Old 07-26-2011, 05:24 PM   #1
Michelangelo OP
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,721
What grease for steering head bearings?
yes I tried the 'search' feature.
Looking for something that can be bought at a local Checker, Pep Boys or Wal Mart and not some special Honda or KTM labeled super slick expensive stuff that has to be ordered.
Want to be able to use for steering head bearings, shock linkages and wheel bearings when needed. Up to now Ive used the red, heavy duty grease for my bearings and shock linkages with occasional steering head bearing set too.
Dirt and offroad motorcycle tours...
ALL MOTO ADVENTURE,LLC.
www.AllMotoAdventure.com
Michelangelo is offline   Reply With Quote
Old 07-26-2011, 05:41 PM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,631
I use BelRay waterproof grease. Whatever you get just be sure it's waterproof grease and everything will be fine.
you don't see luggage racks on a hearse..........act accordingly
Old 07-26-2011, 06:04 PM   #3
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,768
the quart tub of red heavy duty wheel bearing grease is what I go to when I want something to stay slippery (that didn't come out right).
Unless I know it'll be high temperature, then it is the synthetic brake grease from a tube.
Isn't all dino grease waterproof? Or am I missing something?
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 07-26-2011, 06:28 PM   #4
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,695
Originally Posted by anotherguy View Post
i use belray waterproof grease. Whatever you get just be sure it's waterproof grease and everything will be fine.
+1
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 07-26-2011, 07:35 PM   #5
anotherguy
anotherguy's Avatar
Oddometer: 6,631
When churned up by bearing action some greases will mix with water and lose all lubricating properties. Just read the label and be sure it states clearly it's waterproof.
Old 07-26-2011, 08:55 PM   #6
P B G
Oddometer: 10,001
Ya, luckily there are a ton of waterproof axle/wheel bearing trailer greases that are more than sufficient for steering head bearings.
Sadly what kills steering head bearings isn't so much the lubrication as the fact that bearings are designed to spin, and you go thousands of miles with just a few degrees of turning left/right with the majority of that in a couple degrees of middle and straight ahead vibrating.
Old 07-26-2011, 11:25 PM   #7
troidus
Oddometer: 15,300
Which makes me wonder why they use tapered rollers instead of sleeve bearings.
troidus is offline   Reply With Quote
Old 07-27-2011, 04:44 AM   #8
P B G
Oddometer: 10,001
Sleeve could still oblong under that sort of continuous load, and would probably bind more rapidly when worn than a tapered roller does when notched.
The service life of those bearings is pretty good on road bikes.
I would take one where the race was mounted in a unit that could be rotated periodically. Set screw and turn it 15 degrees counter clockwise and go another 30K.
Old 07-27-2011, 05:38 AM   #9
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
+1
use waterproof grease. another cause of wear is loose stem lock nut. play in the stem will destroy them quickly.
current bikes
stainlesscycle is offline   Reply With Quote
Old 07-27-2011, 05:42 AM   #10
DRZ400SK4
DRZ400SK4's Avatar
Oddometer: 2,047
OMC Triple Guard.
It can be bought at any boating or marine supplies shop, and it's designed to stand up to the rigors of marine use. Great stuff for suspension links, head bearings, and wheel dust seals. Pretty much as waterproof as any grease can be.
2008 Yamaha FZ1 / 2009 Kawasaki KLX450R / 2012 Triumph Scrambler
My Photos In Google Earth
DRZ400SK4 is offline   Reply With Quote
Old 07-27-2011, 06:36 AM   #11
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
MOREYS BIGFOOT EP GREASE
Description:
CATEGORICALLY THE BEST HIGH TEMPERATURE /MULTI-PURPOSE/ TACKY-ADHESIVE EP GREASE FOR HEAVY DUTY, SEVERE SERVICE APPLICATIONS. Product Description: BIGFOOT GREASE is a superior Lithium Complex Grease to provide excellent lubricating qualities over a wide range of temperatures. Designed for work under the toughest conditions in operating temperatures from -40F to +450F (-40C to +200C ), with excellent mechanical and chemical stability. BIGFOOT is the grease designed to always ''stay in place'' under the worst operating conditions of water-dirt-mud, providing maximum protection.
When they say tacky they mean tacky.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 07-27-2011, 07:45 AM   #12
Michelangelo OP
Oddometer: 1,721
that's great an all, what with all these fancy names and brands but my initial question still stands: can these be had at a local auto shop or walmart? That is the key to my post.
Old 07-27-2011, 07:53 AM   #13
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Sure just read the label.
Old 07-27-2011, 08:50 AM   #14
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,133
Sta-Lube PN# SL3151
It is NLGI #2 white lithum, EP, water proof grease.
NAPA carries it. It's boat trailer, wheel bearing grease. Exact cross reference to the grease called for in a Honda service manual for steering head bearings.
Wasser is online now   Reply With Quote
Old 07-27-2011, 04:50 PM   #15
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,206
I use that grease also (for most everything) and I've always wondered what makes it 'waterproof' over other greases which are not ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
