Old 08-09-2011, 04:12 AM   #16
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,407
Featured Product of the Day
Snugpak Sleeper Lite
Temperature::
32°F / 18°F
0°C / -7°C
The Sleeper Lite is a robust sleeping bag and an ideal introduction to Snugpak’s Sleeper Series performance range of sleeping bags. It provides plenty of warmth in a realistic pack size. Highly siliconized synthetic fibers give it a soft touch and prolonged lifespan compared to traditional Hollowfibre filled sleeping bags on the market. The Sleeper Lite has been a favorite of US Federal Agencies for the past several years. Used extensively by static troop divisions in other countries deep in hostile territory around the world.
Available Colors: Olive, Black, Woodland Camo
Legnth::86 in
218 cm
Weight::56 Oz
1588 Grams
Width::60 in
152 cm
Pack Size::9 in
23 x 23 cm
$69.00
NITRON RACING SHOCKS USA
(801) 663-7436 sales@nitronusa.com
NeedForSpeed is offline   Reply With Quote
Old 08-10-2011, 04:21 AM   #17
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
TurboFlame
The new Turboflame® Ranger is the ideal windproof lighter essential for any outdoor enthusiast’s. With its double-power jets flames that can reach temperatures up to 1300oc. Also there is Gas level indicator a lanyard attachment point and safety cap.
Turboflames “clean burn” technology means it can also melt synthetic materials without depositing black carbon, so outdoor equipment can be quick fixed without discoloration. Outdoor enthusiasts include Turboflame® in their emergency kits to melt p-tex, seal micro - cracks in boards and canoes, cut and seal PARA rope and blast rust from metal. Turboflame® lighters can work up to altitudes of 3000 metres and doesn’t “self-combust” at high altitudes.
Capable of burning at any angle, even upside down, these adaptable survival lighters provide safe ignition for just about anything.
Features:
• Flame Temperature reaching up 1300oC
• Size 3” x 1.125” (7.6 X 3 cm)
• Weight 3oz (85 grams)
TURBOFLAME® - not just a light...
Customer Reviews
Turboflame...name says it all.
This lighter is like a welding torch of some sorts! It's the most powerful lighter I've ever owned. We have started fires in torrential downpours and lit cigars while staring at the night sky. A must have in your kit.
Reviewed by: rick lohre from Midwest. on 8/8/2011
Old 08-11-2011, 04:11 AM   #18
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Featured Product of the Day-
ProForce Mess Kit
Swedish designed Plastic Mess Kit packs neatly into itself, Includes: 2 Trays, Bowl, Small Fold-A-Cup, Stainless Steel Knife / Fork / Spoon set, Cutting board & 3 compartment condiment stacker.
Made in Sweden
Weight 10 oz
Old 08-12-2011, 04:51 AM   #19
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Snugpak Kit Monster 65L
The Kit Monster is now available in a 65 Liter version as well as the tried and trued 120 Liter version. Some refer to the Kit Monster as a carryall. It has a variety of handles and loops which allow the bag to be carried as a hold all, it can be worn on the back as a rucksack when you use the shoulder straps, or just a simple duffle type style gear bag. One unique feature of the Kit Monster that sets it apart from standard duffle type style bags is it is equipped with compression straps that allow the excess volume to be reduced, which in turns reduces the bulk of the bag. The Kit Monster also has grab handles on each end. This is great for those extremely heavy loads when you need a buddy to help you lift it into the helo or onto the boat. Also the grab handles on each end can also be used in conjunction with a carabiner to secure the Kit Monster to prevent it form moving around. A couple of other features are the heavy duty base and chunky zipper.
Available Colors: Black
Features
  • Carry straps can be used as shoulder straps for heavier loads.
  • Cinch / compression straps on all four sides to to reduce excess volume, which reduces the bulk of the bag.
  • Curved zipper design to easily allow larger objects to be inserted and removed unlike conventional stright zippers.
Old 08-13-2011, 04:58 AM   #20
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
PROFORCE Dri-Sak X-Large
Store your sleeping bag, clothing, and any other items you want to keep dry in a Drī-Sak™. No matter what size you choose or need we have a size that is sure to be right for you situation. They are seam taped, nylon with a TPU Film Lamination to ensure protection if your gear takes an unexpected dive into the water. They are a great addition that can be used in conjunction with any of the Snugpak® backpacks or any other backpacks.
• Dimensions: 9.75“ x 24” / 25 x 61 cm
• Volume: 20 liters
• Weight: 3.70 oz. / 105 g
Proper Use:
• Our Drī-Sak™ Bags are not intended to be submerged For extended periods of time.
• Roll-top closure must be closed correctly (we recommend rolling 3 times and buckled) to keep contents dry.
• Contact with abrasive or sharp objects can damage and/or compromise the integrity and waterproofness of our Drī-Sak™ bags.
Features:
• Durable & Lightweight Nylon fabric w/ Waterproof
Laminate
• Waterproof taped seams
• Roll-top waterproof closure
• Durable buckle secures roll top
• D-Rings for securing if necessary
www.pak-meister.com
Old 08-14-2011, 06:20 AM   #21
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Featured Product-
Snugpak Sleeka
Tried and tested in every conflict since the Falklands war by the
British Military/SAS and has been give the nickname of “Softie”. Ideal for very cold outdoor usage, this low weight, low bulk, easy care jacket has the Softie filling, used by the Softie Sleeping Bags range. Special features include; Low pack size, bottom hem adjuster, comfort fold on zipper, Lycra sleeve cuffs. Paratex Light outer shell for high performance, moisture wicking and breathability. Supplied with a stuff sack.
Available Colors: Olive, Black, Tan or Coyote
Old 08-15-2011, 04:08 AM   #22
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Snugpak Softie Elite 1
Temperature::
45°F / 36°F
7°C / 2°C
The smallest sleeping bag in the elite tactical range, this lightweight and low pack size unit will fit into even the most space restricted rucksack or even tie discreetly to the outside. This Elite bag is equipped with our unique easy to deploy EPS Expanda Panel System and its own sturdy compression stuff sack. A layer of our exclusive Reflectatherm metalized barrier helps to reflect heat back inside.
Available Colors: Olive, Black, Desert Tan
Legnth::86 in
218 cm
Weight::36 Oz
1021 Grams
Width::65 in
165 + EPS cm
Pack Size::7 in
18 x 18 cm
Old 08-16-2011, 04:43 AM   #23
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Snugpak Xocet 35
The Xocet 35® by Snugpak has been getting rave reviews from those that have been fortunate to get a sneak peak at it. The Xocet 35® has a lot of great features that many will like and appreciate. There is a roomy main compartment for your gear with a Hydration system sleeve and an outlet port through the top to run the drinking tube. Also the main compartment has an organization system to help store and arrange various items. There is also a zippered storage pocket for those items you want to keep secure and accessible. There is also a front storage pocket to conveniently put items that are needed at a moment’s notice. Also both sides have a mesh pocket with bungee cord tensioning for items such as water bottles and clothing. Lastly the Xocet 35® has 5 rows of MOLLE webbing on the pack to allow the user to add MOLLE compatible system pouches they might need such as utility, accessory, ammo, radio, etc.
Features
  • Velcro® Strips for Flag & Unit patches as well as for Name and Rank tapes
  • Padded shoulder straps with an adjustable sternum strap
  • Hydration System compatible
  • Internal organizer for small items and tools
  • Waist strap can be secured in hidden compartment to stay out of the way when not needed and then there when it is needed
Specifications
  • Main Compartment: 2135 Cubic Inches / 35 Liters
  • Weight: 38 oz
  • Dimensions: Main (19” H x 12”W x 8”D)
$93.50
Old 08-17-2011, 02:53 AM   #24
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Snugpak Pakbox 6-Liter
Compact multi-functional packing box, used to group small items and clothing in your rucksack or luggage. Useful for t-shirts, socks underwear and all kinds of small items. Features an easy grip handle, zipper closure along with mesh inspection panels for easy identification of contents and comes in three convenient sizes.
Specifications
Dimensions: 13.75” x 12.5” x 3.5”
$15.00
Old 08-18-2011, 03:52 AM   #25
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Featured Product
Snugpak- The Bunker
The Bunker™ by Snugpak® is a new and exciting addition for Snugpak®. The Bunker™ is built and designed for long term hard use. With its 5000mm PU Coated Fly it can handle large amounts of rain as well as surpasses many other tent manufacturers with a much less superior fabric. The Bunker™ has two doors and two vents as well as all types of extras like internal mesh pockets, No-See-Um-Mesh, all seams are seam taped and much much more. The Bunker™ is a Fly First pitch type tent, which allows the users to quickly set up the fly and seek shelter from the elements.
Features
•Interior Mesh Pockets (6 Total - 3 on each side) •2 Doors •2 Vents •Fire Retardant •All seams are taped sealed •Bathtub floor •Alloy Stakes (17 + 2 Spare Stakes) •Available in Olive Outer with Black Inner only (As pictured above) •Comes with a Repair Kit to allow for repairs while on the move if needed
Specifications
•Flysheet is a lightweight 210t Polyester RipStop with a 5000mm waterproof polyurethane coating • •Inner Tent constructed of 190t Nylon with Polyester Mesh •50D Polyester No-See-Um-Mesh •DAC® Featherlite NSL® anodized poles with pressfit connectors •All DAC® Poles are made from TH72M aluminum •Trail Weight: 6.75 lbs (Fly, Inner Tent & Poles) •Pack Weight: 7.74 lbs (Fly, Inner Tent, Poles, Stakes, Repair Kit & Carry Case)
Old 08-19-2011, 04:34 AM   #26
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Snugpak Snuggy Headrest
The Snuggy Headrest Pillow is a great accessory to the Tactical Series line of Sleeping Bags. A practical headrest that packs away into its own integral stuff sack. Provides an amazing amount of support for head and neck. Uses high quality sleeping bag insulation and fabrics.
$15.00
Old 08-20-2011, 04:24 AM   #27
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
PAK-MEISTER MilSpec Series Panniers
PAK-MEISTER MilSpec Series Panniers are Tough As Nails!
We start by hand picking the highest quality late production surplus cans we can find before a 3 stage cleaning process and powder coating. A Heavy Duty inexpensive pannier option, or use as back-ups for the Alcan Hwy instead of beating up your expensive OEM panniers.
Dimensions: 17.25"L x 7.25"W x 14"D
Weight: 18.5 ea
Note- We hand pick the highest quality like-new cans that we can find. However, these cans are 5-10 yrs old and may have a small dent/ding that is slightly highlighted or more pronounced by powdercoating. If you are looking for Museum quality artwork these may not be the right panniers for you.
*Does NOT include mounting hardware, but you'll get two cool Pak-Meister decals for the panniers
$175/pair
NeedForSpeed screwed with this post 04-06-2012 at 01:51 PM
Old 08-21-2011, 05:07 AM   #28
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Snugpak Response Pak
Makes a Great Toolbag!
When travelling light, or when you may need to move out in a hurry, it pays to keep all your essential items together, with a place for everything this multifunctional carry case also doubles as a fanny pack, or as the British would call it, a bum bag. We use the same heavy duty materials in the Response Pak as we do in our series of backpacks. The Response Pak has a multitude of hidden internal storage pockets. The Response Pak has quickly become a favorite among military members as a great little med bag, perfect for those vital items each soldier needs.
The Response Pak has a lot of storage in a small compact functional bag. You have webbing on the front and sides to attach other small pouches using either the MOLLE attachment system or the Alice Clip system.
Great for those needing a larger Medical / E&E bag then those smaller ones made to attach on a belt or pack. Much more room for needed supplies and even a bag of IV can fit inside.
The Response Pak has a waist strap that can also be stowed within itself for those who wish to you us it as a small bag or to attach to a larger back pack with MOLLE on it.
The image above shows the waist straps stowed and the Response Pak is now ready to be used as seen or can easily now be attached to a larger back pack with MOLLE on it.
Measures 14" x 5 1/2" x 8 5/8"
$29.00
Old 08-22-2011, 04:44 AM   #29
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Multimat Summit Mat
The Summit Mat is designed for performance and reliability. The precise balance of weight reduction, comfort and warmth is exceptional.
Note: The pack size is determined when mat is mid-folded and then rolled.
Features
Mats supplied with microfibre-lined stuff sack/pillow case, retaining band & repair kit. Super-fast valve giving 3x airflow of a regular valve for fast inflation/deflation. Lightweight 75D polyester base with non-slip. Water repellent coating. Quality, lightweight, vertically and horizontally drilled, high insulation/rebound 16kg/m3 PU foam core for lasting performance and full & fast insulation.Tough & lightweight 75D rip-stop polyester fabric
Antibacterial ether TPU membrane for an air-tight seal.
Special formulation for use at lower temperatures
Length: 72 in
Width: 20"
Weight: 30oz
$126.50
Old 08-23-2011, 03:18 AM   #30
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,407
Thumb
Snugpak CrossOver Pak
The Crossover™ by Snugpak® is another sought after and requested product. The Crossover™ is a great single shoulder strap day pack for anyone. With its single shoulder strap criss crossing over the owners chest it makes it easy to put on and take off as well as very comfortable. Also there is a small section of MOLLE webbing on the waist strap where someone could place and use a pouch for a cell phone, flashlight, knife etc. Also there is webbing on the shoulder strap as well where a phone or portable radio could be attached and also a hydration drinking tube could be routed and secured for easy access. The Crossover™ also has a hidden compartment that can be accessed from two different zippered openings. The concealed compartment has one panel completely covered in Velcro® to attach various pouches like maybe for a handgun, knife, mace, money, passport, etc.
Features
  • Zippered concealed compartment with Velcro® backing to attach a number of different pouches to secure and hold a handgun, knife, mace, passport or money etc.
  • Built-In Hydration Pouch
  • Waist strap can be used if desired or removed also in not needed
  • MOLLE Webbing on waist strap
Specifications
  • Main Compartment: 1098 Cubic Inches / 18 Liters
  • Weight: 27 oz
  • Dimensions: Main (18” H x 11.75”W x 5”D)
$67.50
Times are GMT -7.   It's 01:12 AM.
