Old 11-01-2012, 04:04 AM   #361
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,419
KTM LC8 Light Bar
SW-Motech Auxiliary Light Mount (KTM LC8 Adventure 950/990 '02-'11) Bike-specific mounting brackets for adding auxiliary driving and/or fog lights. Designed for the KTM 950 & 990 Adventure LC8 '02-'11 for use with Denali LED Lighting or similar accessory lighting such as the PIAA Line. All mounting hardware and instructions included.
$55.00
NITRON RACING SHOCKS USA
(801) 663-7436 sales@nitronusa.com
NeedForSpeed is offline   Reply With Quote
Old 11-04-2012, 04:34 AM   #362
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Interphone F4 Pak-Meister.com
The new Interphone F4 is a robust and full featured Bluetooth multimedia and communication headset. The F4 installs on virtually any helmet in minutes. The 3 button design makes it easy to use while riding. The F4 Twin pack includes everything needed to set up two helmets.
The F4 has an intercom range of 500 meters. Its GPS instructions, smartphone pairing capabilities and wireless hi-fi stereo audio output make it a full-fledged multimedia entertainment system. The F4 intercom functions great for communicating with a passenger or another motorcyclist; and the music, phone and GPS features make the F4 equally handy when riding alone.
The Interphone F4 has a slim profile which makes it virtually unnoticeable on the helmet. The IP67 rating means that the F4 is unfazed by rain and moisture. Advanced digital noise cancellation makes communication at high speeds a breeze.
STEREO FUNCTIONS
- Wireless hi-fi stereo connection with Bluetooth® A2DP music players
- Remote controls music commands AVRCP
- Automatic resumption of the track from the exact point it had been stopped
- Incoming call signal
INTERCOM FUNCTIONS
- Bike-to-bike or pilot-passenger interphone connection
- Compatible with any previous versions of Interphone and Interphone F5
- Interphone connection with activation button
GPS FUNCTIONS
- Audio information from Bluetooth® GPS navigator
TELEPHONE FUNCTIONS
- Hands-free Dualphone (connection with two 2 telephones at the same time)
- Voice response
- Voice call
- Call refuse
Old 11-04-2012, 05:08 AM   #363
belay70
Oddometer: 1
Originally Posted by NeedForSpeed View Post
29 or 41 is up to you regarding how much space you need.
We do not sell racks or mounting hardware, the thought is that our panniers are universal fit with a mounting puck kit- and I recommend happy trails puck kit for the quality/price. I have the BMW OEM racks on my 1200ADV and run a 29/41 combo because of the exhaust cutout. But, I regularly throw on the Milspec panniers when I know I am going to be heading into the woods...
Assuming the Tiger XC OEM or aftermarket racks are symetrical- the 29 or 41 will both work well and look good.
We sold a set to a guy with the same bike- let me see if he ever sent a pic of them mounted up
Thanks,
Mike
Mike - Im about to purchase a 2013 Tiger 800 XC as well and I dont see those Happy Trails puck kits on the pakmeister website. In fact, it looks as if the Expedition series saddlebags ($395) wont fit up to this bike. Can you clarify? Thanks!
belay70 is offline   Reply With Quote
Old 11-09-2012, 05:37 AM   #364
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
give us a call and we'll walk through it
thanks,
Mike
Chief Adventurer
www.pak-meister.com
Old 11-09-2012, 05:42 AM   #365
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
G650GS / Sertao & F700GS Parts
F700GS – current items which fit this new model:
http://www.cobraheat.com/BMW-F700GS_c_134.html
Part No
Description
4000
Radiator guard SILVER
4001
Radiator guard BLACK
8114
Rear Rack - BLACK
8014
Rear Rack - SILVER
8003
Headlight Guard - BLACK
8003P
Polycarbonate Headlight Guard
8013
Fat foot
8999
Rear splash guard
G650GS / Sertao - current items which fit this new model:
http://www.cobraheat.com/BMW-G650GS-Sertao_c_133.html
Part No
Description
1000
Rear Splash Guard - BLACK
1083
Rear Brake Master Cylinder Guard - BLACK
1084
Radiator Guards - SILVER - SET OF 2
1085
Radiator Guards - BLACK - SET OF 2
1086
Rear Brake Master Cylinder Guard - SILVER
8100
Rear Brake Res Guard - BLACK
8000
Rear Brake Res Guard - SILVER
1092
Chain Guard & Rear ABS Sensor Guard - SILVER
1093
Chain Guard & Rear ABS Sensor Guard - BLACK
Old 11-10-2012, 04:10 AM   #366
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
KTM LC8 Engine Guard Skid Plate
SW-MOTECH aluminum engine guard/skidplate (KTM LC8 Adventure 950 & 950/S, & LC8 Adventure 990 & 990/S, '06+ Constructed of 3mm-thick aluminum for heavy-duty, light-weight protection. Baseplate includes side protectors that wrap around the engine block to provide both bottom and side protection. Available in bare aluminum/brushed silver finish or a durable powder coated black.
http://www.cobraheat.com/LC8-Engine-...ate_p_313.html
Old 11-11-2012, 11:58 AM   #367
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Powerhub Fuseblock
The PowerHub fuse block allows you to safely connect up to 6 electronic devices to your motorcycle in a clean, workmanlike manner.
Includes six 10-amp fused outputs, six ground posts, and a plug-and-play wiring harness for direct battery hookup.
Each of the six outputs can be individually set as "always on" or "switched" on/off with the ignition of the motorcycle.
Instead of attaching multiple ring terminals to your battery, use a PowerHub!
We designed the CANbus-safe PowerHUB to allow simple and easy installation of electrical components.
Each unit has six individually fused outputs.
These are not your ordinary outputs.
Simply plug the fuse in to the left or the right on the circuit board to make the accessory live all of the time or switched on/off with the bike's ignition. The main power into the relay is fused for additional protection. The entire unit is rated for 30 Amps (360 watts). Each of the six circuits can handle up to 10A (120W) each - without exceeding a total sum of 30 Amps simultaneously. Features: • Weather-resistant • Compact • Durable • Choice between switched and constant power • 2 holders for spare fuses (Mini-buss fuses easily available in an emergency) Specs: • Dimensions: L 3.25" x W 2.5" x H 1.25" • 6 circuits can handle up to 10A (120W) each • CANbus-compatible • 16 gauge wiring harness with in-line fuse and Posi-lock connector What's in the Box: • PowerHub fuse block • Mounting hardware • 6 mini ATC fuses (one 2-amp, two 3-amp, one 5-amp, two 10-amp) • Fused wiring harness for connecting PowerHub to battery (includes pre-attached ring terminals and switched "trigger" wire with Posi-tap connector) • 1 30-amp ATC fuse for wiring harness • Self-adhesive hook and loop pad for providing a quick-release attachment method for connecting the PowerHub to a flat surface Can I hook up a battery charger to my motorcycle via the Power Hub? YES. Just be certain you place the fuse in the position for continuous power.
$115.00
Old 11-12-2012, 03:00 AM   #368
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Softie 6 Kestrel
Description
A tried and tested favourite, this British made sleeping bag combines micro pack size with serious performance.
The Softie 6 Kestrel, the backbone of the British Royal Marines offensive in the gulf, no other private purchased sleeping bag was as widely used in this conflict. Because of the excessive heat during the day and the heavy conflicts occuring they required a sleeping bag that was extremely lightweight and a compact pack size but with the ability to handle the sub zero temperatures of the desert nights.
Features:Snugfit Hood
The quilted top of the bag is tailored, pleated, and fitted with a drawcord so it pulls into shape, rather like a jacket hood.
Anti-snag Zip
To prevent the 2-way zip from snagging either the zip baffle or the bag edges, an "anti-snag strip" of webbing is sewn in behind the zip. (All zipped bags.)
Liner Fastening and Hanging Tabs
Inner tabs are provided to keep a loose liner in position, corresponding in position with the tabs we provide on our liners. External tabs allow you to easily hang the bag for airing and drying.
Circle Foot
Tapering the bag to a circle foot creates the "mummy" shape which is easy to warm and minimises the weight of material used.
Zip Baffle
Hard to see in the picture, but a zip baffle runs the full length of the bag, behind the zip,to prevent heat escaping through the zip area.
Re-inforced Foot
Sleep with your boots on!
Zip Together
Buy a left and a right hand to make a double (please check when ordering)
Made in the UK
This product is uk made start to finish at our factory in West Yorkshire, England.
Compression Stuff Sack
Comes complete with a compression stuff sack, to make the bag smaller when not in use.
Wider bag (extra)
Can be used with the Snugpak Exanda Panel to make a wider sleeping bag for more comfrot.
Extra Length
This sleeping bag can be make extra long, please ask for more details.
Construction
Single profiled sleeping bag with one layer of softie insulation.
Sleeping Bag Type
Mummy shaped
Zip Type
Full length side zip, in either left or right hand.
Old 11-13-2012, 02:06 AM   #369
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
These MK3 Pivot Pegz are precision built and made from solid aerospace grade stainless steel, polished to a mirror finish and designed to perform like no other peg. You get the Ferrari of the footpeg world at a great price. Pivot Pegz are a...patented, race proven product that actively tracks with the motion of the riders foot to provide superior grip and load distribution whist reducing impact and fatigue. Thousands of users worldwide will lay testament to the performance benefits and rider/bike synergy that Pivot Pegz provide. And to cap it off Pivot Pegz are one of the few motorcycle products that actually save you money due to the fact that the pivoting nature extends the life of the soles of your riding boots.
Mark 3 Pivot Pegz
$169.00
Old 11-14-2012, 05:01 AM   #370
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Coming Soon! Interphone iPad Mount
Water resistant iPad® holder for motorcycles and bicycles universal holder for devices up to 9.7”. Your iPad® is carried in an extremely sturdy, practical case whose interior is lined with knock-proof mate...rial. The holder can be fixed to the handlebar simply and quickly, thanks to a practical, adjustable bracket. Since the base can be rotated 360°, you can position the screen at the visual angle that is just right for you. The water resistant case and zips enable the case to be used in any weather, and your touch screen display is completely functional through the special crystal film window.
AVAILABLE FOR PRE-ORDER SHIPPING MID DECEMBER
$85.00
http://www.cobraheat.com/BIKE-COMMUNICATION_c_92.html
Old 11-14-2012, 05:52 AM   #371
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
WarmSeats Seat Heaters
WarmSeats Waterproof Seat Heater
(Motorcycles, Snowmobiles, ATV's & Golf Carts)
SALE PRICE $49.95
SAVE $20.00
The comfort and pleasure of a heated seat is now available for your motorcycle, snowmobile, and ATVs. Our WarmSeats © waterproof seat heaters quickly provide comforting warmth to the rider or passenger through the seat cushion. The thin waterproof seat heater element fits invisibly under the seat cover.
Illuminated High/Low switch
Dual-Temp Seat Heater operates at approximately 115 degrees.
Heats up quickly Fits most types of motorcycle, snowmobile and ATV seats
Pad size 7.75" x 15.5 "
Low power consumption
1.5 AMPS
Easy DIY installation
3 year / 36,000 Mile Manufacturer's Limited Warranty
http://www.cobraheat.com/WarmSeats-W...-ATV_p_10.html
Old 11-20-2012, 02:49 AM   #372
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Black Friday SMH10 Sale!
1. LIKE
2. SHARE
3. SAVE
http://www.facebook.com/pages/PAK-ME...94302333972063
NeedForSpeed screwed with this post 11-20-2012 at 11:15 AM
Old 11-21-2012, 03:54 AM   #373
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
We need 2 more Deal Share participants on FB for the Black Friday Sena Sale!
Old 11-21-2012, 04:01 PM   #374
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
Starting on Black Friday and extending through until 21 December, anyone placing a retail order totaling $200 or more (excluding any shipping costs and the value of the promo items) can claim a free Kriega gift worth up to $54!
US Residents only.
http://www.cobraheat.com/KRIEGA_c_78.html
Old 11-23-2012, 03:27 AM   #375
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,419
1. Like
2. Share
3. Save
Times are GMT -7.   It's 10:42 PM.
