10-10-2012, 04:01 AM
#346 |
PAK-MEISTER.COM
Oddometer: 949
Kriega R25 Backpack
The Kriega R25's have been flying off the shelf!
The R25 motorcycle backpack has a quick release QUADLOC harness, which is our own tried, tested and highly recommended system, unique to the rucksack industry. An innovative & extremely efficient load-carrying system designed for motorcycle riders. Unlike conventional harness systems the load is carried on the hips & chest, transferring the majority of the load away from the shoulders and thereby preventing the neck strain experienced with regular rucksacks.Unique 4-point harness: transfering the load away from the shoulders and onto the chest & hips. Ergonomically designed with no arm restriction for long distance comfort. Tech Spec 520(H) x 300(W) x 160(D) mm 25-litre capacity CNC 6061-T6 alloy buckles Expanding outer pocket Optional 3-litre hydration reservoir Optional add-on 5 or 10 litre drypacks Optional harness pocket SUPERSPACE: 5mm airspace fabric. Oversize YKK coil zips. Schoeller DYNATECH with intergrated 3M Scotchlite reflectivity. 1000D Dupont Cordura base & harness. 420D nylon ripstop - lightweight yet extremely strong. 10 year guarantee. $179.00 www.pak-meister.com
10-10-2012, 05:45 AM
#347 |
PAK-MEISTER.COM
Oddometer: 949
Oil Cooler Guard - Black With GSA Logo - R1200GSA Wherever you are - riding to work or on the trip of a lifetime - the last thing you need is a hole in your oil cooler from a stray stone or passing debris. Fit one of our heavy duty oil cooler guards to give you protection from whatever the terrain throws at you! For that added professional finish the GSA logo is laser cut into the guard $65.00 |
10-10-2012, 05:39 PM
#348 |
PAK-MEISTER.COM
Oddometer: 949
Ndur utility flame
NEW Item-
NDur Utility Flame ODORLESS - SMOKELSS - NON-TOXIC - WATER-SOLUBLE - NON-HAZARDOUS The Utility Flame Gel is lightweight, inexpensive, safe to transport by aircraft and extremely versatile. Its uses are unlimited - it will boil ...water, provide emergency sterilization, make hot MREs, reconstitute freeze dried foods, heat a cup of coffee, dry wet clothing, provide warmth and start a campfire. It can be used as a heat source in virtually any environment and situation. Because Utility Flame is not a hazardous material, it requires no special clean up or handling. Once the gel has burned, all that is left at the site is sand that easily brushes away. Comes in a 2 Pack (Each Packet is 1.25oz) FEATURES: - Burns up to 1358°F / 737°C - Burns at -23°F / -20.5°C - Burns at 10,000ft + Eevation - Boils Water Easily - Does nto Evaporate, Freeze or Melt - Smokeless / Odorless - Non-Toxic / Water-Soluble - Not Explosive - Indefinite Shelf-Life (Tested up to 12 Year) - No EPA Restrictions (Not a HAZMAT) - Can be Transported by Airline or Mail $6.00
10-11-2012, 03:23 AM
#349 |
PAK-MEISTER.COM
Oddometer: 949
NEW Item- All Weather Notebook
The All Weather Notebook by Snugpak® are a great addition to anyone’s pack. Compose notes in wet weather conditions with a pencil or pen. The interior pages have both lines and grids (spaced in 1/8” lines ver...t ically and horizontally). Also, on the inside of the back cover is an easy to read Conversion Chart for lengths, weights and temperatures. Features • color: Tan • 4” x 6” • Pages Lined on the front / Grid on reverse • Conversion Chart • Printed Rulers for Inches & Centimeters $4.00
10-16-2012, 04:25 AM
#350 |
PAK-MEISTER.COM
Oddometer: 949
BMW R1200GS & R1200GSA - Polycarbonate Headlight Guard Protect your headlights from expensive damage due to wayward stones and other detritus with our heavy duty polycarbonate guard. Also because of the way the guard is fitted the rider will not suffer from reflected glare. This polycarbonate headlight guard has been designed by us at Rugged Roads and is manufactured to the highest quality here in the UK. We have made the fixing brackets out of Stainless Steel - and the guard itself from Makrolon®Color - Clear polycarbonate.
$75.00
10-18-2012, 04:12 AM
#351 |
PAK-MEISTER.COM
Oddometer: 949
Rox Pivot Risers 2" Rise for 1-1/8" Bars BMW R1200GS/A
2" center to center rise to help accommodate more applications with out replacing cables. Very popular for BMW R1200GS/A Also a great Riser for KTM 690 950/990Adv, Great for the new Triumph Tiger 800XC, and Street, along with many other bikes that come with 1 1/8" handlebars. Can work with stock cables. Anodized Clear. Always check and confirm that your bike has adeguate cable and brakeline length before installing any handlebar risers. $87.00 |
10-19-2012, 03:56 AM
#352 |
PAK-MEISTER.COM
Oddometer: 949
Snugpak Sleeka Original-
Tried and tested in every conflict since the Falklands war by the British Military and has been give the nickname of “Softie”. Ideal for very cold outdoor usage, this low weight, low bulk, easy care jacket has the ...Softie filling, used by the Softie Sleeping Bags range. Special features include; Low pack size, bottom hem adjuster, comfort fold on zipper, Lycra sleeve cuffs. Paratex Light outer shell for high performance, moisture wicking and breathability. Supplied with a stuff sack. Temperature:: 23°F / -5°F $187.50
10-20-2012, 04:30 AM
#353 |
PAK-MEISTER.COM
Oddometer: 949
Bluetooth comparison chart
Bluetooth Comparison Chart
10-20-2012, 04:35 AM
#354 |
PAK-MEISTER.COM
Oddometer: 949
Snugpak Elite Series Bag Sizes
10-23-2012, 04:44 AM
#355 |
PAK-MEISTER.COM
Oddometer: 949
Sena smh10
The SMH10 is a Bluetooth v2.1 Class 1 stereo headset with long-range Bluetooth intercom designed specifically for motorcycles. With the SMH10, you can call hands-free on your Bluetooth mobile phone, listen to stereo music or voice instructi...ons of GPS navigations by Bluetooth wirelessly, and have intercom conversations in full duplex with a passenger or other motorcycle riders.
Thanks to the latest Bluetooth v2.1 and the advanced digital processing technology, the SMH10 offers the best sound quality for both incoming and outgoing sound in its class. Also, the easy-to-access and intuitive button operations make the SMH10 a perfect companion for motorcycles. Bluetooth Specification v2.1. Bluetooth intercom up to 980 yards (900 meters). Multi-pair Bluetooth intercom for 4 persons. Bluetooth stereo headset for Bluetooth audio devices such as MP3 players. Bluetooth music playback control by AVRCP: play, pause, track forward and track back. Easy operation by versatile Jog Dial. Sufficient sound level with integrated audio booster. Bluetooth hands-free for Bluetooth mobile phones. Bluetooth headset or stereo headset for Bluetooth GPS navigations. Stereo music by 3.5mm audio cable. Water resistant for use in inclement weather. Crystal clear and natural sound quality. Up to 12 hours talk time, 10 days stand-by time. Can be used while charging on road trips. Individual volume control for each audio source. Includes Two of each: Headset Main Unit, Speaker-Microphone Clamp Unit, DC Power Charger, USB Power Cable, Cigarette Charger, 3.5mm Stereo Audio Jack Cable, Glued Surface Mounting Adapter, Microphone Sponges, Velcro Pads and Hex Key (Allen Wrench).
10-24-2012, 04:19 AM
#356 |
PAK-MEISTER.COM
Oddometer: 949
PivotPegz MK3 F800GS F650GS single/twin
The new Mark 3 Pivot Pegz® are now available and have taken it to a whole new level with a mega wide 60mm platform. Due to the pivoting nature of Pivot Pegz you can have the best of both worlds, a mega wide 60mm platform and easy access to the gear shift and rear brake lever, this is due to the fact that the Pivot Pegz platform pivots and opens up access to the lower controls. Let us assure you that this isnt your average footpeg, not only do you get a mega wide platform but the state of the art grip pattern, platform design and spring loaded pivoting action means you get enhanced grip and load distribution as well as reduced impact and fatigue. The new Mark 3 Pivot Pegz are also designed to reduce mud packing in the peg. As for the quality, its world class, quite simply our aim is to build the best performing and highest quality production footpegs in the world. These MK3 Pivot Pegz are precision built and made from solid aerospace grade stainless steel, polished to a mirror finish and designed to perform like no other peg. You get the Ferrari of the footpeg world at a great price. Pivot Pegz are a patented, race proven product that actively tracks with the motion of the riders foot to provide superior grip and load distribution whist reducing impact and fatigue. Thousands of users worldwide will lay testament to the performance benefits and rider/bike synergy that Pivot Pegz provide. And to cap it off Pivot Pegz are one of the few motorcycle products that actually save you money due to the fact that the pivoting nature extends the life of the soles of your riding boots. |
10-25-2012, 04:23 PM
#357 |
PAK-MEISTER.COM
Oddometer: 949
Just announced lower prices on the Snugpak Elite Series!
Elite 1 $125 Elite 2 $145 Elite 3 $175 Elite 4 $179 Elite 5 $195 http://www.cobraheat.com/SLEEPING-BAGS_c_85.html |
10-28-2012, 04:45 AM
#358 |
PAK-MEISTER.COM
Oddometer: 949
The Great Basin Saddlebag by Giant Loop is the largest member of our growing family of motorcycle luggage solutions. Designed specifically for bikes equipped with passenger pegs - BMW GSs, Suzuki V-Strom, KTM 950/990 Adventure, Kawasaki KLR 650, Triumph Tiger, Yamaha Tenere. The Great Basin™ is our soft luggage problem solver for adventure touring bikes. And yes, it fits most sport and sport touring bikes too, including Ducati, Honda and more.
$439.00 SPECS & FEATURES • Storm flap protects exterior zipper • 1 Hot Springs Heat Shield included (dual exhaust requires additional heat shield) • Seam Grip sealer and brush included • Designed and sewn in the U.S.A. • Easy on/off • No racks, mounts or braces needed • 50+ liter volume • Rides like it’s not even there • Slim, trim profile • Water resistant YKK zipper with double pulls • Water resistant Bomb Shell™ material (22oz vinyl coated polyester – truckers tarp) • Internal compression straps (2, one each side) • Roll-top center case • Removable pannier pods: zippered with webbing handle (2, one each side) • Contoured yellow nylon packcloth stuff sacks with drawstring top (2, one each side) • Exterior pannier reinforcements: super-tough 1050 Nylon Ballistic Cordura™ • Sewn with military-grade thread • Compression straps: 1-in. Ballistic Cordura and Nylike™ webbing with steel/aluminum cam buckles • 2 daisy chains: 1-in. Nylike™ webbing • Dimensions (fully packed): 55" - bottom of pannier, across top to bottom of other pannier bucket 9" - height of bag in top center 7" - distance from inside to outside of pannier bucket bottom 12" - front to back in top center • Includes seam sealing kit to maximize water resistance, detailed installation instructions and packing tips FITS THESE MOTORCYCLE MAKES & MODELS • BMW: GS models, etc. • KTM: Adventure 990, Adventure 950, 950se, 640, 690 (w/passenger pegs), etc. • Honda: XR650L (w/passenger pegs), TransAlp, etc. • Suzuki: V-Strom, DR650, etc. • Yamaha: Super Tenere, most other models (w/passenger pegs) • Kawasaki: KLR 650, etc. • AND JUST ABOUT ANY OTHER BIKE DESIGNED TO CARRY A PASSENGER (including Ducati Monster, MultiStrada and many others) http://www.cobraheat.com/Giant-Loop-...sin_p_329.html |
10-29-2012, 03:16 AM
#359 |
PAK-MEISTER.COM
Oddometer: 949
The Crossover™ by Snugpak® is another sought after and requested product. The Crossover™ is a great single shoulder strap day pack for anyone. With its single shoulder strap criss crossing over the owners chest it makes it easy to put on an...d take off as well as very comfortable. Also there is a small section of MOLLE webbing on the waist strap where someone could place and use a pouch for a cell phone, flashlight, knife etc. Also there is webbing on the shoulder strap as well where a phone or portable radio could be attached and also a hydration drinking tube could be routed and secured for easy access. The Crossover™ also has a hidden compartment that can be accessed from two different zippered openings. The concealed compartment has one panel completely covered in Velcro® to attach various pouches like maybe for a handgun, knife, mace, money, passport, etc.
Features •Zippered concealed compartment with Velcro® backing to attach a number of different pouches to secure and hold a handgun, knife, mace, passport or money etc. •Built-In Hydration Pouch •Waist strap can be used if desired or removed also in not needed •MOLLE Webbing on waist strap Specifications •Main Compartment: 1098 Cubic Inches / 18 Liters •Weight: 27 oz •Dimensions: Main (18” H x 11.75”W x 5”D) $67.50
10-30-2012, 03:47 AM
#360 |
PAK-MEISTER.COM
Oddometer: 949
Swedish designed Plastic Mess Kit packs neatly into itself, Includes: 2 Trays, Bowl, Small Fold-A-Cup, Stainless Steel Knife / Fork / Spoon set, Cutting board & 3 compartment condiment stacker.
Weight 10 oz Available Colors: Olive $35.00
