Old 11-18-2011, 06:09 PM   #136
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,372
Featured Product-
Rugged Roads KTM 950/950 Radiator Guard
The radiator on your KTM is extremely exposed. Expensive to replace if damaged by a wayward stone. We have designed a heavy duty aluminium guard - whilst providing increased good air flow - to prevent expensive accidents.
The guard has been designed and Precison laser cut from aluminium in our UK manufacturing plant and precurved to be a direct fit.
Color - Matt Black
This item fits the following models:
- KTM 950 Adventure
- KTM 950 Adventure S
- KTM 990 Adventure
- KTM 990 Adventure S
- KTM 990 Adventure R
$129.95
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed screwed with this post 11-25-2011 at 10:21 AM
NeedForSpeed is online now   Reply With Quote
Old 11-19-2011, 08:05 AM   #137
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
A tried and tested favourite, this British made sleeping bag combines micro pack size with serious performance.
The Softie 6 Kestrel, the backbone of the British Royal Marines offensive in the gulf, no other private purchased sleeping bag was as widely used in this conflict. Because of the excessive heat during the day and the heavy conflicts occuring they required a sleeping bag that was extremely lightweight and a compact pack size but with the ability to handle the sub zero temperatures of the desert nights.
$209.50
CobraHeat LLC
(801) 663-7436
Old 11-21-2011, 05:46 AM   #138
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product- Snugpak Microbacterial Towel
Quick drying and bacteria resistant, our travel towel packs to the fraction of the size of your traditional bath towel, with quick drying action and superior absorbency power. A travel essential everybody should pack, whether be a weekend hiker explorer or a career military member on deployment. The Snugpak® MicroFibre Antibacterial Travel Towel is Dr. Bacty® Antibacterial treated. Easy care, machine washable. It also comes with a dual pouch stuff sack, for drying and storage when wet.
Available Colors: Olive or Coyote
Dimensions: 36" x 48"
$32.00
CobraHeat LLC
(801) 663-7436
Old 11-22-2011, 05:29 AM   #139
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
The PAK-Meister Expedition Series 36L aluminum panniers have a lift-off lid with a wide, square shape that makes packing and unpacking a cinch. The high ground clearance of the boxes means you won't risk touching down a corner during fast riding or bottoming out the boxes going through deep sand or ruts. Loop handles on the lids are ideal for lashing down a dry bag or other supplies. Adventurers also love the additional space of the 9 wide square panniers.
36 liters = (18L x 9W x 15H in)
2 Steel latches
4 top loops for fastening additional luggage or straps
Removable lid with quick top access
Opens even with luggage rolls on top
Dimensions: 18L x 9W x 15H
Weight: 9 lbs. ea
Sold in Pairs
*Mounting hardware NOT included
$375.00
CobraHeat LLC
(801) 663-7436
Old 11-25-2011, 03:34 AM   #140
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product-
Pak-Meister 41L Aluminum Panniers. Our Premium cases.
These cases are handmade made from 6061 aluminum with 2mm sidewalls and a 3mm lid/bottom for extra strength. The large volume (41L) panniers have protective corners and tie down points for top bags making them ideally suited for your travels- around the block or around the world.
Size- 45x27x43cm ea.
Net Wt.- 6.4kg
* Sold in Pairs
* Does NOT include mounting hardware
$699.00
CobraHeat LLC
(801) 663-7436
Old 11-26-2011, 09:01 AM   #141
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product-
The Kit Monster is now available in a 65 Liter version as well as the tried and trued 120 Liter version. Some refer to the Kit Monster as a carryall. It has a variety of handles and loops which allow the bag to be carried as a hold all, it can be worn on the back as a rucksack when you use the shoulder straps, or just a simple duffle type style gear bag. One unique feature of the Kit Monster that sets it apart from standard duffle type style bags is it is equipped with compression straps that allow the excess volume to be reduced, which in turns reduces the bulk of the bag. The Kit Monster also has grab handles on each end. This is great for those extremely heavy loads when you need a buddy to help you lift it into the helo or onto the boat. Also the grab handles on each end can also be used in conjunction with a carabiner to secure the Kit Monster to prevent it form moving around. A couple of other features are the heavy duty base and chunky zipper.
Available Colors: Black
Features
  • Carry straps can be used as shoulder straps for heavier loads.
  • Cinch / compression straps on all four sides to to reduce excess volume, which reduces the bulk of the bag.
  • Curved zipper design to easily allow larger objects to be inserted and removed unlike conventional stright zippers.
Specifications
  • Dimensions: 23"L x 15"H x 15"W
  • Volume: 3966 Cubic Inches
  • Weight: 46oz / 1.3kg
$55.50
CobraHeat LLC
(801) 663-7436
Old 11-27-2011, 02:59 AM   #142
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product-
Rugged Raods Hella Micro DE Light Guards
Hella Micro DE lights are great on your bike. We absolutely love them and have them fitted on all of our bikes. After a couple of spills and having to replace them, we decided to design and manufacture some guards for these lights. Price is for a set of 2.
The Hella Micro De Light Guards are designed by Rugged Roads and made in Britain from coated aluminium.
Colour - Matt Silver
These light guards are suitable for use with the standard Hella Micro DE Fog and Driving Lights - but NOT the xenon versions as they have a larger external casing.
They will fit on any light mounting bar.
Fitting is easy as you just slot the lights into them and attach to your light bar with the fittings that came with the light.
Fits all models of bike.
$90.00
CobraHeat LLC
(801) 663-7436
Old 11-28-2011, 04:57 AM   #143
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product-
Snugpak Fleece Bag Liner
The traditional extreme temperature liner, made from a lush polyester fleece. The Fleece Liner adds over a season to your sleeping bag. It comes with its own compression stuff sack to allow it to fit nicely into day packs or small storage spaces to be readily available.
Color: Black with side zipper
$81.75
Weight::33 Oz
936 Grams
Pack Size::12 in
30 x 18 cm
CobraHeat LLC
(801) 663-7436
Old 11-30-2011, 06:13 AM   #144
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product- Snugpak Pile Shirt
Our version of the traditional Pile Shirt with thick pile for greater warmth and our innovative high wicking Paratex outer. Side venting zips and ample front map pocket, thumb loops and smock style zip. Designed to be worn next to the skin to draw perspiration directly from the source. (If it is intended to be worn over other clothing, please up the size and for best performance wear synthetic base layers.) Supplied with its own stuff sack.
Colours available:
Technical Information
Sizes & Weights:
Small: 32-38", 850 grams
Medium: 38-42", 900 grams
Large: 42-46", 950 grams
XL: 46-50", 1000 grams
XXL
: 50"+, 1050 grams
*Snugpak jackets fit larger than standard
Shape / Style:Base Layer Pile Shirt
Temp Rating:
Comfort: -5°c
Temp Rating:
Extreme: -10°c
Fabric:
Lining:
Thick Pile
$225.00
CobraHeat LLC
(801) 663-7436
Old 12-01-2011, 06:28 AM   #145
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Stocking Stuffer-
Rugged Roads 1150GS Wind Deflectors
BMW R1150GS & R1150GSA - Wind Deflectors - Set of 2 We've been testing a set of these for about 5,000 miles so far with great results - much less buffeting around the arms and shoulders. The price is for a set of 2 (left and right) and includes all fittings. The wind deflectors are made here in the UK from 4mm clear polycarbonate, and the fixing holes are pre-drilled. All fixings are included.
The wind deflectors fits the following models: - BMW R1150GS. - BMW R1150GSA.
$79.50
CobraHeat LLC
(801) 663-7436
Old 12-02-2011, 04:59 AM   #146
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Stocking Stuffer- Wolfman Enduro Tank Bag
The Enduro Tank Bag
Finally a Tank Bag for Dual Sport and Dirt bikes. The Enduro Tank Bag will fit virtually all dual sport and Dirt bikes, From the Suzuki DR650,DRZ400, to the XR 650L and the KTM525E/XC, and most bikes in between. A very stable three point mounting systems keeps the bag from shifting on the most demanding rides. The innovative design allows the bag to sit on the tank and not interfere with the gas cap or the vent hose.
A first for the dual/dirt bikes. Finally a place to put the things you need on all rides.
Features are:
• Laminated foam sides, bottom, and rear.
• Tough tek bottom, Reflective webbing on sides.
• Inside mesh pocket.
• Outside mesh pocket.
• Removable map pocket.
• Key Clip
Color: black
Dimensions:
•Length: 9"
•Width: 5 1/2"
•Height: Front-7 3/8"
•Rear- 3 1/2"
Capacity:
6 Liters, 366 cu.in.
$79.99
CobraHeat LLC
(801) 663-7436
Old 12-02-2011, 05:26 AM   #147
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Stocking Stuffer-
WarmSeats Waterproof Seat Heaters
Carbon Fiber Heating Systems can be installed in a minimal amount of time with readily available tools. It combines the advantages of modern carbon-technology and electronic control in one easy to install DIY package. Illuminated on-off switch Dual-Temp High/Low settings. Heats up quickly Fits most types of Cars, Trucks, and SUV's
Pad size 11" x 22" each can be trimmed to fit.
Easy DIY installation 3 year / 36,000 Mile Limited Warranty
$85.00 per seat
CobraHeat LLC
(801) 663-7436
Old 12-04-2011, 06:18 AM   #148
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Stocking Stuffer-
EZ-PULL
Outdoor Enthusiasts
Hunting
Camping
Hiking
Overland Travel
ATV Riding
Dual Sport/Adventure Motorcyle Riding
Farm/Garage Use
Emergency Situations /Survival
(A Must have for your Bug Out Bag)
500 lb. capacity with a 5:1 reduction ratio
48 feet of Spectra cord gives 9 feet of travel
$89.00
CobraHeat LLC
(801) 663-7436
Old 12-05-2011, 04:12 AM   #149
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product-
Snugpak Sleeka Original
Sleeka Original - "nicknamed Softie". The original mid layer insulated garment. There have been many emulations, but only ever one filled with Snugpak's own Softie insulation. Tried and tested in every conflict since the Falklands War (and never beaten). Paratex Light outer shell for higher performance, moisture wicking and breathability.
Colours available:
Sizes & Weights:
Small: 32-38", 650 grams
Medium: 38-42", 700 grams
Large: 42-46", 750 grams
XL: 46-50", 800 grams
XXL
: 50"+, 850 grams
Shape / Style:Mid Layer Insulated Jacket
Temp Rating:
Comfort: -5°c
Temp Rating:
Extreme: -10°c
Fabric:
Lining:
$189.50
CobraHeat LLC
(801) 663-7436
Old 12-06-2011, 04:22 AM   #150
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,372
Featured Product- Snugpak Stratosphere
A WATERPROOF / BREATHABLE ONE PERSON BIVVI SHELTER includes lightweight aluminum poles to create a self supporting canopy around the head and shoulders which allows increased breathability and movement while giving protection from the elements. Great for lightweight backpacking and survival situations. Fully Zipped with Roll Away Mosquito Net in front of the hood and meshed ventilation section at the back.
MUCH SMALLER then a standard tent but with all the features, supplied with seven steel
anchor pegs which includes a spare and packs into its own compression sack.
Features
  • Seams are waterproof and taped
  • Ultra compact 1 person shelter
  • Stands up to severe weather
  • Makes sure you stay dry
  • Small pack size
Specifications
  • Zip; Full Length side Zip
  • Fabric – Top; 40D Nylon Ripstop, Waterproof and Moisture Permeable
  • Fabric – Bottom; 70D Nylon Taffeta with PU Coating
  • Poles; Aluminum with Screw Lock Tips
  • Dimensions: 90” x 37” x 42”
  • Weight: 46oz (Including Poles, Pegs and Compression Sack)
$169.15
CobraHeat LLC
(801) 663-7436
Times are GMT -7.   It's 04:04 PM.
