07-12-2012, 03:44 AM
#106 |
Oddometer: 282
Speedi,fine looking weapon
how are those tubliss setup working out,i have them on my 450 and looking to run a set on the 690,but havn't used then long enough to be convinced. would like to hear you thoughts |
07-12-2012, 11:14 PM
#107 |
KTM Cape Town
Oddometer: 3
Cant explain why, but for some reason I do not like the system. I dont feel safe riding the bike, especially on high speed tar section. Been struggling with the front inner tube pressure, it keeps losing pressure. Our bike runs up to 185kph and on tar I just do not feel confident with the tubeliss in front. Will be changing back to tubes ASAP. I might change my mind once I ride with the Tubes again!
Shop Online at shop.ktmcapetown.co.za |
07-12-2012, 11:34 PM
#108 | |
Oddometer: 38
I'm thinking to use tubeless wheels, I've only to find the rims with the correct internal profile... |
07-13-2012, 12:39 AM
#109 | |
Oddometer: 730
Making it tubeless is easy enough. keeping it going if you have to change the tire is more of a prob from my experience. The thread I found that lead to the method i used didn't seem to worry about bead's in the rim. As he pointed out if the tube goes flat in a hurry what really is the difference between a rim with tire/tube and a home build tubeless one.... a thought anyhow
If ignorance is bliss, why aren´t more people happy?????
07-13-2012, 01:38 AM
#110 | |
Oddometer: 282
07-13-2012, 01:46 AM
#111 | |
Oddometer: 38
![]() Also having less weight on the wheels is a big advantage for the suspensions, the tire, the traction and the handling of the bike I want to contact alpina, they make tubeless rims for the exc... |
07-13-2012, 01:59 AM
#112 |
Oddometer: 4,900
Nobody makes a strong tubeless wheel, incl. Alpina. I have seen them get bent up on supermoto courses without any hard hits.
If you are actually going to ride hard off road and want it to hold up, stay with the DID Dirt Stars or an Excel (ideally A60). Then seal up your rims using one of the methods Cyborg, Sakurama and Woodie have posted, and only use the Tubliss as a backup, instead to a safety bead. This will be way stronger and cheaper, and just as light as the Alpina wheels.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
07-13-2012, 05:41 AM
#113 | |
Oddometer: 38
but there a re several problem in using tubliss as backup, it's no so packable and hou have to drill out the sealant... not ideal... better a tube as backup IMHO + you can use only one tube dimension for front and rear wheel |
07-13-2012, 05:46 AM
#114 | |
Oddometer: 4,900
I am talking about having the Tubliss installed on sealed rims, not packing it. There is no risk of sudden blow out this way, unless you fuck up your rim with a square edge hit so hard that it totally deforms it.
07-13-2012, 06:09 AM
#115 | |
Oddometer: 38
but run in this way don't give many advantages (i don't have a good feeling with tubliss) |
07-13-2012, 06:13 AM
#116 |
Oddometer: 4,900
I don't get it. It will be stronger, cheaper and just as light as a $$$ Alpina wheel. What advantage don't you get "run in this way"?
07-13-2012, 06:24 AM
#117 |
rally racer
Oddometer: 124
[QUOTE=speedi;19108368]
Relocated fuel pump to front tanks to drain fuel from all tanks simultaneously New exhaust header pipe /QUOTE] How did you mount the oem fuel pump in the front tanks, would be intersteing to some pics of this. Will your exhaust pipe be available to buy seperately, and how much?
690 enduro/ rally 350 exc RALLY-RAIDPRODUCTS.CO.UK |
07-13-2012, 06:28 AM
#118 | |
Oddometer: 38
in other words... i don't like it |
07-13-2012, 05:38 PM
#119 | |
when in doubt GAS IT
Oddometer: 1,659
[QUOTE=beaney;19119677]
Even better run 2 fuel pumps 1as a back up ,keep the stock and add extra in the front tanks ,it would require either switches or a plug and play but shouldn't be that hard . PS, got a good tax refund 10k |
07-13-2012, 06:08 PM
#120 | |
Beef = Packed Vegetables
Paul Jr
KTM690r 2011 |
