02-08-2013, 05:07 AM
#436 |
PAK-MEISTER.COM
Oddometer: 962
Customer submitted picture (BeerGut) of our 36L panniers on his KLR
Only $395 per pair (mounting hardware/racks not included) http://www.cobraheat.com/PAK-MEISTER...es-_p_116.html
02-10-2013, 03:55 AM
#437 |
PAK-MEISTER.COM
Oddometer: 962
Ktm lc8
SW-MOTECH aluminum engine guard/skidplate (KTM LC8 Adventure 950 & 950/S, & LC8 Adventure 990 & 990/S, '06+ Constructed of 3mm-thick aluminum for heavy-duty, light-weight protection. Baseplate includes side protectors that wrap around the engine block to provide both bottom and side protection. Available in bare aluminum/brushed silver finish $249.95
http://www.cobraheat.com/LC8-Engine-...ate_p_313.html |
02-11-2013, 03:44 AM
#438 |
PAK-MEISTER.COM
Oddometer: 962
EZ Pull Block & Tackle System
Outdoor Enthusiasts Hunting Camping Hiking Overland Travel ATV Riding Dual Sport/Adventure Motorcyle Riding Farm/Garage Use Emergency Situations /Survival (A Must have for your Bug Out Bag) 500 lb. capacity with a 5:1 reduction ratio 48 feet of Spectra cord gives 9 feet of travel weighs less that 1/2 pound and fits in your pocket! http://www.cobraheat.com/EZ-Pull-Block-Tackle-System_p_160.html |
02-12-2013, 02:59 AM
#439 |
PAK-MEISTER.COM
Oddometer: 962
Kriega Overlander 60
100% water, dust and sandproof packs. Constructed from double-stitched 1000D Cordura with reinforced sides and twin straps, which compress the load, whatever the terrain. 60L of stoarge (4 x 15L, 2 per side). Soft pack...s are the ultimate solution for extreme off road riding, with adjustable pack size and their flexibility on impact. Virtually indestructable CNC machined CDPE platforms, accept Overlander bags or Rotopax fuel/water containers. Overlander-60 comprises: 2 x ADV. platforms, 4 x 15L packs and all mounting hardware to connect to 18mm pannier frames (Touratech, KTM PowerParts, Metal Mule). Ultra-secure cam levers mount to frames with quick release for when the going gets really tough. $795.00 ![]() http://www.cobraheat.com/Kriega-Over...Set_p_283.html |
02-12-2013, 05:33 AM
#440 |
Thumper
Oddometer: 371
It always makes for a great day when you get home to find a package from Mike arrived!
Great guy to do business with ![]() Untitled by Frank Vest, on Flickr |
02-15-2013, 02:42 AM
#441 |
PAK-MEISTER.COM
Oddometer: 962
KLR650 Engine Guard Skid Plate- SW Motech
Constructed of 3mm-thick (1/8"-thick) aluminum for heavy-duty, light-weight protection. Baseplate includes side protectors that wrap around the engine block and the water pump housing to provide both bottom and side protection. Now available in a 2 tone black & silver finish. All hardware needed to mount the skidplate is included.
02-16-2013, 04:49 AM
#442 |
PAK-MEISTER.COM
Oddometer: 962
Kriega Hydro 3 has been designed specifically as an active riding pack with our unique Quadloc harness system. Providing a level of fit and comfort unequalled by any other hydration system. With a fully adjustable back-length and unrestrict...ed underarm movement. Once set, the pack is exceptionally convenient to use, with none of the harness strap re-adjustment necessary on conventional harness systems. The adjustable back also allows the pack position to be moved up to allow large waistpacks to be also worn. Hydro 3 can be worn with or without a waiststrap - we recommend to use a waiststrap for maximum stability, when carrying the full 3 litre (100 oz) water capacity.
$139.00 ![]() http://www.cobraheat.com/Hydro-3-End...ack_p_262.html |
02-16-2013, 09:16 AM
#443 |
PAK-MEISTER.COM
Oddometer: 962
Sneak Peak!
Performance Exhaust for the BMW 1150GS 1200GS F650 F700 F800
02-19-2013, 07:18 AM
#444 |
PAK-MEISTER.COM
Oddometer: 962
Giant Loop Zig Zag Handlebar Bag
New 2013 Model! $48.00 ![]() http://www.cobraheat.com/Giant-Loop-...Bag_p_421.html |
02-20-2013, 03:50 AM
#445 |
PAK-MEISTER.COM
Oddometer: 962
Kaoko Throttle Controls, Pivot Pegz, and Rox Risers in stock and shipping Daily
02-22-2013, 09:23 AM
#446 |
PAK-MEISTER.COM
Oddometer: 962
New Performance exhaust for the R1150GS, R1200GS, F800GS and the F700GS. Barker’s says it emphasized durability while building the systems, adding that other selling points are low sound and the fact that the systems are fully rebuildable using available parts. Future applications will be the Suzuki DR650, the Kawasaki KLR650 and the Honda X650R. :-)
Available Soon at www.Pak-Meister.com
02-23-2013, 05:34 AM
#447 |
PAK-MEISTER.COM
Oddometer: 962
Sena SMH10R at www.pak-meister.com
New Sena SMH10R Low Profile Bluetooth in stock and selling fast!
Bluetooth 3.0 Four-way Conference Intercom Multipoint Connection - Mobile Phone + GPS Conference phone call with intercom participant The SMH10R is a Bluetooth 3.0 stereo headset with long-range Bluetooth intercom designed specifically for motorcycle riders who prefer smaller form factor for maximizing their riding performance, yet maintaining rich features of Bluetooth intercom. With the SMH10R, you can call handsfree on your Bluetooth mobile phone, listen to stereo music or voice instructions of GPS navigations by Bluetooth wirelessly, and have intercom conversations in full duplex with other riders. Thanks to the latest Bluetooth and the advanced digital signal processing technology inherited from the SMH10, the SMH10R offers the best sound quality for both incoming and outgoing sound in its class. Also, its super thin and compact form factor contribute higher performance for sports bike riding and it makes the SMH10R a perfect companion of motorcycle riders. Features
02-26-2013, 04:03 AM
#448 |
PAK-MEISTER.COM
Oddometer: 962
02-26-2013, 06:16 PM
#449 |
PAK-MEISTER.COM
Oddometer: 962
F800GS Center Stand SW-Motech F800GS Center Stand The must-have accessory for sport-touring! Greatly eases basic chain maintenance, tire changes, parking, and bike cleaning. Super-strong steel construction features typical German design and... high engineering standards. Superb integration with the factory exhaust and sidestand components -- retain all existing features without sacrificing lean angle or clearances. All hardware needed to mount the centerstand included. Typically installs using basic hand tools. No welding, cutting, or drilling of existing frame or body parts required. Tough black powdercoated finish with some gray fittings or hardware as applicable. A double-retention spring is included as a safety feature to prevent the centerstand from contacting pavement if one of the two springs should fail during a ride. Designed to work with OEM components -- we cannot assure fit with aftermarket exhausts or other accessories. Special Note:We do not recommend installing centerstands on bikes with a lowered rear suspension because use on a lowered bike may result in: • ground clearance & cornering clearance problems, and difficulty in lifting the lowered bike onto the centerstand. Fits the following models: - F800GS - All Models $184.95
![]() http://www.cobraheat.com/F800GS-Center-Stand-_p_388.html |
02-27-2013, 04:30 AM
#450 |
PAK-MEISTER.COM
Oddometer: 962
NDuR Water Purification Bottle
NDuR Water Purification Bottle 28 oz. $39.00
When you're traveling in areas where water quality is suspect, this unique water filtration bottle makes life easy. It gives you a convenient and low-cost alternative to boiling, purification dr...ops and bottled water, and is suitable for travel throughout the world. Simply fill your bottle from any tap, stream, river or lake even in third world countries and enjoy safe, clean drinking water straight away. ![]() NDūR’s Portable Filtration Devices are the most laboratory and field-tested of their kind in the world using EPA protocols and tested to NSF/ANSI Standards 42 and 53 by Broward Testing Laboratory. Each contains an Advanced Filter that uses the advanced technology of Seychelle®. NDūR’s Advanced Filtered products remove what most other filters cannot; eliminating up to 99.9% of Micro-Organisms such as Giardia and Cryptosporidium, up to 99.99% of all chemicals and heavy metals, as well as up to 99.9999% of viruses and bacteria including E-Coli found in water sources. The 28oz Flip Top / Pull Top Bottles filter up to 100 gallons of water or more, depending on the quality of the source water. Seen as one of the safest, most convenient, low-cost alternative to boiling, purification drops and bottled water, and is suitable for travel throughout the world. Simply fill your container from any tap, stream, river or lake, even in third world countries, and enjoy safe, clean drinking water straight away. With NDūR’s Advanced Filtration System, you’ll have instant access to safe drinking water anywhere in the world. Key Factors for the 28oz Pull Top Bottle: • Made from BPA-free plastic • Filter Life: up to 100 Gallons or more, depending upon the quality of the source water • Ideal for those traveling abroad Removes up to 99.9999% of: • Virus • Bacteria - E-Coli Removes up to 99.99% of: • Chromium 6 • Chlorine • Lead • Mercury • Cadium • Aluminum • Copper Removes up to 99.9% of Micro-organisms, such as Giardia and Cryptosporidium NOTE: NOT FOR USE WITH SALT WATER |
