Old 01-03-2013, 04:00 AM   #406
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 948
Giant Loop Great Basin @ Pak-Meister.com
The Great Basin Saddlebag by Giant Loop is the largest member of our growing family of motorcycle luggage solutions. Designed specifically for bikes equipped with passenger pegs - BMW GSs, Suzuki V-Strom, KTM 950/990 Adventure, Kawasaki KLR... 650, Triumph Tiger, Yamaha Tenere. The Great Basin™ is our soft luggage problem solver for adventure touring bikes. And yes, it fits most sport and sport touring bikes too, including Ducati, Honda and more. We put the bag where the passenger goes. Tell your buddy to get her own bike – that seat’s taken!
$419.00
http://www.cobraheat.com/Giant-Loop-...sin_p_329.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
NeedForSpeed is offline   Reply With Quote
Old 01-04-2013, 03:00 AM   #407
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
These guards provide extra protection to the fuel tank in case of a fall. Manufactured with high grade materials and anti-vibration fixings and finished in Matt Black. They also come in very handy to attach the Kriega US5 Dry Pack bags for ...additional waterproof storage! (sold seperately) These tank guards will only fit with the OEM Upper Crashbars that are fitted as standard to the Adventure model. * All BMW R1200GS Adventure models * Silver or Black * sold in pairs
$125.00
http://www.cobraheat.com/BMW-R1200GS...rds_p_278.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-09-2013, 05:07 AM   #408
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
The All Weather Shelter is the most versatile multi-purpose shelter for “ALL WEATHER” conditions protecting you from the sun, wind, rain and snow. Designed by Military Veterans and avid Outdoorsmen. It can be configured and used as a Fly, P...up Tent, Lean-Too Shelter, Emergency Bivvi and the list goes on. With the components and features offered the All Weather Shelter has endless possibilities, only limited by ones imagination. The All Weather Shelter is ideal for those that travel light and move fast.
The All Weather Shelter measures 10’x10’ with grommets on each corner as well as numerous webbing tabs along each side. Also there are 3 webbing tabs across the spine when used as a fly. Also down two opposite side are plastic snaps which can allow it to be folded and snapped together to make an emergency bivvi if desired. Included also are 4 guy ropes with adjusters measuring 10’ in length and 8 ultra lightweight alloy stakes.
Constructed out of 210T Nylon Rip-Stop, PU Coated and is also UV Resistant. All seams are sealed and taped. Reinforced webbing tabs along sides. Available in Olive only.
$67.95
http://www.cobraheat.com/PROFORCE-Al...lter_p_32.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-12-2013, 03:35 AM   #409
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
The Kit Monster is now available in a 65 Liter version as well as the tried and trued 120 Liter version. Some refer to the Kit Monster as a carryall. It has a variety of handles and loops which allow the bag to be carried as a hold all, it ...can be worn on the back as a rucksack when you use the shoulder straps, or just a simple duffle type style gear bag. One unique feature of the Kit Monster that sets it apart from standard duffle type style bags is it is equipped with compression straps that allow the excess volume to be reduced, which in turns reduces the bulk of the bag. The Kit Monster also has grab handles on each end. This is great for those extremely heavy loads when you need a buddy to help you lift it into the helo or onto the boat. Also the grab handles on each end can also be used in conjunction with a carabiner to secure the Kit Monster to prevent it form moving around. A couple of other features are the heavy duty base and chunky zipper.
Available Colors: Black
Features
•Carry straps can be used as shoulder straps for heavier loads.
•Cinch / compression straps on all four sides to to reduce excess volume, which reduces the bulk of the bag.
•Curved zipper design to easily allow larger objects to be inserted and removed unlike conventional stright zippers.
Specifications
•Dimensions: 23"L x 15"H x 15"W
•Volume: 3966 Cubic Inches
•Weight: 46oz / 1.3kg
$55.50
http://www.cobraheat.com/Snugpak-Kit...iter_p_54.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-15-2013, 02:04 AM   #410
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
Kriega R25 backpack
The Kriega R25 motorcycle backpack has a quick release QUADLOC harness, which is our own tried, tested and highly recommended system, unique to the rucksack industry. An innovative & extremely efficient load-carrying system designed for mot...orcycle riders. Unlike conventional harness systems the load is carried on the hips & chest, transferring the majority of the load away from the shoulders and thereby preventing the neck strain experienced with regular rucksacks.Unique 4-point harness: transfering the load away from the shoulders and onto the chest & hips. Ergonomically designed with no arm restriction for long distance comfort and a 10 year guarantee.
$179.00
Get all your kriega gear here-
http://www.cobraheat.com/KRIEGA_c_78.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-16-2013, 12:34 PM   #411
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
R1200GS R1150GS Fork Guards
These Fork Guards were designed from experience gained in riding thousands of miles in all weathers. Effectively protects the most exposed part of the fork from dust, dirt and stones. Essential protection for off-road, however still very ef...fective against insects and tar for tarmac riders. Includes both right and left Fork Guards with all necessary fittings and clear instructions to mount installs in under 5 minutes. BLACK. Will fit all BMW R1200GS / GSA models Will fir all BMW R1150GS / GSA models
$89.95
http://www.cobraheat.com/BMW-1200GS-ADV_c_66.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-18-2013, 03:10 AM   #412
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
Snugpak Sleeper Xpedition
The Snugpak Sleeper Xpedition is the lowest rated temperature bag we offer under the Sleeper Series range of sleeping bags. Many have been surprised at the features and construction of the Sleeper Xpedition as these are things you would nor...mally expect to see in a much higher priced sleeping bag. Our engineers and design team really came up with a great 4 season bag here. For those that need a 0°F bag at a very reasonable price, then the Sleeper Xpedition is exactly what the Dr. ordered.
Available Colors: Olive, Black
Temperature Rating: 10°F to 0°F (-12°C to -17°C)
92 Oz
$89.00
http://www.cobraheat.com/Snugpak-Sle...ion_p_301.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-19-2013, 05:29 AM   #413
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
When youre traveling in areas where water quality is suspect, this unique water filtration bottle makes life easy. It gives you a convenient and low-cost alternative to boiling, purification drops and bottled water, and is suitable for trav...el throughout the world. Simply fill your bottle from any tap, stream, river or lake even in third world countries and enjoy safe, clean drinking water right away!
The NDūR 38oz Bottle contains an advanced filter designed and tested by Seychelle Research Laboratories one of the most sophisticated portable water purification devices in the world. Not only does it remove up to 99.99% of chemicals and other contaminants, it also protects you against viruses and bacteria to 99.9999% in water that other filters cannot remove. In addition it removes harmful heavy metals like mercury, lead, aluminum .
This lightweight yet durable bottle is made from top quality, BPA-free plastic, so its 100% safe. The tightly-fitting lid prevents spills, even when squashed in a backpack. And the no-touch spout prevents cross-contamination from your hands when you open it to drink.
With the NDūR 38oz Bottle, youll have instant access to safe drinking water anywhere in the world. Plus youll save money on bottled water, and reduce your plastic footprint by keeping hundreds of plastic bottles out of landfill.
Quick facts: Removes up to 99.9999% of contaminants Made from BPA-free plastic Filter can be replaced when needed or desired Filter Life = 100 Gallons Unique design prevents leaks No-touch spout avoids cross-contamination The pliable plastic used and the design allows for increased flow rate when squeezed.
$39.00
http://www.cobraheat.com/NDuR-Water-...-oz_p_253.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-20-2013, 02:32 AM   #414
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
1200GS/ADV Headlight Guard - Black
Protect your headlights from expensive damage due to wayward stones and other detritus with our heavy duty powdercoated aluminium headlight guard. The Headlight Guard is made from Powdercoated BS1470 5251...-H22 Aluminium. The fixing brackets are made of 316-S31 Stainless Steel. Color - Powdercoated Black. This item fits the following models: - R1200GSA Models from 2004 onwards and all R1200GS Models.
$105.00
Also shown: 1200GS Oil Cooler Guard, 1200GSA Auxillary Light Guards
http://www.cobraheat.com/1200GSADV-H...ard_p_185.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-20-2013, 02:53 AM   #415
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
For those of you with a fondness for the black rifle...
check out our sister website and facebook page for some high speed, low drag gear
Website
Facebook
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-21-2013, 04:15 AM   #416
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
Powerhub Fuse Block
The PowerHub fuse block allows you to safely connect up to 6 electronic devices to your motorcycle in a clean, workmanlike manner. Includes six 10-amp fused outputs, six ground posts, and a plug-and-play wiring harness for direct battery ho...okup. Each of the six outputs can be individually set as "always on" or "switched" on/off with the ignition of the motorcycle. Instead of attaching multiple ring terminals to your battery, use a PowerHub! We designed the CANbus-safe PowerHUB to allow simple and easy installation of electrical components. Each unit has six individually fused outputs. These are not your ordinary outputs. Simply plug the fuse in to the left or the right on the circuit board to make the accessory live all of the time or switched on/off with the bike's ignition. The main power into the relay is fused for additional protection. The entire unit is rated for 30 Amps (360 watts). Each of the six circuits can handle up to 10A (120W) each - without exceeding a total sum of 30 Amps simultaneously. Features: Weather-resistant Compact Durable Choice between switched and constant power 2 holders for spare fuses (Mini-buss fuses easily available in an emergency) Specs: Dimensions: L 3.25" x W 2.5" x H 1.25" 6 circuits can handle up to 10A (120W) each CANbus-compatible 16 gauge wiring harness with in-line fuse and Posi-lock connector What's in the Box: PowerHub fuse block Mounting hardware 6 mini ATC fuses (one 2-amp, two 3-amp, one 5-amp, two 10-amp) Fused wiring harness for connecting PowerHub to battery (includes pre-attached ring terminals and switched "trigger" wire with Posi-tap connector) 1 30-amp ATC fuse for wiring harness Self-adhesive hook and loop pad for providing a quick-release attachment method for connecting the PowerHub to a flat surface Can I hook up a battery charger to my motorcycle via the Power Hub? YES. Just be certain you place the fuse in the position for continuous power.
$115.00
http://www.cobraheat.com/TT-PowerHub...ock_p_401.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-22-2013, 03:39 AM   #417
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
Snugpak Softie Elite 2
$145.00
http://www.cobraheat.com/Snugpak-Sof...te-2_p_64.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-23-2013, 02:53 AM   #418
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
PAK-MEISTER Expedition Series Panniers 36L
The PAK-Meister Expedition Series 36L aluminum panniers have a lift-off lid with a wide, square shape that makes packing and unpacking a cinch. The high ground clearance of the boxes means you won...'t risk touching down a corner during fast riding or bottoming out the boxes going through deep sand or ruts. Loop handles on the lids are ideal for lashing down a dry bag or other supplies. Adventurers also love the additional space of the 9 wide square panniers.
36 liters = (18L x 9W x 15H in)
2 Steel latches
4 top loops for fastening additional luggage or straps
Removable lid with quick top access
Opens even with luggage rolls on top
Dimensions: 18L x 9W x 15H
Weight: 9 lbs. ea
Sold in Pairs *Mounting hardware NOT included
$395.00
http://www.cobraheat.com/PAK-MEISTER...es-_p_116.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-23-2013, 03:05 AM   #419
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 948
The Trekker Mat by MultiMat is quickly becoming the choice of many Military personnel. The Unique design and color combination sets the Trekker apart from the competition and the choice of Military Professionals. Self-Inflating Mats not onl...y provide a little extra comfort sleeping on top of rocks and other hard surfaces but also help to add a barrier between you and the cold ground beneath. The Trekker Mat is reversible with Olive on one side and Coyote on the opposite site.
Features:
•Super-fast valve giving 3x airflow of a regular valve for fast inflation/deflation
•Mats supplied with microfibre-lined stuff sack/pillow case, retaining band & repair kit
•Tough 150D Polyester top & bottom layer
•TPU membrane for air-tight seal
•Quality, lightweight, 20kg/m3 PU foam core for lasting performance and full inflation
$58.50
http://www.cobraheat.com/Trekker-Mat...Mat-_p_57.html
PAK-MEISTER
Adventure Grade.
www.pak-meister.com
Old 01-23-2013, 07:44 AM   #420
Widz
05 lurker.950adv/sm rider
Widz's Avatar
Oddometer: 80
The Multimat 25 Superlite is actually v.popular as I understand, at least with British troops. I have one and recommend it highly as its so lightweight. If you want to pay for the 35 version is thicker and very comfy. Both are better options than the noisy and fraglile thermorest neoairs.
What is the point of life?
KTM
Widz is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
