Old 06-30-2012, 04:57 AM   #301
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 962
Pak-Meister 29L Panniers
A recent review from one of our customers-
Recently purchased the 29L panniers and was very satisfied with the quality and construction. Mounted on SW-Motech Evo quicklok side racks, and only took 30 minutes and was ready to go. Second purchase from Mike and really appreciate the way he does business! Will gladly do business with Pak-Meister in the future.
Paul-
Asheville N.C.
6/29/2012
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
NeedForSpeed is offline   Reply With Quote
Old 07-01-2012, 05:43 AM   #302
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
F800GS Skid Plate
BMW F800GS Engine Guard Skid Plate
Constructed of 3mm-thick (1/8"-thick) aluminum for heavy-duty, light-weight protection.
Baseplate includes side protectors that wrap around the engine block to provide both bottom and side protection.
Available in bare aluminum only.
Fits the following models:
- F800GS - All Models
$239.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-03-2012, 04:33 AM   #303
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
The ProForce All Weather Shelter is the most versatile multi-purpose shelter for “ALL WEATHER” conditions protecting you from the sun, wind, rain and snow. Designed by Military Veterans and avid Outdoorsmen. It can be configured and used as a Fly, Pup Tent, Lean-Too Shelter, Emergency Bivvi and the list goes on. With the components and features offered the All Weather Shelter has endless possibilities, only limited by ones imagination. The All Weather Shelter is ideal for those that travel light and move fast.
The All Weather Shelter measures 10’x10’ with grommets on each corner as well as numerous webbing tabs along each side. Also there are 3 webbing tabs across the spine when used as a fly. Also down two opposite side are plastic snaps which can allow it to be folded and snapped together to make an emergency bivvi if desired. Included also are 4 guy ropes with adjusters measuring 10’ in length and 8 ultra lightweight alloy stakes.
Constructed out of 210T Nylon Rip-Stop, PU Coated and is also UV Resistant. All seams are sealed and taped. Reinforced webbing tabs along sides. Available in Olive only.
$67.95
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-04-2012, 04:38 AM   #304
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
kaoko throttle lock cruise control KLR
Kaoko Cruise Controls are purpose-built for a variety of motorcycles over 600cc. They consist of a friction nut that is integral with a replacement handlebar-end weight.
To install, just remove the right hand bar weight, replace it with Kaoko's bar weight, and firmly tighten the central retaining screw.
Features
• Greatly reduces rider fatigue and strain on hand and wrist
• While cruising, rider is able to remove hand from throttle grip, throttle opening will remain as set
• Very simple to operate, even with heavy winter gloves
• High quality, compact and durable design, super smooth action
• Takes less than 5 minutes to fit
• Very little maintenance is required
• Less wear and tear on throttle cables and linkages
• Can result in reduced fuel consumption
Fits:
Kawasaki Ninja 650R, '06-
•Kawasaki ER6N
• Kawasaki Versys
• Kawasaki KLR650E '08+ *
•Kawasaki ZX12
• Kawasaki ZX14
• Kawasaki GTR1400 Concours
• Kawasaki GTR1000/ZG1000 Concours, '86-'06
*Will fit KLR650E with original Kawasaki handguards or without any handguards. Will not fit KLR650E with full-wrap handguards that require removal of original bar end weight.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-05-2012, 01:31 PM   #305
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,000
Hi, I mentioned on Facebook that I would like to purchase your mid range panniers assuming they would fit a Tiger 800XC with Givi Monokey racks. I can be reached at 330-205-0323 or tommyt@drumlines.org.
Thanks,
Tom Lally
KLR 650- BMW K75- DRZ400S- 75 XS 650
Every bike an adventure bike... Every ride an adventure.
ThomasVolomitz is offline   Reply With Quote
Old 07-06-2012, 04:35 AM   #306
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
Interphone F5
The Interphone F5 Bluetooth ®Motorcycle Communicator offers full-duplex communication for groups of up to 6 riders. Effective maximum range starts at 0.8 miles between a pair of riders and increases to 1.5 miles for a group of six riders. The full-duplex communication allows all six people to talk at once.
Bluetooth 3.0 is the latest in Bluetooth intercom technology, providing faster data transfer for better range, more reliable connectivity, and improved battery life of up to 11 hours of talk or streaming time and 700 hours at standby.
Text to Speech:
The Interphone F5 has advanced features, including Text-to-Speech (TTS) for listening to text messages. Voice guidance commands are used to make setup and function selection much easier with no guessing about what function you have selected.
Phone:
Pair with your mobile phone for hands-free mobile communication. Text to Speech tells you when you have an incoming call and who is calling. Answer by saying "hello" or by pressing the center button. Dial by saying the name of a stored contact.
GPS:
Navigation messages can be received from Bluetooth motorcycle GPS units.
Pairing:
You can pair up to 8 devices. Each will remain in memory even after powering down. See instructions for complete pairing information.
Music:
Pair with any mobile phone or music player using MP3 Bluetooth or A2DP stereo. Enjoy broadcast music using the built-in FM radio with 8-function memory and station scanning. A 3.5mm auxiliary jack allows connection to external audio sources.
Easy Mounting:
The F5 comes with both self-adhesive and clamp-on mounts. The self-adhesive mount allows more flexibility in mounting location and is a bit more aerodynamic compared to the clamp-on mount. The head unit slides onto the mount and locks securely into place. The plug has a locking guide that provides a secondary locking mechanism. Detach the unit by first removing the plug and them depressing the locking tab and sliding the unit upward.
$269.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-16-2012, 04:25 PM   #307
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
We are off to the BMW Rally tomorrow morning!
Building A
Stop in and say Hello!!!!
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-24-2012, 06:28 AM   #308
beergut
Thumper
beergut's Avatar
Oddometer: 373
Like the rest of the country, my neck of the woods has been in a drought pretty much since last fall; Very little snow and rain.
This morning the clouds opened up and it seemed like all of the rain that has been holding off for almost a year came down in about 10min time...which just so happened to be the tail end of my morning commute.
My panniers are attached to my bike as they have seemed to be pretty beneficial to have on all of the time. I haul pretty much everything on the bike...haven't driven my SUV in so long the battery is actually dead from it sitting.
This evening I have class so my bag with my ipad and cell phone was in the pannier. I was sorta nervous about it because it was raining super hard...to the point where cars were pulled over.
When I arrived at work, I just left everything in the pannier. I thought, if its going to get wet, it is wet by now. Ill go back out and get it later.
I just went out at a break in the storm and the bag was totally dry. All contents in the pannier were just fine!
Again, +1 for Pak-Meister!
'04 KTM 950Adv
KTM rotopax mounting plates
DIY rear top rack
beergut is online now   Reply With Quote
Old 07-28-2012, 05:53 AM   #309
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
Our Adventure Tank Guards are now available in Black!
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 07-31-2012, 05:07 AM   #310
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
Rox Risers will be shipping next week!
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
NeedForSpeed screwed with this post 08-03-2012 at 04:49 PM
Old 08-02-2012, 04:19 AM   #311
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
We are now a Pivot Pegz Dealer! The new MK3's will begin shipping by the end of August
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 08-07-2012, 11:27 AM   #312
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
Rox Risers have arrived and are in stock!
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 08-08-2012, 05:12 AM   #313
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
BMW Auxillary Light Bars
BMW R1150GS & R1150GSA - Auxiliary Light Mounting Bar
The R1150GS light bar had been designed and manufactured in the UK from 4mm laser cut, brushed stainless steel.
Longer bolts and spacers required for fitting, are included.
Benefits Of The Rugged Roads Auxiliary Light Mounting Bar
- Lasercut fixing holes so you can easily attach the cables to the light bar keeping your wiring secure and out of the way.
- The light bar goes left to right under the beak, so you only need one to mount 2 or 4 lights and cuts out any vibration.
- The bar is bolted to the beak by means of the oil cooler bolts.
- Can be mounted in 5 minutes, without disassembling anything on your R1150GS.
- R1150GS - All Models
- R1150GSA - All Models
$99.00
BMW F800GS & F650GS Twin - Auxiliary Light Mounting Bar
We all know that you can never have enough lighting and that many of you like to fit additional lights to your bikes. We have designed and manufactured this ergonomic light bar, making it easy for you to fit auxiliary lights.
The light bar has been designed and manufactured in the UK from laser cut, aluminium, and finished in matt black.
All fittings are included.
Due to the different locations of the front indicators between the F650GS and F800GS we suggest the following;
- For the F650GS we would suggest that you mount your auxiliary lights underneath the lightbar.
- For the F800GS we would suggest that you mount your auxiliary lights above the lightbar.
- F650GS Twin - All Models
$89.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 08-14-2012, 03:34 AM   #314
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
Kriega US-20 at Pak-Meister.com
We've had a run on the Kriega US-20 over the past 2 days- shipped almost 10 of them- including Russia, Norway, Brazil, and to our friends Down Under...
The Kriega US-20 tailpack is designed to fit most motorcycle seat pads (attachment strap...s included). The pack is easily attached/removed by 4 x quick-release buckles. No extra bungees or rain covers needed. Remove the 2 x compession straps from the US-20. Remove the bike's seat pad. Lay the straps in to the void of the rear seat. Replace the seat pad and ensure it is correctly locked down (thread the top roll-over strap through the pillion grab-strap if present). Finally, connect all 4 x quick-release buckles and tighten the pack down on to the seat. NB - it is important to use the 2 x strap-tidy components on each compression strap. These components ensure there is no web-creep once the strap has been tightened. The US-20 can fit a traditional style, long motorcycle seat. We recommend the use of the otional connector-straps (see link below). This option allows the loose strap-ends to be connected together over the top of the seat, when not using the tailpack. The US-20 also makes an effective rack-mounted motorcycle luggage solution with the addition of the optional 4 x Loop Straps (see link below). This strap spec. allows the web to be tied to the rack rather than just run under it, as is possible with the standard compression straps.
Tech Spec (H)15.7 x (W)10.2 x (D)7.5 inches 20-litre capacity (100% waterproof main-body) Side access zip pocket (water-resistant) Coated-mesh pocket Shoulder & waist straps Option to add-on US-10s (see US-30 & 40 links below) 1000D Dupont Cordura RHINOTEK: abrasion resistant fabric HYPALON: abrasion resistant re-enforcement DRYPACK: taped-seam liner 420D nylon ripstop - lightweight yet extremely strong Acetal ITW Airloc buckles YKK water-resistant zip 10-year guarantee
$139.00
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 08-20-2012, 03:37 AM   #315
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 962
BMW F800GS & F650GS Twin - Rear Rack
BMW F800GS & F650GS Twin - Rear Rack - Black Want to carry a bit more on the back of your bike without having to use a topbox? Great for holding larger items such as tents. Because of the height of the rack extension even wide items can be fixed on as they will sit above your panniers. Designed with lots of strap fixing points so you can carry just about anythiing on your rack. We think the F800GS is beautifully shaped and have followed the lines of the rear panels so your rack - as well as being functional looks fantastic when fitted on your bike.
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Times are GMT -7.   It's 07:05 AM.
