Old 09-25-2011, 10:16 PM   #91
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
Great job Luke!!!! I was very impressed when I first saw the bike at the meet up last week, now i have found the thread to read along.
Drtyfun is offline   Reply With Quote
Old 09-26-2011, 01:21 AM   #92
troidus
Oddometer: 14,238
I've kicked around the idea of converting my '89 JS440 JetSki to electric. One problem is that the whole system has to be waterproof, not just water resistant. Also, boats are constant load, so there is no coasting to save power, meaning that runtime will be an issue. It should run for at least 90 minutes, or it'll be disappointing. There should also be a "reserve", some smaller pack in the battery bank that will at least get it to shore if I misjudge and run out of juice in the middle of a lake.
troidus is online now   Reply With Quote
Old 09-26-2011, 08:56 AM   #93
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,423
Combining a backhanded compliment with spam. Well done.
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is offline   Reply With Quote
Old 09-26-2011, 09:07 AM   #94
Cody1771
Cody1771's Avatar
Oddometer: 246
no kidding... wicked project! awsome work.
Cody1771 is offline   Reply With Quote
Old 09-30-2011, 05:47 PM   #95
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
So it's been a while without any updates, so here's a little one.
I've been messing with the charging system; building the charger into a portable box, and doing a bunch of invisible fussing with the electronics. It's paying off- the same battery pack gives about 25% more range than it did before. There's also a fair bit to do to make the throttle response better; MX tires on wet rocks give a lot of wheelspin.
The wooden box is the charger- it takes 1 hour to charge at home, 3 hours from the truck. With a bit more work it should be able to charge this sized pack in around 1/2 hour. For any more remote charging I'll get a generator. 3 hours is a long time to charge, especially when I have to keep my truck running.
Here's the last run of the day. I got hung up on a root hole midway through and had to lift the back of the bike out- but it's so light that that's easy. And of course, the battery ran out right at the very end.
Luke is offline   Reply With Quote
Old 09-30-2011, 06:21 PM   #96
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,721
Lookin good!
Gotta remember to ride up hill so you can coast back
Mr. Fisherman is offline   Reply With Quote
Old 09-30-2011, 11:44 PM   #97
knary
knary's Avatar
Oddometer: 29,423
How is throttle control working out now that you've had it out in the woods?
Goodbye Toolfan
Old 10-01-2011, 12:44 AM   #98
Sequoia
Oddometer: 246
Saving weight
I read through the entire thread & didn't see anything about belt drives so I thought I would mention it.
Remember Harleys have belt drives so you should be able to find one somewhere close to what you need through
Gates Belts or ?? It's not going to save you a whole lot of weight but it is rotating weight & should help out some when you get to that point.
I can see you lightening up the cases that hold the batteries too, I know that wood fiberboard isn't light.
Great job on the build though I like it.
Sequoia is offline   Reply With Quote
Old 10-01-2011, 02:34 AM   #99
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
It works well as long as I'm moving. Not so well when I get stuck :) Then the back wheel really likes to spin up. That makes it hard to get moving again, and is probably wasting a lot of energy.
Old 10-01-2011, 02:46 AM   #100
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
I've been talking with a local guy with a similar project. He used a belt for the primary reduction and it has been giving a bit of trouble despite careful mechanical design and construction. My tape measure and cutting torch approach would not work at all with a belt. At this point I'm going to stick with the chain but would like to use a belt eventually for the noise benefit.
As far as the battery packs, yes there is a lot of extra weight. The plastic isn't light either, and the cases and supports weigh nearly as much as the cells. That's not a big deal with these small packs, but for a bigger one it will be.
Old 10-06-2011, 12:15 AM   #101
Sequoia
Oddometer: 246
Is there a minimum distance that the batteries have to be seperated by ?
Old 10-06-2011, 09:36 AM   #102
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
It doesn't seem like it. They barely get warm, and I doubt they would overheat even if packed tight. I'd assume that wouldn't hold for all sorts of bikes or batteries, though.
Old 10-06-2011, 09:48 AM   #103
knary
knary's Avatar
Oddometer: 29,423
Is there a ready solution for modulating the initial power ?
Goodbye Toolfan
Old 10-06-2011, 09:02 PM   #104
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
No.
As in, I'm working on it but it's not ready yet.
Old 10-06-2011, 10:32 PM   #105
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,488
What about making an electric vintage trials bike? Ever thought of that?
Times are GMT -7.   It's 11:37 PM.
