Old 02-16-2012, 03:31 AM   #196
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,386
The Trekker Mat by MultiMat is quickly becoming the choice of many Military personnel. The Unique design and color combination sets the Trekker apart from the competition and the choice of Military Professionals. Self-Inflating Mats not only provide a little extra comfort sleeping on top of rocks and other hard surfaces but also help to add a barrier between you and the cold ground beneath.
The Trekker Mat is reversible with Olive on one side and Coyote on the opposite site.
Note: The pack size is determined when mat is mid-folded and then rolled.
Features
  • Super-fast valve giving 3x airflow of a regular valve for fast inflation/deflation
  • Mats supplied with microfibre-lined stuff sack/pillow case, retaining band & repair kit
  • Tough 150D Polyester top & bottom layer
  • TPU membrane for air-tight seal
  • Quality, lightweight, 20kg/m3 PU foam core for lasting performance and full inflation
Legnth::72 in
1830 cm
Weight::31 Oz
855 Grams
Width::20 in
510 cm
Pack Size::10.75 in
270 x 150 cm
$58.50
The Multimat Pillow is a must have for any outdoor enthusiast and/or military personnel as it is extremely compact and lightweight. It will self-inflate to 4.25 when it fully inflates. You can also use the valve to add air or let air out as well to get the pillow to exactly the desired softness or firmness you prefer.
Available in Olive only
Features
  • Ultra-Lightweight Self-Inflating Pillow
  • 20D Polyester Fabric
$25.00
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 02-17-2012, 04:05 AM   #197
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
Snugpak Microfiber Antibacterial Towel
Quick drying and bacteria resistant, our travel towel packs to the fraction of the size of your traditional bath towel, with quick drying action and superior absorbency power. A travel essential everybody should pack, whether be a weekend hiker explorer or a career military member on deployment. The Snugpak® MicroFibre Antibacterial Travel Towel is Dr. Bacty® Antibacterial treated. Easy care, machine washable. It also comes with a dual pouch stuff sack, for drying and storage when wet.
Available Colors: Olive or Coyote
36" x 48"
$32.00
CobraHeat LLC
(801) 663-7436
Old 02-18-2012, 03:27 AM   #198
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
We're off to the dealer Expo today!
CobraHeat LLC
(801) 663-7436
Old 02-23-2012, 04:13 AM   #199
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
The Kit Monster is now available in a 65 Liter version as well as the tried and trued 120 Liter version. Some refer to the Kit Monster as a carryall. It has a variety of handles and loops which allow the bag to be carried as a hold all, it can be worn on the back as a rucksack when you use the shoulder straps, or just a simple duffle type style gear bag. One unique feature of the Kit Monster that sets it apart from standard duffle type style bags is it is equipped with compression straps that allow the excess volume to be reduced, which in turns reduces the bulk of the bag. The Kit Monster also has grab handles on each end. This is great for those extremely heavy loads when you need a buddy to help you lift it into the helo or onto the boat. Also the grab handles on each end can also be used in conjunction with a carabiner to secure the Kit Monster to prevent it form moving around. A couple of other features are the heavy duty base and chunky zipper.
Available Colors: Black
Features
  • Carry straps can be used as shoulder straps for heavier loads.
  • Cinch / compression straps on all four sides to to reduce excess volume, which reduces the bulk of the bag.
  • Curved zipper design to easily allow larger objects to be inserted and removed unlike conventional stright zippers.
Specifications
  • Dimensions: 23"L x 15"H x 15"W
  • Volume: 3966 Cubic Inches
  • Weight: 46oz / 1.3kg
$55.50
CobraHeat LLC
(801) 663-7436
Old 02-23-2012, 06:40 AM   #200
1 lunger
1 lunger's Avatar
Oddometer: 1,267
Interested in a front fender pack. Do you carry these? Thanks! BTW, looks like you guys have some bad ass products!! Bump!
I am here: http://maps.google.com/maps?ll=41.877075,-72.751134
Life is good!
1 lunger is online now   Reply With Quote
Old 02-23-2012, 07:18 AM   #201
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
Don't have anything right now-
We will have some top of line things shortly ( few weeks)
I'll post it with an announcment
thx
CobraHeat LLC
(801) 663-7436
Old 02-24-2012, 03:41 AM   #202
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
The Warrior Survival Saw is an excellent tool. Easy to pack away, lightweight & heavy duty Hand Chain Saw, ideal for cutting firewood in survival situations as well as for campers, backpackers, fishermen, hikers, homeowners or survivalists. A superb hand operated pocket sized survival chainsaw made from riveted sections of bi-directional chain-saw style cutting teeth. Extended longevity comparable to a traditional bow saw. Will cut anything from a thin branch to a large trunk and can be thrown over high branches for cutting above head height. Black nylon lanyard loop handles.
$18.00
CobraHeat LLC
(801) 663-7436
Old 02-25-2012, 05:10 AM   #203
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
BMW F800GS & F650GS Twin - Rear Rack - Black Want to carry a bit more on the back of your bike without having to use a topbox? Great for holding larger items such as tents. Because of the height of the rack extension even wide items can be fixed on as they will sit above your panniers. Designed dith lots of strap fixing points so you can carry just about anythiing on your rack. We think the F800GS is beautifully shaped and have followed the lines of the rear panels so your rack - as well as being functional looks fantastic when fitted on your bike. Manufactured in the UK. Material - Aluminium Color-Black Fittings: The rack comes with all fittings required. This item fits: - R800GS - F650GS Twin
$99.95
CobraHeat LLC
(801) 663-7436
Old 02-26-2012, 04:47 AM   #204
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
The CVT Awning will attach to any roof rack system. This awning is versatile and is easy to setup. Gives you added comfort by sheltering you from the sun and/or rain. And allows the added benefit of attaching one of our mosquito mesh rooms (optional) for that evening dinner away from the pests.
When retracted the awning is stored in a pvc cover.
104" Awning $325.00
79" Awning $275.00
55" Awning $250.00
Optional Mesh rooms (mosquito) $175.00
CobraHeat LLC
(801) 663-7436
Old 02-27-2012, 04:05 AM   #205
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
BMW R1150GS & R1150GSA - Wind Deflectors - The wind deflectors are made from 4mm clear polycarbonate, and the fixing holes are pre-drilled. All fixings are included. The wind deflectors fits the following models:
BMW R1150GS. - BMW R1150GSA.
$79.95
CobraHeat LLC
(801) 663-7436
Old 02-28-2012, 03:29 AM   #206
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
KTM 950/990 Rear Rack
Sculpted to follow the concise lines of the KTM our rear rack offers a much larger area with multiple securing points. Designed and manufactured in the UK from 3mm aluminium. Color- Black No additional fittings are required as the rack utilises existing fittings and mounting points. This item fits the following models: KTM 950 Adventure KTM 950 Adventure S KTM 990 Adventure KTM 990 Adventure S KTM 990 Adventure R Shipping weight 0.78 kg
$90.00
CobraHeat LLC
(801) 663-7436
Old 02-29-2012, 04:00 AM   #207
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
The Snugpak Patrol Poncho is a simple over the head, waterproof, smock style piece of useful kit that everyone should have. Designed to be worn over the user as well as the users backpack, if one is being utilized, to help keep you and your gear dry in a down pour. Its generously cut design can allow one to use as an emergency Bivvi if needed. We have gone above the old standard design of what most people think about when thinking of a poncho, we have included an adjustable hood and thumb loops in our design. Located on the chest is a Velcro map pocket with storm flap. Made out of Snugpak’s exclusive Paratex Dry material and with fully taped seams which allows the shell to be 100% waterproof. Perfect to throw in your luggage and forget it.
Black or OD
$59.00
CobraHeat LLC
(801) 663-7436
Old 02-29-2012, 08:50 AM   #208
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,396
Originally Posted by NeedForSpeed View Post
Thanks for the plug ChiefPilot.
4,000 inmate pages views- don't be shy- if you have a question about one of the products let me know...
Our NEW 29L Panniers are in stock!
What's the total width of these installed on the GS and do you powder coat the interior?
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is online now   Reply With Quote
Old 02-29-2012, 10:53 AM   #209
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,386
Depends on your rack.
The panniers are each 8" wide and they are annodized not pc
we're dealing on the panniers....
CobraHeat LLC
(801) 663-7436
Old 02-29-2012, 04:10 PM   #210
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,396
What rack is shown in the pic, and does the price only include the panniers sans any mounting hardware?
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider screwed with this post 02-29-2012 at 04:20 PM
Times are GMT -7.   It's 04:26 PM.
