Old 04-03-2013, 07:02 PM   #466
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 1,348
Coming Soon! Interphone F5XT Single
We will start shipping April 26th
Order yours now!
PAK-MEISTER
Motorcycle Adventure Gear
CobraHeat LLC
A VETERAN OWNED AND OPERATED CO.
Nitron Shocks call (801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 04-04-2013, 03:48 AM   #467
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Snugpak Softie 3 Merlin-
International best seller and brand leader, this lightest and smallest of the Softie® sleeping bag range utilises space age technology in the form of a highly breathable metallised barrier (Relectatherm) to give a temperaturerating that exceeds expectations. Used in climates as diverse as the Australian outback to the foothills of the Himalayas.
$194.50
PAK-MEISTER
CobraHeat LLC
Old 04-05-2013, 05:52 AM   #468
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
The All Weather Shelter is the most versatile multi-purpose shelter for “ALL WEATHER” conditions protecting you from the sun, wind, rain and snow. Designed by Military Veterans and avid Outdoorsmen. It can be configured and used as a Fly, P...up Tent, Lean-Too Shelter, Emergency Bivvi and the list goes on. With the components and features offered the All Weather Shelter has endless possibilities, only limited by ones imagination. The All Weather Shelter is ideal for those that travel light and move fast.
The All Weather Shelter measures 10’x10’ with grommets on each corner as well as numerous webbing tabs along each side. Also there are 3 webbing tabs across the spine when used as a fly. Also down two opposite side are plastic snaps which can allow it to be folded and snapped together to make an emergency bivvi if desired. Included also are 4 guy ropes with adjusters measuring 10’ in length and 8 ultra lightweight alloy stakes.
Constructed out of 210T Nylon Rip-Stop, PU Coated and is also UV Resistant. All seams are sealed and taped. Reinforced webbing tabs along sides. Available in Olive only.
$67.95
PAK-MEISTER
CobraHeat LLC
Old 04-06-2013, 07:33 PM   #469
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Coming May 30th
Pak-Meister Adventure Roof Top Tent "The Base Camp"
See this at the Ga. Mtn Rally- Ra Rally- MOA Rally
(Dealer Inquires Welcome)
PAK-MEISTER
CobraHeat LLC
Old 04-11-2013, 09:57 AM   #470
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
SW-MOTECH skidplate
Constructed of a 4mm-thick aluminum base plate and 3mm-thick side plates for heavy-duty, light-weight protection. Where the base plates and side plates overlap, it forms a riveted 7mm-thick rail for extra rigidity. Base plate includes side protectors that wrap around the engine block to provide both bottom and side protection.
$269.00
PAK-MEISTER
CobraHeat LLC
Old 04-17-2013, 07:21 PM   #471
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
We are only a few weeks away from the debut of the PAK-MEISTER "BASE CAMP" Roof Top Tent!
PAK-MEISTER
CobraHeat LLC
Old 04-17-2013, 07:53 PM   #472
roscoau
roscoau's Avatar
Oddometer: 552
Now I just need one designed to mount on a trailer towed by my bike... hmmm?
Aussie Ural Owners
rosco.id.au
Ural - speed limits aren't a restriction, they are an achievement!
roscoau is offline   Reply With Quote
Old 04-23-2013, 06:40 PM   #473
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
PAK-MEISTER
CobraHeat LLC
Old 04-24-2013, 12:21 AM   #474
oz97tj
oz97tj's Avatar
Oddometer: 819
What does this indicate? The bike is bone stock. What do you have for it?
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 04-24-2013, 04:11 AM   #475
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
We have the following available (not up on the website yet) but will be posted in the next few days...
Swing arm slider
Front Axle slider
Upper engine crashbars
Lower engine crashbars
Aux light bar
Aux lights
On/Off Road footpegs
Pannier racks
TraX Panniers
Rear Top rack/ Box
Adjustable Gear lever
with a few more coming soon....
PAK-MEISTER
CobraHeat LLC
Old 04-24-2013, 04:29 AM   #476
oz97tj
oz97tj's Avatar
Oddometer: 819
Swing arm slider
Front Axle slider
Aux light bar
Aux lights
Pannier racks
TraX Panniers
Rear Top rack/ Box
Some of that stuff I'm interested in. At this point, the aux light bar I'm interested in most. Can you post info about that, or even just PM me?
'13 BMW 1200 GSW
'05 Honda ST1300
Old 04-24-2013, 01:38 PM   #477
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
we'll have it up on the website shortly (next 2-3 days) and update this thread when ready...
thanks!
PAK-MEISTER
CobraHeat LLC
Old 04-26-2013, 05:25 AM   #478
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
The first Pak-Meister "Base Camp" Roof Top Tent is off the production line- more pictures and video coming soon!
PAK-MEISTER
CobraHeat LLC
Old 04-29-2013, 07:38 PM   #479
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
We have the following available for the 2013 1200GS Liquid Cooled
Swing arm slider
Front Axle slider
Aux light bar
Aux lights
Pannier racks
TraX Panniers
Rear Top rack/ Box
with a few more things coming soon
PAK-MEISTER
CobraHeat LLC
Old 04-30-2013, 04:06 AM   #480
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
thanks for catching that- we've correct them.
the 1200GSLC parts will begin shipping next week!
PAK-MEISTER
CobraHeat LLC
Times are GMT -7.   It's 01:57 PM.
