Old 09-07-2011, 04:19 AM   #46
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,375
Thumb
Featured Product-
Softie 3 Merlin
A tried and tested favourite, this British made sleeping bag combines micro pack size with serious performance.
International best seller and brand leader, this lightest and smallest of the Softie® sleeping bag range utilises space age technology in the form of a highly breathable metallised barrier (Relectatherm) to give a temperaturerating that exceeds expectations. Used in climates as diverse as the Australian outback to the foothills of the Himalayas. Comes with reinforced foot as standard.
$194.50
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed screwed with this post 09-07-2011 at 04:27 AM
NeedForSpeed is offline   Reply With Quote
Old 09-08-2011, 04:03 AM   #47
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Thumb
Featured Product
Multimat Superlite Mat
Multimat Superlite Mat Temperature Rating: 14F to 112F (-10C to 45C)
The Superlite Mat is technically advanced, lightweight and compact- the ultimate in weight reduction.
The Superlite Mat is reversible with Olive on one side and Black on the other.
Super-fast valve giving 3x airflow of a regular valve for fast inflation/deflation
Mats supplied with stuff sack/pillow case, retaining band & repair kit
Color: Olive/Black
Length:: 72 in
Width:: 20 in
Weight:: 18 Oz
Pack Size:: 10.25 in
$84.15
CobraHeat LLC
(801) 663-7436
Old 09-09-2011, 04:29 AM   #48
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
The Crossover™ by Snugpak® is another sought after and requested product. The Crossover™ is a great single shoulder strap day pack for anyone. With its single shoulder strap criss crossing over the owners chest it makes it easy to put on and take off as well as very comfortable. Also there is a small section of MOLLE webbing on the waist strap where someone could place and use a pouch for a cell phone, flashlight, knife etc. Also there is webbing on the shoulder strap as well where a phone or portable radio could be attached and also a hydration drinking tube could be routed and secured for easy access. The Crossover™ also has a hidden compartment that can be accessed from two different zippered openings. The concealed compartment has one panel completely covered in Velcro® to attach various pouches like maybe for a handgun, knife, mace, money, passport, etc.
Features
  • Zippered concealed compartment with Velcro® backing to attach a number of different pouches to secure and hold a handgun, knife, mace, passport or money etc.
  • Built-In Hydration Pouch
  • Waist strap can be used if desired or removed also in not needed
  • MOLLE Webbing on waist strap
$67.50
CobraHeat LLC
(801) 663-7436
Old 09-10-2011, 05:01 AM   #49
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Featured Product-
Snugpak SOFTIE (Pile) Shirt
It doesn't get any better than this for a cold weather base layer!
Softie Shirt
Description
Same facade and features as the Pile Shirt, but the fibre pile is replaced with a layer of Softie insulation, Reflectatherm and TS1 (Thermal Suede) to give the same performance, but in a lighter more compressible unit, something to consider if you don't intend to wear the garment 100% of the time. A neck baffle similar to a sleeping bag has also been included to seal the collar. Supplied with its own stuff sack.
Colours available:
Technical Information
Sizes & Weights:
Small: 32-38", 700 grams
Medium: 38-42", 750 grams
Large: 42-46", 800 grams
XL: 46-50", 850 grams
XXL
: 50"+, 900 grams
*Snugpak jackets fit larger than standard
Shape / Style:Base Layer Pile Shirt
Temp Rating:
Comfort: -5°c
Temp Rating:
Extreme: -10°c
Fabric:
Lining:
$261.75
CobraHeat LLC
(801) 663-7436
Old 09-11-2011, 05:36 AM   #50
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Thumb
Featured Product
ProForce Warrior Saw
The Warrior Survival Saw is an excellent tool. Easy to pack away, lightweight & heavy duty Hand Chain Saw, ideal for cutting firewood in survival situations as well as for campers, backpackers, fishermen, hikers, homeowners or survivalists. A superb hand operated pocket sized survival chainsaw made from riveted sections of bi-directional chain-saw style cutting teeth. Extended longevity comparable to a traditional bow saw. Will cut anything from a thin branch to a large trunk and can be thrown over high branches for cutting above head height. Black nylon lanyard loop handles. $18.00
CobraHeat LLC
(801) 663-7436
Old 09-12-2011, 04:37 AM   #51
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Featured Product
Trekker Mat by Multimat
The Trekker Mat by MultiMat is quickly becoming the choice of many Military personnel. The Unique design and color combination sets the Trekker apart from the competition and the choice of Military Professionals. Self-Inflating Mats not only provide a little extra comfort sleeping on top of rocks and other hard surfaces but also help to add a barrier between you and the cold ground beneath.
The Trekker Mat is reversible with Olive on one side and Coyote on the opposite site.
Note: The pack size is determined when mat is mid-folded and then rolled.
Features
  • Super-fast valve giving 3x airflow of a regular valve for fast inflation/deflation
  • Mats supplied with microfibre-lined stuff sack/pillow case, retaining band & repair kit
  • Tough 150D Polyester top & bottom layer
  • TPU membrane for air-tight seal
  • Quality, lightweight, 20kg/m3 PU foam core for lasting performance and full inflation
$58.50
CobraHeat LLC
(801) 663-7436
Old 09-13-2011, 04:26 AM   #52
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
We are pleased to announce KAOKO to our product line
CobraHeat LLC
(801) 663-7436
Old 09-14-2011, 05:24 AM   #53
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Looking for a Good base layer for the colder weather?
Check out the Snugpak Pile Elite Shirt
The Pile Shirt has also been re-invented for the modern soldier, it now comes with a choice of two detachable hoods, a Paratex Nylon wind hood and a Paratex/Pile, both are supplied as a standard issue along with a compression sack. Hoods attach to a concealed Velcro strip.
$126.95
CobraHeat LLC
(801) 663-7436
Old 09-14-2011, 02:54 PM   #54
ChiefPilot
Rather be flying, but....
ChiefPilot's Avatar
Oddometer: 80
I just picked up some gear from NeedForSpeed and I can say the process was VERY easy and shipping was very fast. Adv code worked when checking out with no problems.
I got some travel / camping gear including a lightweight sleeping bag, fleece liner , small pack and a couple other things. I liked what the stuff looked like on the beb site so I decided to give it a try..
Top quality stuff and very lightweight. I'll be putting the sleeping gear to the test next week on a week long trip to the Black Hills. Thought I'd try the fleece liner in case it gets colder than anticipated while we're there. Kind of thinking I should have gotten the TS1 liner for something a bit more compact, but at my age I really hate sleeping cold and the fleece should be the ticket if the temp drops. Guess there will be another order in my future.
I also got one of the Turbo Lighters. That thing REALLY puts out the flame.
Should be perfect for the evening cigar by the campfire.
Deal with confidence.
'12 K1600 GT
'06 R1200GS Leaving the Garage Soon.....
If you are in trouble anywhere in the world, an airplane can fly over and drop flowers, but a helicopter can land and save your life. - Igor Sikorski, 1947
ChiefPilot is offline   Reply With Quote
Old 09-15-2011, 06:07 AM   #55
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Thanks for the plug ChiefPilot.
4,000 inmate pages views- don't be shy- if you have a question about one of the products let me know...
Our NEW 29L Panniers are in stock!
CobraHeat LLC
(801) 663-7436
Old 09-16-2011, 04:05 AM   #56
Jiro
Watch Out for Squirrel!
Jiro's Avatar
Oddometer: 639
since there's no mounting hardware for this... how does one usually mount this???
2003 F650GS
Ride Safe and Fast!
Jiro is offline   Reply With Quote
Old 09-16-2011, 04:49 AM   #57
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Use whatever rack you currently have (or purchase) and a mounting puck kit.
Thus, the panniers are Universal Fit for any make/model.
MilSpec Series with BMW rack
MilSpec Series with Moose rack
(Customer from NC)
I run the 41L Adventure cases on my R1200GS Adventure most of the time, but can switch over the the MilSpec panniers in 5 minutes for the dirt
CobraHeat LLC
(801) 663-7436
Old 09-16-2011, 04:54 AM   #58
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
The 41L Panniers are in stock as well. Will start shipping early next week
CobraHeat LLC
(801) 663-7436
Old 09-19-2011, 04:23 AM   #59
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Featured Product
Snugpak Xocet 35
The Xocet 35® by Snugpak has been getting rave reviews from those that have been fortunate to get a sneak peak at it. The Xocet 35® has a lot of great features that many will like and appreciate. There is a roomy main compartment for your gear with a Hydration system sleeve and an outlet port through the top to run the drinking tube. Also the main compartment has an organization system to help store and arrange various items. There is also a zippered storage pocket for those items you want to keep secure and accessible. There is also a front storage pocket to conveniently put items that are needed at a moment’s notice. Also both sides have a mesh pocket with bungee cord tensioning for items such as water bottles and clothing. Lastly the Xocet 35® has 5 rows of MOLLE webbing on the pack to allow the user to add MOLLE compatible system pouches they might need such as utility, accessory, ammo, radio, etc.
Features
  • Velcro® Strips for Flag & Unit patches as well as for Name and Rank tapes
  • Padded shoulder straps with an adjustable sternum strap
  • Hydration System compatible
  • Internal organizer for small items and tools
  • Waist strap can be secured in hidden compartment to stay out of the way when not needed and then there when it is needed
Specifications
  • Main Compartment: 2135 Cubic Inches / 35 Liters
  • Weight: 38 oz
  • Dimensions: Main (19” H x 12”W x 8”D)
$93.50
CobraHeat LLC
(801) 663-7436
Old 09-20-2011, 03:40 AM   #60
NeedForSpeed OP
Nitron Shocks USA
Oddometer: 1,375
Featured Product
Snugpak Softie Elite 1
The sleeping bag has evolved to the next level. Snugpak EPS (Expander Panel System) bags give versatility to tackle any adventure. The key is its ability to control temperature and comfort by being able to transform from a warm, snug sleeping bag into a cool and spacious one.
The bag boasts all the features of traditional sleeping bags but the jumbo zip baffle can be opened out to give much more room when needed. The extra space within the bag allows more air to move aroundkeeping the bag cooler.
This temperature management gives your bag much more flexibility allowing you to confidently select a product that can perform in a range of conditions, so that when the
Outer Fabric:
Inner Fabric:
Filling:
Activity: Travel, Trekking
Season: Warm Weather/Indoor Use, 2 Season - Late Spring
Origin: Imported
Weight Category: 1 to 1.5kg
Features: Expanda Panel System
$135.50
CobraHeat LLC
(801) 663-7436
Times are GMT -7.   It's 06:21 PM.
