Old 05-21-2012, 03:01 PM   #76
Mackan
Player 1
Oddometer: 9
Just stumbled upon this thread.
Why, oh why, did you have to plant these ideas in my already overloaded mind?!
When your done, take it for a spin down to GBG so I can have a go. OK?
Can't wait to see the finished result!
Mackan is offline   Reply With Quote
Old 05-21-2012, 08:33 PM   #77
ramjet
ramjet's Avatar
Oddometer: 2,267
Evil Invader, I envy your access to these rare parts. Do you know if engine components can be had for the Rally bikes still. Or would it be futile because the frame and transmission is completely different than standard?
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 05-21-2012, 10:39 PM   #78
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,203
great thread, wish i had your budget and ability when I adventurized my 690
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 05-24-2012, 11:28 AM   #79
Evil Invader OP
Evil Invader's Avatar
Oddometer: 695
Tjena Mackan!
Canīt wait me neither...
Donīt really know what components you are refering to, but anything should be possible to order from your local dealer as long as you have the part.no.
Budget? Hell, itīs just work, order parts, pay bills, repeat...
And thanks for the kind words. Lotsa work lately, so build has come to a stand still, but soon....
Iīll be back
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 05-30-2012, 03:12 PM   #80
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Great looking bike! I will be in Sweden and Norway this September. I'd love to check it out in person.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 06-03-2012, 10:09 AM   #81
Evil Invader OP
Oddometer: 695
Thumb
You are most welcome!! Get i touch when you are in the country.
M Motoadventures
Old 06-04-2012, 03:02 PM   #82
Evil Invader OP
Oddometer: 695
Wink
Hello!
So, where were we.... ah, lights and roadbook.
Got me a pair of candles from an 640 Duke.
Some modification to make it fit.
One in place, one more to go...
Gpsmount, trip and roadbook in place
And..... voila!
Switches for gps, gripheat and ignition
The End.
Na!
M Motoadventures
Old 06-09-2012, 12:52 AM   #83
KTBen
Barrrp!
KTBen's Avatar
Oddometer: 475
Fkn AWESOME!!!
690 ADV
KTBen is offline   Reply With Quote
Old 06-09-2012, 07:15 AM   #84
ramjet
ramjet's Avatar
Oddometer: 2,267
Cool! How does the fuel circuit work from the Rally tanks?
Old 06-10-2012, 06:22 AM   #85
Evil Invader OP
Oddometer: 695
Well, it doesnt.
Still thinkin about it, but have no good solution yet. For the moment I just drive it as is till I get more inspiration....
Kinda of all wrenching for the moment now I just wanna ride it!
M Motoadventures
Old 06-10-2012, 04:41 PM   #86
LukasM
Oddometer: 5,425
What's the problem with your fuel system?
I would just use a simple/cheap/small/reliable Mikuni vacuum pump like the factory rally bikes (DF52-60). Put it down low up front to pump the fuel from both front tanks to the rear of the bike:
(not this exact model, but something similar)
Then use the RRP-UK tank adapter to feed it into the main tank.
http://www.rally-raidproducts.co.uk/...-adaptor-plate
This way you don't need an external pump and no additional wiring, just a simple vacuum line.
Old 06-10-2012, 07:07 PM   #87
ramjet
ramjet's Avatar
Oddometer: 2,267
Would this take a vacuum fitting off the head? And function with FI vs carb?
Old 06-11-2012, 02:29 AM   #88
LukasM
Oddometer: 5,425
The vacuum pump doesn't care whether it's FI or carb, it's just a simple low pressure pump (5-7 psi maybe?) to get the fuel from both front tanks into the rear. Then the stock high pressure (43-45 psi?) EFI pump takes over.
You could use any vacuum source that pulls when the bike is on, there is at least one on the head and one on the throttle body from the stock emissions equipment that could be used.
From Bartron's thread:
Head:
Throttle body:
Old 06-14-2012, 12:53 PM   #89
Evil Invader OP
Oddometer: 695
Probably this way I will go.
Just wonder if the pump will work with the rally fueltap, so I can "fill up" from the front tanks say when the low fuel-light comes on.
Hmmm... will have to make a return line when the petcock is "closed".....
M Motoadventures
Old 06-14-2012, 05:07 PM   #90
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Maybe you could put a valve on the vacuum line. So it would only pump when you wanted it to.. You could even use the electric valve that you took off when you removed the emission's BS... Mount a switch on your dash!
Times are GMT -7.   It's 06:46 PM.
