Old 05-09-2012, 05:16 AM   #256
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 947
Wherever you are - riding to work or on the trip of a lifetime - the last thing you need is a hole in your oil cooler from a stray stone or passing debris.
Fit one of our heavy duty oil cooler guards to give you protection from whatever the terrain throws at you!
For that added professional finish the GS logo is laser cut into the guard
The Oil Cooler Guard is made in Britain from BS1470 5251-H22 Aluminium.
Color - Matt Silver
Items Included For Fitting: - 2 x 5mm Zip Ties 300mm Long
$60.00
1150 GS
1150GSA
1200GS
1200GSA
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
NeedForSpeed is offline   Reply With Quote
Old 05-11-2012, 10:01 AM   #257
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
BMW R1200GS Adventure Box With 3.5 liters of capacity, the GS box is great to store essential tools etc, with a lockable rear door big enough to gain access to all usable space. Fits neatly and securely inside the right pannier frame, and is supplied with all necessary fixings for a simple install. Store a puncture kit, a first aid kit, anti-theft cables, locks, tools, etc. out of the way. Made of durable ABS plastic with a lockable door and brackets in anodised aluminium and stainless steel fittings, and supplied with 2 keys. The GS Adventure Box will fit all BMW R1200GS Adventure models from 2006 onwards with the facory fitted BMW Adventure aluminium frame.
$199.95
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-12-2012, 03:53 AM   #258
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
BMW R1200GS/A Mud Guard
Fits 2004-2007 Non ESA
BMW R1200GS/A Mud Guard is designed to attach under the rear seat, keeping the rear of the motor and shock absorber clear of road grime, dirt, dust, and excessive water, even reducing mud build up if riding off-road.
Developed, designed, and tested over thousands of miles in all weather conditions and terrain.
Installs in minutes and includes all necessary fittings and instructions..
Color - BLACK
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-13-2012, 03:57 AM   #259
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
BMW R1150 R1200 GS Fork Guards
These Fork Guards were designed from experience gained in riding thousands of miles in all weathers.
Effectively protects the most exposed part of the fork from dust, dirt and stones.
Essential protection for off-road, however still very effective against insects and tar for tarmac riders.
Includes both right and left Fork Guards with all necessary fittings and clear instructions to mount – installs in under 5 minutes.
BLACK
$79.95
Will fit all BMW R1200GS / GSA models
Will fit all BMW R1150GS / GSA models
Add our Kriega Fork Seal Covers for complete protection of your forks
$25.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-14-2012, 03:45 AM   #260
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
These Frame Guards were designed from experience gained in riding thousands of miles in all weathers.
Effectively protects the most exposed part of the frame from dust, dirt, stones, and boots!
Includes both right and left Guards with all necessary fittings
– Installs in under 5 minutes.
BLACK.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-16-2012, 04:02 AM   #261
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
KTM 950 990 XL Rear Rack
Want to carry larger items on the back of you KTM - such as a tent or roll bag?
Our XL rear rack offers a much larger area with multiple securing points and as a bonus also protects the fragile rear indicators from mishaps as well.
If you have the standard KTM Rear Pannier racks fitted our Xtra Large Rear Rack will not obstruct the opening of the panniers.
Designed and manufactured in the UK from 4mm aluminium with no sharp edges to catch bags or cut into straps.
Color - Matt Black
No additional fittings are required as the rack utilises existing fittings and mounting points.
Rack size: 450mm wide x 325mm deep.
This item fits the following models: KTM 950 Adventure KTM 950 Adventure S KTM 990 Adventure KTM 990 Adventure S KTM 990 Adventure R
Shipping weight 1.20 kg
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-17-2012, 04:10 AM   #262
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
The Bunker™ by Snugpak® is a new and exciting addition for Snugpak®. The Bunker™ is built and designed for long term hard use. With its 5000mm PU Coated Fly it can handle large amounts of rain as well as surpasses many other tent manufacturers with a much less superior fabric. The Bunker™ has two doors and two vents as well as all types of extras like internal mesh pockets, No-See-Um-Mesh, all seams are seam taped and much much more. The Bunker™ is a Fly First pitch type tent, which allows the users to quickly set up the fly and seek shelter from the elements.
Features
•Interior Mesh Pockets (6 Total - 3 on each side) •2 Doors •2 Vents •Fire Retardant •All seams are taped sealed •Bathtub floor •Alloy Stakes (17 + 2 Spare Stakes) •Available in Olive Outer with Black Inner only (As pictured above) •Comes with a Repair Kit to allow for repairs while on the move if needed
Specifications
•Flysheet is a lightweight 210t Polyester RipStop with a 5000mm waterproof polyurethane coating • •Inner Tent constructed of 190t Nylon with Polyester Mesh •50D Polyester No-See-Um-Mesh •DAC® Featherlite NSL® anodized poles with pressfit connectors •All DAC® Poles are made from TH72M aluminum •Trail Weight: 6.75 lbs (Fly, Inner Tent & Poles) •Pack Weight: 7.74 lbs (Fly, Inner Tent, Poles, Stakes, Repair Kit & Carry Case)
Retail Price $379.00
$322.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-19-2012, 04:31 AM   #263
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
BMW F800GS & F650Gs Twin - Headlight Guard
Protect your headlights from expensive damage due to wayward stones and other detritus with our heavy duty Headlight guard.
This headlight guard is manufactured to the highest quality in the UK.
This item fits the following models: - F800GS Models. - F650GS Twin Models.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-20-2012, 04:15 AM   #264
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
30-litre capacity (US-20 + US-10 combo.) 100% waterproof tailpacks. A unique solution which can fit directly to the seat-pad or to the tank (see TANK option below).
The US-20 also comes equipped with removable shoulder and waist straps.
It can be carried courier style, on or off the bike.
The US-10 can fit on either side or on top of the US-20.
Once connected together they can be removed as one single luggage 'block'
$239.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-21-2012, 04:50 AM   #265
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
Snugpak Stratosphere One Person Tent - New
Stratosphere
Much smaller than a standard tent but all the features, comes complete with seven L-shaped steel anchor pegs (six and one spare) and packs into its own compression sack. Fully zipped with roll away mosquito net in front of hood and meshed ventilation section at back.
Features
  • Shape/Style: Ultra compact 1 person shelter
  • Zip: Full length side zip
  • Fabric Outer: 50D Nylon Rip stop (5000mm HH)
  • Highly Breathable (5000g/ m2 Moisture Permeability)
  • Fabric Bottom: 70D Nylon Taffeta with PU coating (8000mm HH)
  • Poles: 8.5 mm Aluminium (Outside diameter) with screw lock tip
  • Dimensions: 230x95x106cm / 90inx37nx42in
  • Pack Size: 12.25” x 5.5” / 31cm x 14cm
  • Weight: 1.13kg / 46 Ounce (inc pegs)
  • Seams are waterproof and taped
  • Ultra compact 1 Person shelter
  • Stands up to severe weather
  • Makes sure you stay dry
  • Small Pack size
  • Ultralight alloy pegs
  • Come complete with compression sack
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-22-2012, 03:15 AM   #266
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
1200GS/ADV Headlight Guard
Protect your headlights from expensive damage due to wayward stones and other detritus with our heavy duty powdercoated aluminium headlight guard.
The Headlight Guard is made in Britain from Powdercoated BS1470 5251-H22 Aluminium.
The fixing brackets are made of 316-S31 Stainless Steel.
Color - Powdercoated Black.
This item fits the following models: - R1200GSA Models from 2004 onwards. - R1200GS Models.
$105.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-23-2012, 03:52 AM   #267
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
Coming Soon!
Kriega Overlander-60
Product details:
Innovative 60L panniers. Integrated platform design accepts 100% waterproof Overlander-15 packs or multiple Rotopax fuel/water containers.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-25-2012, 05:35 AM   #268
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
We just shipped 4 of these to a customer in Canada.
SnugPak Jungle Bag-
A sleeping bag for warmer conditions (summer) that packs smaller than a coconut.
The weight of the Travelsoft insulation was chosen for its performance in hot clammy conditions and is made into a sleeping bag that can be opened up into a quilt for more versatility when travelling.
Comes complete with a concealed roll away mosquito net which can be zipped over the face sealing the sleeping bag not only from mosquitoes but all manner of insects.
Activity: Travel, Trekking
Season: Warm Weather/Indoor Use, 2 Season - Late Spring
Origin: Imported
Weight Category: 0 to 1.0kg
Features: Mosquito Net, Antibacterial
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-26-2012, 05:35 AM   #269
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
The R1200GS Light Bar is designed to install PIAA lights on all BMW R1200GS bikes including the Adventure models. Made from 6061-T-6 billet aluminum, it is both lightweight and strong easy-to-install mounting bracket attaches the bar to the frame in a secure location under the front fender. Each end is threaded to accept a 10mm bolt, which makes the perfect location to mount a second PIAA lamp ( recommend the PIAA 1100X kit for this location) With its anodized black finish, the PIAA Light Bar will add both function and beauty to your R1200GS
$189.95
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 05-27-2012, 03:38 AM   #270
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 947
PIAA 510 Auxillary Lights
The compact size of this powerhouse allows for a multitude of applications. This long range driving light gets an amazing amount of light down the road and ahead of your high beams. The rotatable lens and trim ring allows the lamps to mount up or down. Uses a street-oriented 30-degree spread driving beam pattern. This projects the beam further down the road than the 510 ATP lamp, but provides a narrower beam. Recommended for moderate/Large sized enduro and adventure-touring motorcycles. Includes two 35-watt lamps, wiring harness, and M10 stud mounting hardware. Approximate exterior dimensions of lamp housing (excluding stud mount): 5" dia. x 3" long
$295.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Times are GMT -7.   It's 11:58 PM.
