Old 04-20-2012, 04:28 AM   #241
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 1,348
The Trekker Self-Inflating Pillow by MultiMat is a very versatile item that will self-inflate to a 1.25” Cushion, but can be further inflated with a couple of breathes, to form a pillow. Complete with Velcro joining strip, the hook side of which should be fixed to the top of your sleeping mattress, the self-inflating pillow can be fixed in place for sleeping, or packed for use in a day sack.
Features
  • Lightweight & Compact
  • Weight: 6.5 Ounces
  • Size: 15.75” x 11.75” x 1.25” to 3.75”
  • Tough 75D Polyester
  • Velcro Strip Adapter to attach to Self Inflating Mats
  • Stuff Sack included
Simply open valve and watch it inflate to a cushion or add extra air to make a pillow - Close valve to use.
Easily attaches to our mattress products via Velcro strips.
$25.00
PAK-MEISTER
Motorcycle Adventure Gear
CobraHeat LLC
A VETERAN OWNED AND OPERATED CO.
Nitron Shocks call (801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 04-20-2012, 07:12 AM   #242
ctoldie
ctoldie's Avatar
Oddometer: 230
Expedition Series
I have a 2009 BMW G650GS and wish to purchase your Expedition bags. I have hepco-becker racks. Where would I get a mounting kit to attach these bags? Also, I cannot access your website to purchase these bags. Please help.
Thanks,
John
ctoldie is offline   Reply With Quote
Old 04-20-2012, 07:32 AM   #243
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
I just looked an the website and everything appears ok on my end...
you'll need a mounting puck kit for the racks
pm sent with my cell #
Mike
PAK-MEISTER
CobraHeat LLC
Old 04-21-2012, 04:01 AM   #244
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
HOT NEW ITEM! 1200GSA TANK GUARDS
These guards provide extra protection to the fuel tank in case of a fall. Manufactured with high grade materials and anti-vibration fixings and finished in Silver. They also come in very handy to attach the Kriega US5 Dry Pack bags for additional waterproof storage! (sold seperately) These tank guards will only fit with the OEM Upper Crashbars that are fitted as standard to the Adventure model.
* All BMW R1200GS Adventure models
* Silver
* sold in pairs
$110.00
PAK-MEISTER
CobraHeat LLC
NeedForSpeed screwed with this post 04-21-2012 at 05:27 AM
Old 04-22-2012, 02:33 AM   #245
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
John-
sent you a pm
PAK-MEISTER
CobraHeat LLC
Old 04-23-2012, 04:55 AM   #246
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
The ProForce All Weather Shelter is the most versatile multi-purpose shelter for “ALL WEATHER” conditions protecting you from the sun, wind, rain and snow. Designed by Military Veterans and avid Outdoorsmen. It can be configured and used as a Fly, Pup Tent, Lean-Too Shelter, Emergency Bivvi and the list goes on. With the components and features offered the All Weather Shelter has endless possibilities, only limited by ones imagination. The All Weather Shelter is ideal for those that travel light and move fast.
The All Weather Shelter measures 10’x10’ with grommets on each corner as well as numerous webbing tabs along each side. Also there are 3 webbing tabs across the spine when used as a fly. Also down two opposite side are plastic snaps which can allow it to be folded and snapped together to make an emergency bivvi if desired. Included also are 4 guy ropes with adjusters measuring 10’ in length and 8 ultra lightweight alloy stakes.
Constructed out of 210T Nylon Rip-Stop, PU Coated and is also UV Resistant. All seams are sealed and taped. Reinforced webbing tabs along sides. Available in Olive only.
Retail $79.95
PAK-MEISTER
CobraHeat LLC
Old 04-24-2012, 04:44 AM   #247
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
The radiator on your KTM is extremely exposed. Expensive to replace if damaged by a wayward stone.
We have designed a heavy duty aluminium guard - whilst providing increased good air flow - to prevent expensive accidents.
The guard has been designed and Precison laser cut from aluminium in the UK and precurved to be a direct fit.
Colour - Matt Black
This item fits the following models:
- KTM 950 Adventure
- KTM 950 Adventure S
- KTM 990 Adventure
- KTM 990 Adventure S
- KTM 990 Adventure R
$129.95
PAK-MEISTER
CobraHeat LLC
Old 04-26-2012, 05:53 AM   #248
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Shipping a Scorpion 3 to an inmate today!
The Scorpion 3™ by Snugpak® is a new and exciting addition for Snugpak®. The first thing people will notice about the Scorpion 3™ is its stylish and sleek design. This design helps the Scorpion 3™ to fend off those fierce winds that kick up from time to time and still is built and designed for long term hard use. With it’s 5000mm PU Coated Fly it can handle large amounts of rain keeping you and your gear dry, as it should be. The Scorpion 3™ has one door and three vents as well as all types of extras like internal mesh pockets, No-See-Um-Mesh, all seams are seam taped and much much more. The Scorpion 3™ is a Fly First pitch type tent.
Features
•Interior Mesh Pockets (10 Total - 6 on each side) •1 Door •3 Vents •All seams are taped sealed •Alloy Stakes (18 + 2 Spare Stakes) •Available in Olive Outer with Black Inner only (As pictuered above) •Comes with a Repair Kit to allow for repairs while on the move if needed.
Specifications
•Flysheet is a lightweight 210t Polyester RipStop with a 5000mm waterproof polyurethane coating •Inner Tent constructed of 190t Nylon with Polyester Mesh •50D Polyester No-See-Um-Mesh •DAC® Featherlite NSL® anodized poles with pressfit connectors •All DAC® Poles are made from TH72M aluminum •Trail Weight: 6.44 lbs(Fly, Inner Tent & Poles) •Pack Weight: 7.47 lbs (Fly, Inner Tent, Poles, Stakes, Repair Kit & Carry Case)
$339.00
PAK-MEISTER
CobraHeat LLC
Old 04-27-2012, 03:49 AM   #249
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
BMW F800GS & F650GS Twin - Rear Rack - Black Want to carry a bit more on the back of your bike without having to use a topbox? Great for holding larger items such as tents. Because of the height of the rack extension even wide items can be fixed on as they will sit above your panniers. Designed with lots of strap fixing points so you can carry just about anythiing on your rack. We think the F800GS is beautifully shaped and have followed the lines of the rear panels so your rack - as well as being functional looks fantastic when fitted on your bike.
Manufactured in the UK.
Material - Aluminium
Color-Black
Fittings: The rack comes with all fittings required.
This item fits: - F800GS - F650GS Twin
$99.95
PAK-MEISTER
CobraHeat LLC
Old 04-28-2012, 01:41 PM   #250
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Kaoko Cruise Controls are purpose-built for a variety of motorcycles over 600cc. They consist of a friction nut that is integral with a replacement handlebar-end weight.
Fits all model years, including those with 80mm or 90mm bar-end weight retaining screws.
Supercedes discontinued part CCF400.
To install, just remove the right hand bar weight, replace it with Kaoko's bar weight, and firmly tighten the central retaining screw.
Features
• Greatly reduces rider fatigue and strain on hand and wrist
• While cruising, rider is able to remove hand from throttle grip, throttle opening will remain as set
• Very simple to operate, even with heavy winter gloves
• High quality, compact and durable design, super smooth action
• Takes less than 5 minutes to fit
• Very little maintenance is required
• Less wear and tear on throttle cables and linkages
• Can result in reduced fuel consumption
Fits:
BMW R1200GS, '04-'07 & '08- with or without BMW Handguards
BMW R1200GS with Touratech Handguards
'08- BMW R1200GS Adventure
'06-'07 & '08- with or without BMW Handguards
Kit does NOT include a replacement left-side bar end weight.
$125.00
PAK-MEISTER
CobraHeat LLC
Old 04-29-2012, 06:12 PM   #251
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
First neighborhood ice cream run with the Deuce and had room for 8 more
PAK-MEISTER
CobraHeat LLC
Old 05-01-2012, 04:33 AM   #252
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
1200GSA TANK GUARDS
* Silver
* sold in pairs
$110.00
PAK-MEISTER
CobraHeat LLC
Old 05-02-2012, 04:41 AM   #253
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
We just shipped a Kriega US30 to Aaron in Texas yesterday!
The US-30 uses the latest generation of fitting straps. New for 2011 the US-Hook straps are an extra secure subframe fitting kit which allows tailpack combinations of up to 90-litres. Easy on/off the bike with no loose straps left on the bike. Custom 6061-T6 alloy hooks attach to four discreet web loops located on the frame of the bike. Fitting method is particularly suitable for traditional one-piece seats and bolt-on seat pads/racks. US-packs can be mounted inline or across the seat. See US-Hook strap page for full fitting instructions.
Tech Spec. 445(H) x 295(W) x 225(D) mm 30-litre capacity (100% waterproof main body) Side access zip pocket (water-resistant) Coated-mesh pocket Shoulder & waist straps US-Hook straps included 1000D Dupont Cordura RHINOTEK: abrasion resistant fabric HYPALON: abrasion resistant re-enforcement DRYPACK: tape-seamed liner 420D nylon ripstop - lightweight yet extremely strong Acetal ITW Airloc buckles YKK water-resistant zips 6061-T6 alloy fitting hooks
10-year guarantee
$169.00
PAK-MEISTER
CobraHeat LLC
Old 05-02-2012, 05:22 PM   #254
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
We're off to the Ga Mtn Rally in the morning- stop in and say Hello!
PAK-MEISTER
CobraHeat LLC
Old 05-07-2012, 05:36 AM   #255
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Kriega UScombo70 motorcycle luggage system: 100% waterproof tailpack. Massive 70-liter capacity (US-30 + 2 x US-20 combo.). Innovative design solution which can fit directly to the seat or tank (US-20 component: see TANK option below) of your motorcycle. Both the Kriega US-30 and Kriega US-20 come equipped with removable shoulder and waist straps. They can be carried courier style, on or off the bike. The US-20 can fit on either side or on top of the US-30. Once connected together they can be removed as one single luggage 'block'.
$449.00
PAK-MEISTER
CobraHeat LLC
Times are GMT -7.   It's 09:16 PM.
