reply With Quote
Times are GMT -7.   It's 06:04 AM.
