Old 01-31-2012, 08:40 PM   #181
NaDSoB
Another asshole on a KLR
NaDSoB's Avatar
Oddometer: 363
Question pannier advice?
I'm picking up a Triumph Tiger XC this weekend and I think the Pak-Meister Panniers would look great on the new bike! Question is, which size, 29, 41, or one of each? And which rack and mounting system would you recommend for durability and ease of pannier removal? I'm new to hard cases and mounting racks, so have no frame of reference, and would really appreciate some guidance regarding the hardware and frame.
Thanx!
"Tire tracks and broken hearts, that's all we're leaving behind.
It doesn't matter what we're losing, it only matters what we're going to find!"
Meat Loaf from "A Kiss Is A Terrible Thing To Waste", Lyrics by Jim Steinman
NaDSoB is offline   Reply With Quote
Old 02-01-2012, 03:45 AM   #182
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 949
29 or 41 is up to you regarding how much space you need.
We do not sell racks or mounting hardware, the thought is that our panniers are universal fit with a mounting puck kit- and I recommend happy trails puck kit for the quality/price. I have the BMW OEM racks on my 1200ADV and run a 29/41 combo because of the exhaust cutout. But, I regularly throw on the Milspec panniers when I know I am going to be heading into the woods...
Assuming the Tiger XC OEM or aftermarket racks are symetrical- the 29 or 41 will both work well and look good.
We sold a set to a guy with the same bike- let me see if he ever sent a pic of them mounted up
Thanks,
Mike
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
NeedForSpeed is offline   Reply With Quote
Old 02-01-2012, 05:38 AM   #183
NaDSoB
NaDSoB's Avatar
Oddometer: 363
Question
Thanks,
Mike
Thanks, Mike,
Would it be possible to ask your customer which mounting racks he used, and if he's pleased with them?
Rob
Old 02-02-2012, 04:39 AM   #184
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
The Skid Plates will be available Feb 15
Coming Soon!
Re-Designed 2012 KTM 950/950 Skid Plate
Want some heavy duty protection for the underside of your bike?
You cannot get better than the new KTM Skid Plate.
Designed and manufactured in the UK from 4mm aluminium and powdercoated with a special HD aluminium powder for durability.
Color - Silver with Silver sacrificial plate
We have also included stainless Steel brackets for ease of fixing the bashplate to your bike utilising the existing mounting points.
Also the bashplate comes supplied with an additional 2mm aluminium sacrificial plate designed to take any serious impact and leave the bashplate intact.
This items fits the following models:
- KTM 990 Adventure R
- KTM 990 Adventure and 990 Adventure S
- KTM 950 Adventure and 950 Adventure S
[/QUOTE]
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-02-2012, 05:02 AM   #185
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
NDUR Water Filtration Bottle (100gal)
Canteen (100gal)
Survival Straw (50gal)
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-05-2012, 06:27 AM   #186
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
Coming Soon!
NDUR Water Filtration Straw
(50gal filter)
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-08-2012, 04:49 AM   #187
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
We just rec'd the re-designed 1150GS/A Aux Light Bars-
We all know the lights on the BMW R1150GS could be better and that many of you like to fit additional lights to your bikes. We have designed and manufactured this great brushed stainless steel light bar, making it easy for you to fit either 2 or 4 lights
The R1150GS light bar had been designed and manufactured in the UK from 4mm laser cut, brushed stainless steel.
Longer bolts and spacers required for fitting, are included.
Benefits Of The Auxiliary Light Mounting Bar
- Lasercut fixing holes so you can easily attach the cables to the light bar keeping your wiring secure and out of the way.
- The light bar goes left to right under the beak, so you only need one to mount 2 or 4 lights and cuts out any vibration.
- The bar is bolted to the beak by means of the oil cooler bolts.
- Can be mounted in 5 minutes, without disassembling anything on your R1150GS.
Fits the following models:
- R1150GS - All Models
- R1150GSA - All Models
$90.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-10-2012, 03:47 AM   #188
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
We have a 7 sets of the BMW Aux lights guards from a customer order that was canceled.
$85.00 per set shipped
paypal is sales AT cobraheat DOT com
normally $110.00+ S/H
Protect your BMW auxiliary lights with these stylish and robust light guards made from silver anodised aluminium. For a professional finishing touch the Adventure logo is laser cut into the side of the guard. Price is for 2 light guards to fit the R1200GSA. The Auxiliary Light Guards are made in Britain from BS1470 5251-H22 Aluminium. Color- Silver Fits R1200GSA Models from 2004 onwards.
PLEASE NOTE THAT THESE LIGHT GUARDS WILL ONLY FIT ORIGINAL BMW FACTORY FITTED AUXILIARY LIGHTS. THEY WILL NOT FIT ANY OTHER AUXILIARY LIGHT UNITS.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-11-2012, 04:20 AM   #189
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
When travelling light is not an option the Bergen is ideal. As the Rocket Paks bigger brother it has all the same features but the main compartment is a hefty large 4270 Cu. In. / 70 Litre on its own. Also as the Rocket Pak the Bergen too has two removable side pockets ( 915 Cu. In / 15 Liters each) which are compatible and attach to the Snugpak® Yoke System. There are side compression straps to minimize those side pockets if empty. There is a zipper compartment on the top and bottom. The top zippered compartment is a great place to store those essentials that need to be easily accessed. Just like all of our other backpacks the Bergens back panel system is a heavily padded air permeable system for comfort and outstanding back protection. It also has contoured and heavily padded chest straps faced with textured high wicking fabrics. The bottom compartment also houses a roll away waterproof cover.
Specifications
  • Main Compartment: 4270 Cubic Inches / 70 Liters
  • Side Pockets (Each): 915 Cubic Inches / 15 Liters
  • Total Volume: 6100 Cubic Inches / 100 Liters
  • Weight: 88 oz
  • Main Compartment (19 1/8H x 13 1/8W x 9 1/8)
  • Side Pocket (14H x 7 1/8W x 5 1/8)
$203.15
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-11-2012, 06:35 AM   #190
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
Praying to the GPS God's for Forgiveness...
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-13-2012, 03:47 AM   #191
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
Looking for the ultimate Base Camp?
We have it.
Mt. Shasta RTT with Annex Room and screened Awning
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-13-2012, 04:46 PM   #192
ThomasVolomitz
Not so Gnarly
ThomasVolomitz's Avatar
Oddometer: 3,979
More details and price on this one!
Doo Done
ThomasVolomitz is offline   Reply With Quote
Old 02-13-2012, 06:03 PM   #193
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
Mt. Shasta Roof Top Tent
Size: 56"W x 96"L x 50"Ht. (Open)
Size: 56"W x 48"L x 14" Ht. (Closed)
Covered end: 3' overhang
Weight: 115lbs - Will hold up to 650 lbs
Base: Aluminum sheets and insulated foam
Frame: Aluminum
Ladder: Telescoping aluminum ladder (new) 2 sizes available
Fabric: 260g Poly/Cotton Rip Stop Fabric. W/P PU coating, Breathable and Mold Resistant with UV Protection
Rain Fly: 420D Poly/Oxford PU
Mattress: High density foam 2.5" thick
Travel Cover: Heavy duty PVC
The Mt. Shasta Annex room is a nice addition to your Roof Top Tent. It comes with four sides and a removable pvc floor making it easy to clean. It also has an entry door, two windows and a rear entry access making it easy to get in and out of your vehicle with your tent to the side or turned off the back of your vehicle. Simply just zip it on. A great place to store extra gear or when you have those extra kids up at the lake. When open this room is approx 7'x7' at the bottom. Travel bag included.
Mt.Shasta with Annex Room $1,295.00
Awnings- 3 Sizes: 55" 79" 84"
The Awning will attach to any roof rack system. This awning is versatile and is easy to setup. Gives you added comfort by sheltering you from the sun and/or rain. And allows the added benefit of attaching one of our mosquito mesh rooms (optional) for that evening dinner away from the pests. When retracted the awning is stored in a pvc cover.
$250 55"
$275 79"
$300 104"
Mesh Screen Room
This SUV screen room is enclosed on four sides (no floor) Maximum wall height is about 7 feet. Zippered door. Netting keeps bugs out of your way while you enjoy the sunset and dinner.
$175.00
other sizes/shapes on our website.
We will have this set up at the MOA Rally along with all our gear!
thanks,
Mike
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-14-2012, 03:53 AM   #194
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
This Jungle Hammock with Mosquito Net is great for those who dont want to carry a tent but want protection from insects. This Jungle Hammock comes with Mosquito Netting built right into the overall product. Its great for those looking for a simple solution when out in about in the woods or jungles. The Jungle Hammock comes with 4 pieces of 10 long guy ropes as well as a Suspension Attachment System. Comes with two steel carabiners for attaching to the Suspension Attachment System.
Measures 9 long by 48 wide.
Available in Olive only.
Weight 20oz.
Weight Capacity 400lbs
$59.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 02-15-2012, 04:18 AM   #195
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 949
KTM Rear Rack
Sculpted to follow the concise lines of the KTM our rear rack offers a much larger area with multiple securing points. Designed and manufactured in the UK from 3mm aluminium. Color- Black No additional fittings are required as the rack utilises existing fittings and mounting points. This item fits the following models: KTM 950 Adventure KTM 950 Adventure S KTM 990 Adventure KTM 990 Adventure S KTM 990 Adventure R Shipping weight 0.78 kg
$90.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Times are GMT -7.   It's 02:54 PM.
