Old 07-21-2014, 05:00 PM   #121
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Originally Posted by SFMCjohn View Post
My first spin around the block and big smile.
Kalle Hoffman
San Francisco, CA
kallehof is offline   Reply With Quote
Old 07-21-2014, 05:26 PM   #122
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
California Indain Run
Wow! Now I've got a running 1937 Indian Chief. So I brought it to the California Indian Run which is organized by Indian Rick Decost and hosted at Spanky's Ranchoria in Smartsville, Ca.
Dennis Magree, his son Dominic and Myself with my chief. I was having some troubles with a vacuum leak on the intake manifold. So long street rides were not in order. But I had a chance to show off the bike.
Dennis Magree's 1936 Chief that he has ridden to Alaska and back several times. He let me ride it several times over the weekend which was a real treat. 30's rigid chiefs sure are nimble compared to the plungered Chief of the 40's.
Field Games
I won the board game. The secret is to look straight ahead and not at the board.
Cute Girl with broken bike on our Saturday Ride.
On Saturday we stopped in Washington, California to cool down and have a drink at the Washington Hotel.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-21-2014 at 05:31 PM
Old 07-21-2014, 05:44 PM   #123
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,492
Kalle, it great to see those old bikes out and being enjoyed!
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 07-21-2014, 05:55 PM   #124
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Manfold Leak
All seemed well. With the exception of a manifold leak which made for a very hard to start bike.
Red Fred and I pressurized the manifold on my 37 and soaped down the manifold nuts and heads to look for the leak. We did note a leak between the front cylinder nipple to manifold. We tighten the nut but it still leaked.
We also noticed that there seems to be a groove/step in the manifold and blemish on the brass ring where the leak is on.
At this point I sent an email my My engine builder Jim to see what he thought.
He suggested I try PEEK Manifold Rings. PEEK (polyetheretherketone) is a linear aromatic semi-crystalline thermoplastic developed in the late 1960’s. It has a melting point of 650F (343C) with a continuous use temperature of 500F. It has outstanding creep resistance for an engineering thermoplastic material and can sustain large stresses over a useful service life without significant time induced extrusion.
If your manifolds are absolutely pristine, and of full dimension, then you
may save money and time with mass-produced PEEK Manifold Rings seals from enfield racing. http://www.enfieldracing.com/8.html
But if your manifolds' spigots are worn or blemished, then Cotten of Liberty Motorcycle Specialties, Inc. can offer a solution, as he can custom machine seals for you.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-21-2014 at 08:21 PM
Old 07-21-2014, 06:10 PM   #125
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Oil Changes - and Breaking It In
Now this is topic is half individuality and half science. But I just picked an Indian Guru to follow and stuck with his recommendation on the engine break in.
  1. Non detergent 30 wt oil for the first start up. 90% of the initial wear is in the first five minutes.
  2. Drain oil
  3. 30 wt oil for the first 50 miles - Compression breaking - varied rpm
  4. Drain oil
  5. 50 wt oil for the next 500 miles - varied rpm - not too fast.
  6. Drain oil
  7. 50 wt oil changed every 3000 miles - I use Valvoline VR1 Racing 50 wt oil which is stocked at my local auto store and readily available. "Any oil is good oil, as long as you have some oil".
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-22-2014 at 01:28 PM
Old 07-21-2014, 06:22 PM   #126
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Rigid Ride
With my vacuum leak solved I sign up for Pete Young's Rigid ride. It would be the first real test of my chief. 180 miles of twisties. From Portola Valley to Pigeon Point Lighthouse and back.
The group of rigid riders at Pigeon Point light house just south of Half Moon Bay.
My Rigid.
1939 Chief
My 1937 Chief at San Gregorio General Store.
Kalle Hoffman
San Francisco, Ca
kallehof screwed with this post 07-22-2014 at 12:51 AM
Old 07-21-2014, 06:30 PM   #127
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Tranmission Woes
During the Rigid Ride the lock washer on the clutch nut failed and the nut backed off. I made it home but after noticing an oil leak I pulled the top of the transmission tower and found this. This is a known short coming of Indians. The nut is small and the experienced Indian rebuilders say that they tighten the crap out of this nut. But even then, it still can fail.
A lock washer that didn't
Sheared rivets on the generator drive.
Wear on the inside of the primary.
Ugly!
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-22-2014 at 03:39 PM
Old 07-22-2014, 10:31 AM   #128
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Brooks Auction Chief
Here's a Chief (34 or 35) I saw at the Brooks Auction a few years ago and again last year on the Rigid Ride.
Now owned by a local Yerba Buena AMCA member Clay.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-22-2014 at 03:49 PM
Old 07-24-2014, 12:53 PM   #129
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Battery
My basket case came with an older reproduction battery shell. Not correct for 1937 but it is nice to have extra shells around when you have Indians. All of my bikes have been converted to 12 volts so a hollow battery case is the best place to store a modern 12v battery. I buy the largest battery that will fit inside the hollow 6 volt case. Suzuki V Strom 650 battery works for me.
The shell was miss the lead posts.
A deep socket from my tool box had a .500" outside diameter and some quick set plaster made for a quick and simple mold.
I collected up some old tire weights and melted them with a propane torch.
Kalle Hoffman
San Francisco, CA
Old 07-24-2014, 04:08 PM   #130
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Valve Covers and Oilers
In a total loss system the oil is not circulated, It is wasted, Usually on the drive chain. I've read articles and advertisements that boast virtues of your engine always getting clean oil in a total loss system. Early 10's and 20's operator manuals describe the oiling rate in terms of miles per quart right next to miles per gallon of gas. On the 1936 and 1937 Chief even thought there is an oil pump that recirculates the oil from the sump back into the reservoir. There is still one relic of the total loss days, the valve oiling lines. They allow oil to "mist" up from the cam shafts to the valve stems. I've heard that they were not installed in late 1937 chiefs and the holes were plugged with a rounded set screw. The numbers on my bike are mid 1937 and I like the look of the oilers. And I had heard stories of them making a mess when functional, so I had "dummy" oil lines fabricated and installed.
Another note here is that in 1937 the valve covers are "Clam Shells". In 1938 Indian went to a better design where the valve covers screw together. In my case the covers are chrome and the oil lines are nickle. Hope I got that right.
You can see that the last three or four cooling fins behind the oil lines need to be shorter than the ones above. If you think you have 1937 cylinders but these fins are not trimmed and you have a high number engine that may indicate that your bike may not have come with the oilers from the factory. The lower fins on earlier 1935 cylinders would not be trimmed. The casting numbers on the cylinders in 1937 should be 85612 and 85614.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 07-24-2014 at 05:30 PM
Old 07-24-2014, 10:08 PM   #131
Prmurat
Prmurat's Avatar
Oddometer: 1,036
Nice Indian!! I wish I'll be able to use my -48 Chief soon (bad leg... Can't start it: how humiliating!!); i'll miss the rigid ride but will for sure on the 49ers (if I cant install the Kiwi ES!).
Prmurat is online now   Reply With Quote
Old 07-29-2014, 05:02 PM   #132
SFMCjohn
13
SFMCjohn's Avatar
Oddometer: 906
Hey Kalle,
Wonderful posts, beautiful bike ...
Nice also to see Clay's Brooks Indian back on the road, too ...
see you around the campfire,
-- SFMCjohn
caryandjohn.blog: Baja, KLR, & '73 Tiger Ride Reports
San Francisco Motorcycle Club, Est. 1904
Let's Ride!: BAARC and Old's Cool Ride Reports Index
IBA#'98onaEX500
SFMCjohn is offline   Reply With Quote
Old 08-01-2014, 02:12 PM   #133
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Rigid Tandem
No chum-mee seats in 1937. If you wanted to carry a passenger you either got a side car or a Tandem Seat. Here's a rigid chief with tandem seat spotted in Italy.
Tandem Seat
What year is it? Lots.
* rigid frame <=1939
* large cylinders >=1940
* handlebar mounted headlight <=1937
* screw on gas take caps <=1936
* large chain guard >=1937
* frame mounted shift lever >=1937
* Oil Pump >=1938
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 08-01-2014 at 02:22 PM
Old 08-05-2014, 11:16 AM   #134
kallehof OP
kalle
kallehof's Avatar
Oddometer: 111
Research
If you thinking of restoring an Indian Jerry Hatfield's Restoration Guide is an excellent place to start.
First additions of this book are a bit spendy but later additions will run you from $50-$100.
I use Jerry Greer's parts catalog for all my assembly guidance. It has excellent parts diagrams and parts lists. And it's Free.
The original factory documentation and parts list is the no non-sense go to for a restoration's correctness.
Moan's Virtial Indian Website http://www.virtualindian.org/ is an excellent resource for all things Indian. I look forward to his yearly xmas additions. There is also a Yahoo email list anyone can join https://groups.yahoo.com/neo/groups/VirtualIndian/info.
Your local AMCA chapter is a good place to start too. Here is San Francisco I'm a member of the Yerba Buena Chapter.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 08-05-2014 at 11:28 AM
Old 08-06-2014, 12:38 PM   #135
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,480
Is there a plan for paint? It seems like the shake down is about finished.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Times are GMT -7.   It's 08:34 AM.
