Old 12-24-2011, 02:18 AM   #166
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,404
We all know that you can never have enough lighting and that many of you like to fit additional lights to your bikes. We have designed and manufactured this ergonomic light bar, making it easy for you to fit auxiliary lights.
The light bar has been designed and manufactured in the UK from laser cut, aluminium, and finished in matt black.
All fittings are included.
Due to the different locations of the front indicators between the F650GS and F800GS we suggest the following;
- For the F650GS we would suggest that you mount your auxiliary lights underneath the lightbar.
- For the F800GS we would suggest that you mount your auxiliary lights above the lightbar.
Fits the following models:
- F800GS - All Models
- F650GS Twin - All Models
$79.00
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 12-24-2011, 06:53 AM   #167
Kainic
Almost there
Kainic's Avatar
Oddometer: 386
I assume the lightbar doesn't fit the f650gs single?
Kainic is offline   Reply With Quote
Old 12-25-2011, 09:03 AM   #168
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
KAOKO Cruise Control for the BMW F650GS/F800GS 2008+ with OEM handguards
Part Number KAO.CCF900
Kaoko Cruise Controls are purpose-built for a variety of motorcycles over 600cc. They consist of a friction nut that is integral with a replacement handlebar-end weight. To install, just remove the right hand bar weight, replace it with Kaoko's bar weight, and firmly tighten the central retaining screw. Features Greatly reduces rider fatigue and strain on hand and wrist While cruising, rider is able to remove hand from throttle grip, throttle opening will remain as set Very simple to operate, even with heavy winter gloves High quality, compact and durable design, super smooth action Takes less than 5 minutes to fit Very little maintenance is required Less wear and tear on throttle cables and linkages Can result in reduced fuel consumption Fits: BMW F650GS, '08- BMW F800GS, '08- Kit does NOT include a replacement left-side bar end weight. Kaoko Safety Warning: The Kaoko Cruise Control is an aftermarket accessory. Any misunderstood, abused or incorrectly installed motorcycle accessory is a safety hazard that could cause injury or death. Its the riders responsibility to understand the operation and purpose for which the Kaoko Cruise Control is designed, namely, for cruising, only when safe to do so. At all other times the control should be disengaged. The Kaoko Cruise Controls are to be used only by experienced and responsible riders.
$120.00
CobraHeat LLC
(801) 663-7436
Old 12-26-2011, 04:21 AM   #169
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Rugged Roads Oil Cooler Guard-
Oil Cooler Guard - Silver With GS Logo - R1200GS Wherever you are - riding to work or on the trip of a lifetime - the last thing you need is a hole in your oil cooler from a stray stone or passing debris. Fit one of our heavy duty oil cooler guards to give you protection from whatever the terrain throws at you! For that added professional finish the GS logo is laser cut into the guard The Oil Cooler Guard is made in Britain from BS1470 5251-H22 Aluminium. Color - Matt Silver Items Included For Fitting: - 2 x 5mm Zip Ties 300mm Long Fits all R1200GS models from 2004 onwards.
$60.00
CobraHeat LLC
(801) 663-7436
Old 12-27-2011, 11:59 AM   #170
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Antarctica RE
Description
As the name suggests the Antarctica RE is our most extreme performance bag, using a combination of highly water repellent Isodry fibres teamed with a luxurious layer of Softie® next to the skin. The performance of this bag is further enhanced with the addition of Reflectatherm which adds to the overall performance of the bag. A quick release centre zip enables a speedy exit should the need arise.
Features:
  • Quick Release Central Zip
  • Neck Baffle
  • Reflectatherm
  • Extreme Temperature Rating
Colours available:
Technical Information
Zip Style:
Full Length Centre Zip
Shape:
Mummy
Temp Rating:
Comfort: -20°c
Temp Rating:
Extreme: -50°c
Weight:2800g (inc. compression stuff sack)
Packsize
(Fully Compressed):
30x25cm ('How to' Guide)
Packsize (Uncompressed)
Length:220cm
Width (Chest):165cm
Width (Foot):
Outer Fabric:
Inner Fabric:
Filling:
Activity: Expedition
Season:
Extreme -10
Origin: UK Made
Weight Category: 1.5kg +
$359.00
CobraHeat LLC
(801) 663-7436
Old 12-28-2011, 05:06 AM   #171
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Fat Foot
We are the original designers and manufacturers of the celebrated FAT FOOT. Stainless steel baseplate with integrated studs so no bolt heads to get ground off during usage - get the original – still the best and most rugged FAT FOOT on the market. Ever get worried about parking your BMW on its side stand on soft ground? If so spread the load with this Fat Foot. Designed to spread the load of your bike and stop it sinking. It will also stop it leaning over quite so far. The Fat Foot is made at our factory in the UK to the highest specification of both durability and looks. The Fat Foot is built as follows: - Stainless steel base plate with permanently affixed studs for easier fitting. - 1 x Aluminium Foot Locating Plate. - Stianless steel top plate. Includes all required fixings.
Color- Silver
$29.95
CobraHeat LLC
(801) 663-7436
Old 12-29-2011, 04:32 AM   #172
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
The Bunker™ by Snugpak® is a new and exciting addition for Snugpak®. The Bunker™ is built and designed for long term hard use. With its 5000mm PU Coated Fly it can handle large amounts of rain as well as surpasses many other tent manufacturers with a much less superior fabric. The Bunker™ has two doors and two vents as well as all types of extras like internal mesh pockets, No-See-Um-Mesh, all seams are seam taped and much much more. The Bunker™ is a Fly First pitch type tent, which allows the users to quickly set up the fly and seek shelter from the elements.
Features
•Interior Mesh Pockets (6 Total - 3 on each side) •2 Doors •2 Vents •Fire Retardant •All seams are taped sealed •Bathtub floor •Alloy Stakes (17 + 2 Spare Stakes) •Available in Olive Outer with Black Inner only (As pictured above) •Comes with a Repair Kit to allow for repairs while on the move if needed
Specifications
•Flysheet is a lightweight 210t Polyester RipStop with a 5000mm waterproof polyurethane coating • •Inner Tent constructed of 190t Nylon with Polyester Mesh •50D Polyester No-See-Um-Mesh •DAC® Featherlite NSL® anodized poles with pressfit connectors •All DAC® Poles are made from TH72M aluminum •Trail Weight: 6.75 lbs (Fly, Inner Tent & Poles) •Pack Weight: 7.74 lbs (Fly, Inner Tent, Poles, Stakes, Repair Kit & Carry Case)
$322.00
CobraHeat LLC
(801) 663-7436
Old 12-30-2011, 04:48 AM   #173
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
PAK-MEISTER Expedition Series Panniers
No Frills, High Quality, Git-R-Done Aluminum Panniers
The PAK-Meister Expedition Series 36L aluminum panniers have a lift-off lid with a wide, square shape that makes packing and unpacking a cinch. The high ground clearance of the boxes means you won't risk touching down a corner during fast riding or bottoming out the boxes going through deep sand or ruts. Loop handles on the lids are ideal for lashing down a dry bag or other supplies. Adventurers also love the additional space of the 9 wide square panniers.
36 liters = (18L x 9W x 15H in)
2 Steel latches
4 top loops for fastening additional luggage or straps
Removable lid with quick top access
Opens even with luggage rolls on top
Dimensions: 18L x 9W x 15H
Weight: 9 lbs. ea
Sold in Pairs
*Mounting hardware NOT included
$375.00
CobraHeat LLC
(801) 663-7436
Old 12-31-2011, 04:35 AM   #174
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
CobraHeat LLC
(801) 663-7436
NeedForSpeed screwed with this post 01-06-2012 at 03:47 AM
Old 01-06-2012, 03:53 AM   #175
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
The Ridgeline Plus Duffel is a versatile tail bag and travel duffel – in an ideal "weekender" size. The durable all Ballistics nylon construction and weather-resistant design help keep your contents dry. Use the carry handle, stow the bungee-and-hook mounts into their storage pocket, and quickly convert the Ridgeline Plus into a great travel duffel.
Features:
• Convenient top-loading – like an ice chest.
• Reflective webbing accents for nighttime safety.
• Universal adjustable bungee-and-hook mounting.
• Two outside crescent pockets on each end. Great for quick access items.
• Outside compression straps stabilize the load, and hold more gear.
• Tough-Tek non-skid/non-scratch bottom
• Interior mesh pocket under the top.
• Expandable "Wedge" gusset.
• Heavy Duty #10 and #8 Ykk Zippers.
• All seams are reinforced and bound.
• Carry Handle.
Color: Black
Dimensions:
Length: 11" / 28cm
Width: Main Body: 18" / 45cm , Overall with pockets: 24" / 60cm
Height: 10.5" / 26.5cm
Expanded: 14.5" / 37cm
Capacity:
Main Compartment: 2029 cu.in. / 33 liters
Expanded: 2425 cu.in. / 39.5 liters
Side Pockets Each: 91 cu.in. / 1.5 liters
Total: 2593 cu.in. / 42.5 liters
$139.99
CobraHeat LLC
(801) 663-7436
Old 01-11-2012, 03:32 AM   #176
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
BMW F800GS & F650GS Twin Auxiliary Light Mounting Bar.
$79.00
KAOKO R1200GS R1200GSADV with or without OEM handguards
Part Number KAO.CCF400-08
Kaoko Cruise Controls are purpose-built for a variety of motorcycles over 600cc. They consist of a friction nut that is integral with a replacement handlebar-end weight. Fits all model years, including those with 80mm or 90mm bar-end weight retaining screws. Supercedes discontinued part CCF400. To install, just remove the right hand bar weight, replace it with Kaoko's bar weight, and firmly tighten the central retaining screw. Features • Greatly reduces rider fatigue and strain on hand and wrist • While cruising, rider is able to remove hand from throttle grip, throttle opening will remain as set • Very simple to operate, even with heavy winter gloves • High quality, compact and durable design, super smooth action • Takes less than 5 minutes to fit • Very little maintenance is required • Less wear and tear on throttle cables and linkages • Can result in reduced fuel consumption Fits: BMW R1200GS, '04-'07 & '08- with or without BMW Handguards BMW R1200GS with Touratech Handguards, '08- BMW R1200GS Adventure, '06-'07 & '08- with or without BMW Handguards Kit does NOT include a replacement left-side bar end weight. Kaoko™ Safety Warning: The Kaoko™ Cruise Control is an aftermarket accessory. Any misunderstood, abused or incorrectly installed motorcycle accessory is a safety hazard that could cause injury or death. It’s the rider’s responsibility to understand the operation and purpose for which the Kaoko™ Cruise Control is designed, namely, for cruising, only when safe to do so. At all other times the control should be disengaged. The Kaoko™ Cruise Controls are to be used only by experienced and responsible riders.
$125.00
CobraHeat LLC
(801) 663-7436
Old 01-12-2012, 03:49 AM   #177
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Snugpak Stamina 40-
The perfect size for the passenger seat/rack of your GS or other bike
The 4 side compression straps will hold the bag on your bike and it has a built in rain cover in the bottom compartment.
The Stamina 40™ is a streamlined, multi-purpose, single chamber 2440 Cu. In. / 40 litre backpack. The superb back panel system consists of a heavily padded air permeable system for comfort and outstanding back protection. It also has contoured and heavily padded chest straps faced with textured high wicking fabrics. There is a zipper compartment on the top and bottom. The top zippered compartment is a great place to store those essentials that need to be easily accessed. The bottom compartment also houses a roll away waterproof cover. The Stamina is a great in-between backpack for those that cant make up their mind up on either the Sleeka Force 35 or the Rocket Pak.
Specifications
  • Main Compartment: 2440 Cubic Inches / 40 Liters
  • Weight: 51 oz
  • Dimensions: Main (19”H x 11”W x 9”)
  • Olive, Black, Coyote
$126.95
CobraHeat LLC
(801) 663-7436
Old 01-14-2012, 05:24 AM   #178
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
One of our best sellers...
BMW R1150GS & R1150GSA - Wind Deflectors - Set of 2 We've been testing a set of these for about 5,000 miles so far with great results - much less buffeting around the arms and shoulders. The price is for a set of 2 (left and right) and includes all fittings. The wind deflectors are made here in the UK from 4mm clear polycarbonate, and the fixing holes are pre-drilled. All fixings are included. The wind deflectors fits the following models: - BMW R1150GS. - BMW R1150GSA.
$79.95
CobraHeat LLC
(801) 663-7436
Old 01-22-2012, 10:29 AM   #179
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Fully reversible version of the Sleeka Original, same great Softie insulation, but with the option of Multicam or Tan. Both sides of the jacket are equally well equipped with pockets. Comes supplied with its own stuff sack.
MultiCam® is a single camouflage pattern designed to help the wearer hide in varied environments, seasons, elevations, and light conditions. It was designed to address the real-world need for concealment in different environments, with one basic kit of gear. While there are many great location-specific patterns, MultiCam® is designed to work well across a very broad range of environmental conditions when observed in both the visual and near infrared (night vision) spectrums.
Snugpak has taken their most popular outerwear and offered them in MultiCam®. These models are exactly the same as our standard Snugpak jackets but utilizing the very popular MultiCam® Camouflage Pattern. All Snugpak MultiCam® outerwear utilizes a Nylon outer shell which provides the same outstanding performance as with all standard Snugpak branded outerwear.
All the features of the Original Sleeka, but with the option of reversing the jacket using both MultiCam® & Desert Tan outer shells. Both sides are equally equipped with pockets that are slanted and allow easy access. Supplied with a stuff sack and available in sizes Small through XX-Large. Temp Rating: Comfort 23°F/Low 14° (-5°C/-10°C)
Sizes & Weights:
Small: 32-38", 650 grams
Medium: 38-42", 700 grams
Large: 42-46", 750 grams
XL: 46-50", 800 grams
XXL
: 50"+, 850 grams
*Snugpak jackets fit larger than standard
Shape / Style:Mid Layer Insulated Jacket
Temp Rating:
Comfort: -5°c
Temp Rating:
Extreme: -10°c
Fabric:
Lining:
$249.00
CobraHeat LLC
(801) 663-7436
Old 01-31-2012, 04:37 PM   #180
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,404
Coming Soon!
Re-Designed 2012 KTM 950/950 Skid Plate
Want some heavy duty protection for the underside of your bike?
You cannot get better than the new KTM Skid Plate.
Designed and manufactured in the UK from 4mm aluminium and powdercoated with a special HD aluminium powder for durability.
Color - Silver with Silver sacrificial plate
We have also included stainless Steel brackets for ease of fixing the bashplate to your bike utilising the existing mounting points.
Also the bashplate comes supplied with an additional 2mm aluminium sacrificial plate designed to take any serious impact and leave the bashplate intact.
This items fits the following models:
- KTM 990 Adventure R
- KTM 990 Adventure and 990 Adventure S
- KTM 950 Adventure and 950 Adventure S
CobraHeat LLC
(801) 663-7436
Times are GMT -7.   It's 10:07 AM.
