Old 05-29-2012, 04:08 AM   #271
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,419
The Denali D1 light kit was designed from the ground up specifically for use on motorcycles. The compact 2”-square lamps house ultra-bright LEDs with an incredibly low draw of 0.75 amps each. A two lamp kit provides similar light output as dual 55-watt halogen kits on the market. Denali D1 LED lighting uses 10 watt LED technology. Each pod produces 900 lumens, making them the most efficient off-road lamp on the market. Unlike HIDs which require a warm-up time, LEDs are on at the flick of a switch! Each two-lamp kit includes a full wiring harness, lighted water-resistant switch with relay, and two sets of lenses, so you can run the Denali D1 LEDs as driving lights with a narrow, focused beam pattern or as flood lights with a wider beam pattern. The Denali D1 LED TT-D1.KIT ships with a universal M10 mount kit that works on most makes and models of bikes without any additional hardware. They can be wired to be triggered by your high beam switch, ignition key, or directly to battery for use when the bike is turned off (not recommended). Limited Lifetime Warranty - See Related Files section at the bottom of the page for complete details. Kit components: • 2 x Denali D1 LED light pods • full wiring harness with relay and switch • 2 x universal M10 mounting brackets • 2 x multi-link connectors • 2 x 'Euro' driving beam lenses (10 degree beam pattern) • 2 x fog beam lenses (35 degree beam pattern) • installation instructions
NITRON RACING SHOCKS USA
(801) 663-7436 sales@nitronusa.com
NeedForSpeed is offline   Reply With Quote
Old 05-30-2012, 03:46 AM   #272
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
New-
Interphone F5 Bluetooth ® Motorcycle Communicators
We have the F5 Single unit for $269.95 and the F5 twin pack for $449.95
The Interphone F5 Bluetooth ®Motorcycle Communicator offers full-duplex communication for groups of up to 6 riders. Effective maximum range starts at 0.8 miles between a pair of riders and increases to 1.5 miles for a group of six riders. The full-duplex communication allows all six people to talk at once.
Bluetooth 3.0 is the latest in Bluetooth intercom technology, providing faster data transfer for better range, more reliable connectivity, and improved battery life of up to 11 hours of talk or streaming time and 700 hours at standby.
Text to Speech:
The Interphone F5 has advanced features, including Text-to-Speech (TTS) for listening to text messages. Voice guidance commands are used to make setup and function selection much easier with no guessing about what function you have selected.
Phone:
Pair with your mobile phone for hands-free mobile communication. Text to Speech tells you when you have an incoming call and who is calling. Answer by saying "hello" or by pressing the center button. Dial by saying the name of a stored contact.
GPS:
Navigation messages can be received from Bluetooth motorcycle GPS units.
Pairing:
You can pair up to 8 devices. Each will remain in memory even after powering down. See instructions for complete pairing information.
Music:
Pair with any mobile phone or music player using MP3 Bluetooth or A2DP stereo. Enjoy broadcast music using the built-in FM radio with 8-function memory and station scanning. A 3.5mm auxiliary jack allows connection to external audio sources.
Easy Mounting:
The F5 comes with both self-adhesive and clamp-on mounts. The self-adhesive mount allows more flexibility in mounting location and is a bit more aerodynamic compared to the clamp-on mount. The head unit slides onto the mount and locks securely into place. The plug has a locking guide that provides a secondary locking mechanism. Detach the unit by first removing the plug and them depressing the locking tab and sliding the unit upward.
Full list of F5 Features:
  • A2DP stereo Bluetooth for HD audio
  • Certified IP67 waterproof and dustproof*
  • Provide clear audio up to 110 mph
  • Bluetooth® wireless music/GPS/phone calls
  • Automatic intercom muting during phone calls
  • 11 hour talk time or music streaming, 700 hour standby
  • 5 independent buttons: volume up, volume down, next track/station, last track/station, and function
  • Buttons have a pointed shape that provides ease-of-use, even with thick gloves
  • LED function lights
  • Automatic volume adjustment
  • Head unit responds to voice commands
  • Voice guidance commands simplify function selection and setup
  • Text-to-speech capability (listen to text messages)
  • FM radio (8 station memory and station scan function)
  • 3.5mm auxiliary input jack for external audio sources not using Bluetooth
  • Backwards-compatible with F4 head units
Dimensions: 3.54" x 1.75" x .78"
Weight: 1.94 oz. (55 grams)
What's in the Box?
All parts necessary to set up two helmets (one of which is full face), so you can easily move the head unit between both helmets.
  • Bluetooth head unit.
  • Boom mic and speakers for installation in a modular, open face, or full face helmet.
  • Self-adhesive mic and speakers for permanent installation in a full face helmet.
  • Quick release head unit mounts (1 self-adhesive, 1 clamp-on).
  • Wall charger with 2 leads to charge 2 head units simultaneously.
  • USB cable for charging and software updates.
NeedForSpeed screwed with this post 05-31-2012 at 05:14 AM
Old 05-31-2012, 08:25 AM   #273
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
We are now an Authorized SENA Dealer and have the SMH5/SMH10 Motorcycle Bluetooth Headsets available-
SMH5 Single $109.65
SMH5 Dual $211.95
SMH10 Single $186.15
SMH10 Dual $339.15
Old 06-01-2012, 05:26 AM   #274
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
The Snugpak Sleeper Xpedition is the lowest rated temperature bag we offer under the Sleeper Series range of sleeping bags. Many have been surprised at the features and construction of the Sleeper Xpedition as these are things you would nor...mally expect to see in a much higher priced sleeping bag. Our engineers and design team really came up with a great 4 season bag here. For those that need a 0°F bag at a very reasonable price, then the Sleeper Xpedition is exactly what the Dr. ordered.
Available Colors: Olive, Black
Temperature Rating: 10°F to 0°F (-12°C to -17°C)
Legnth:: 86 in
218 cm Weight:: 92 Oz
2608 Grams
Width:: 60 in
152 cm Pack Size:: 14 in
36 x 36 cm
$89.00
Old 06-03-2012, 05:46 AM   #275
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
The Snugpak Patrol Poncho is a simple over the head, waterproof, smock style piece of useful kit that everyone should have. Designed to be worn over the user as well as the users backpack, if one is being utilized, to help keep you and your gear dry in a down pour. Its generously cut design can allow one to use as an emergency Bivvi if needed. We have gone above the old standard design of what most people think about when thinking of a poncho, we have included an adjustable hood and thumb loops in our design. Located on the chest is a Velcro map pocket with storm flap. Made out of Snugpak’s exclusive Paratex Dry material and with fully taped seams which allows the shell to be 100% waterproof.
$57.95
Old 06-04-2012, 07:28 AM   #276
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
BMW R1200GS & Adventure Mud Guard
BMW R1200GS/A Mud Guard is designed to attach under the rear seat, keeping the rear of the motor and shock absorber clear of road grime, dirt, dust, and excessive water, even reducing mud build up if riding off-road.
Developed, designed, and tested over thousands of miles in all weather conditions and terrain.
Installs in minutes and includes all necessary fittings and instructions..
Color - BLACK
$139.95
Old 06-06-2012, 07:34 AM   #277
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Sena Products are on sale and selling quickly...
www.pak-meister.com
SMH5 Single $109.65
SMH5 Dual $189.95
SMH10 Single $164.25
SMH10 Dual $299.25
Sena SMH5 Bluetooth Headset
The SMH5 is a Bluetooth v3.0 Stereo Headset with Bluetooth Intercom designed specifically for motorcycles. With the SMH5, you can call hands-free on your Bluetooth mobile phone, listen to stereo music or voice instructions of GPS navigation by Bluetooth wirelessly, and have two-way intercom conversations in full duplex with a passenger or another motorcycle rider.
Thanks to the latest Bluetooth v3.0 and the advanced digital processing technology, the SMH5 offers the best sound quality for both incoming and outgoing sound in its class. Also, the easy-to-access and intuitive button operations make the SMH5 a perfect companion for motorcycles.
General Features:
  • Bluetooth Specification v3.0
  • Bluetooth Intercom up to 400 meters (437 yards) (in open terrain)
  • Multi-Pair Bluetooth intercom
  • Bluetooth stereo headset by A2DP
  • Bluetooth music playback control by AVRCP: play, pause, track forward and track back
  • Easy operation by versatile Jog Dial
  • Sufficient sound level with integrated audio booster
  • Bluetooth hands-free for Bluetooth mobile phones
  • Bluetooth headset or stereo headset for Bluetooth
  • GPS navigation
  • Water resistant for use in inclement weather
  • Crystal clear and natural sound quality
  • Up to 8 hours talk time, 7 days stand-by time
  • Can be used while charging on road trips
  • Individual volume control for each audio source
Old 06-09-2012, 04:04 AM   #278
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
The Ultimate Base Camp for your Dual Sport Riding
Mt Rainier Roof Top Tent
You wanted a more family-friendly sized tent now we have it.
This tent is the same tent as our Mt. Shasta only BIGGER!
It is 6'wide x 8'long it will sleep 3 big guy's (lol) or a family of 4.
The Mt. Rainier is the same great quality that you have become accustomed to with CVT.
The fabric of the tent is rip-stop with a P.U. Coating The travel cover is PVC.
We still have our unbeatable 4 year warranty!
When deployed the annex room is 9'x7'.
$1595.00 with Annex Room
(shown w/optional awnnig/screen room)
Old 06-10-2012, 04:35 AM   #279
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Kriega US-30 Combo from Pak-Meister $239.00
30-litre capacity (US-20 + US-10 combo.)
100% waterproof tailpacks.
A unique solution which can fit directly to the seat-pad or to the tank (see TANK option below).
The US-20 also comes equipped with removable shoulder and waist straps.
It can be carried courier style, on or off the bike.
The US-10 can fit on either side or on top of the US-20.
Once connected together they can be removed as one single luggage 'block'
Old 06-11-2012, 07:39 PM   #280
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
We now have the Interphone Waterproof iPhone 4/4s cases in stock (for tubular and non tubular handlebars)
The perfect addition to the SENA SMH5/SMH10 or Interphone F5 Bluetooth Headsets!
Old 06-12-2012, 03:39 AM   #281
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Kriega ADV Pannier Platform
Innovative platform design accepts Overlander-15 packs or multiple 1 Gallon Rotopax fuel/water containers. Make your own custom luggage combo based upon your needs, then change it for the next trip!
The Platform-...
Available as a single component (as used on Overlander-60 Panniers). The ADV Platform is a product to use alongside your existing alloy pannier set-up. Virtually indestructable CNC machined LDPE (9mm) platform accepts Overlander 15L luggage packs or 1 Gallon Rotopax fuel/water containers. (max 4 Gallons/ 15L per side).
The Fitting-
Designed for ultra-secure off road performance, Kriega custom 6061-T6 Clamps fit to the platform in various positions to clear exhaust & bodywork. Easy on/off with 4 x cam levers. Fits all 18mm pannier frames (Touratech, KTM PowerParts, Metal Mule).
The Dealer-
Pak-Meister.com
$225.00 ea.
Old 06-13-2012, 04:35 AM   #282
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Now in Stock!
NDuR Water Purification Survival Straw
When you’re travelling in areas where water quality is suspect, this unique water filtration device makes life easy. It gives you a convenient and low-cost alternative to boiling, purification drops and bottled water, and is suitable for travel throughout the world. Simply place the straw into any tap, stream, river or lake – even in third world countries – and enjoy safe, clean drinking water straight away.
The NDūR Survival Straw contains an advanced filter designed and tested by Seychelle Research Laboratories – one of the most sophisticated portable water purification devices in the world. Not only does it remove up to 99.99% of chemicals and other contaminants, it also protects you against viruses and bacteria to 99.9999% in water that other filters cannot remove. In addition it removes harmful heavy metals like mercury, lead, aluminum. This Survival Straw is made from BPA-free plastic, so it’s 100% safe.
With the NDūR Survival Straw, you’ll have instant access to safe drinking water anywhere in the world. Plus you’ll save money on bottled water, and reduce your plastic footprint by keeping hundreds of plastic bottles out of landfill.
Quick facts:
• Removes up to 99.9999% of contaminants
• Made from BPA-free plastic
• Filter can be replaced when needed or desired
• Straw Filter Life = 25 Gallons
• Unique design prevents leaks
• Ideal for those traveling abroad
$35.00
Old 06-14-2012, 03:31 AM   #283
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
NEW- NDuR Water Purification Canteen 38 oz.
When youre traveling in areas where water quality is suspect, this unique water filtration bottle makes life easy. It gives you a convenient and low-cost alternative to boiling, purification drops... and bottled water, and is suitable for travel throughout the world. Simply fill your bottle from any tap, stream, river or lake even in third world countries and enjoy safe, clean drinking water straight away.
The NDūR 38oz Bottle contains an advanced filter designed and tested by Seychelle Research Laboratories one of the most sophisticated portable water purification devices in the world. Not only does it remove up to 99.99% of chemicals and other contaminants, it also protects you against viruses and bacteria to 99.9999% in water that other filters cannot remove. In addition it removes harmful heavy metals like mercury, lead, aluminum .
This lightweight yet durable bottle is made from top quality, BPA-free plastic, so its 100% safe. The tightly-fitting lid prevents spills, even when squashed in a backpack. And the no-touch spout prevents cross-contamination from your hands when you open it to drink.
With the NDūR 38oz Bottle, youll have instant access to safe drinking water anywhere in the world. Plus youll save money on bottled water, and reduce your plastic footprint by keeping hundreds of plastic bottles out of landfill.
Quick facts: Removes up to 99.9999% of contaminants Made from BPA-free plastic Filter can be replaced when needed or desired Filter Life = 100 Gallons Unique design prevents leaks No-touch spout avoids cross-contamination The pliable plastic used and the design allows for increased flow rate when squeezed .
$55.00
Old 06-15-2012, 04:06 AM   #284
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
PIAA 510 5-inch 35w H3 Star White driving lamps-
The compact size of this powerhouse allows for a multitude of applications. This long range driving light gets an amazing amount of light down the road and ahead of your high beams. The rotat...able lens and trim ring allows the lamps to mount up or down. Uses a street-oriented 30-degree spread driving beam pattern. This projects the beam further down the road than the 510 ATP lamp, but provides a narrower beam. Recommended for moderate/Large sized enduro and adventure-touring motorcycles. Includes two 35-watt lamps, wiring harness, and M10 stud mounting hardware. Approximate exterior dimensions of lamp housing (excluding stud mount): 5" dia. x 3" long
$299.00
Old 06-16-2012, 02:14 AM   #285
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
We've sold quite a few tents this month-here's one of them
The Scorpion 2™ by Snugpak® is designed and modeled after the Scorpion 3™. The major difference between the Scorpion 3™ and the Scorpion 2™ is the size. The Scorpion 2™ has a small...er profile and is very sleek. Just as with the Scorpion 3™, this design helps the Scorpion 2™ to fend off those fierce winds that kick up from time to time and still is built and designed for long term hard use. With it’s 5000mm PU Coated Fly it can handle large amounts of rain keeping you and your gear dry, as it should be. The Scorpion 2™ has one door and three vents as well as No-See-Um-Mesh and all seams are seam taped and much much more.
Features
•1 Door
•3 Vents
•All seams are taped sealed
•Alloy Stakes (14 + 2 Spare Stakes)
•Available in Olive Outer with Black Inner only (As pictuered above)
•Comes with a Repair Kit to allow for repairs while on the move if needed
Specifications
•Flysheet is a lightweight 210t Polyester RipStop with a 5000mm waterproof polyurethane coating
•Inner Tent constructed of 190t Nylon with Polyester Mesh
•50D Polyester No-See-Um-Mesh
•DAC® Featherlite NSL® anodized poles with pressfit connectors
•All DAC® Poles are made from TH72M aluminum
•Trail Weight: 4.93 lbs (Fly, Inner Tent & Poles)
•Pack Weight: 5.83 lbs (Fly, Inner Tent, Poles, Stakes, Repair Kit & Carry Case)
$305.00
Times are GMT -7.   It's 03:22 PM.
