08-17-2012, 03:35 PM
#106 |
Oddometer: 1,461
WOW! You guys even have me second guessing my build. Part of my plan was to install heavier wall tubing into the downtube and backbone tube on my KLR frame. Honestly, I have always felt that those areas needed to be strengthened as they have been prone to failure. I still feel that it would be better to install the Versys engine into a stock KLR frame. The engine would obviously need to be trimmed in certain areas.
08-18-2012, 02:31 PM
#107 | |
I don't ride much.
Oddometer: 950
Well - I certainly think that intended use has a lot to do with it... but don't think it would hurt to reinforce the spine - that's for sure.
--------------------- KLRE650 Build thread. Ryca Scrambler Build. __________________ |
08-18-2012, 06:51 PM
#108 | |
Oddometer: 608
reinforcement
It isn't rocket science. You just have to do it right. Anyone can build an airplane. A homebuilt aircraft is not complex or difficult. One advantage of building an airplane is that the builder recognizes from the start that his/her life is at risk every time he uses it. And maybe the life of passengers too. Regular inspections are required during construction to make sure his work is acceptable. Super Rio was done right. Don't cut corners and settle for "good enough" and it will be safe and strong.
Attitude ~ The difference between Ordeal and Adventure James |
08-18-2012, 07:17 PM
#109 | |
displaced Jeep guy.....
Sent from my MB886 using Xparent Green Tapatalk 2
Interested in a Charleston, SC ADVdinner? |
08-18-2012, 08:13 PM
#110 | |
Gravel Runner
Oddometer: 2,776
1 1/16 impact socket, not 27mm, lock the sprocket off against the swingarm with an old 3/8 socket in the correct length (or steel pipe nipple), breaker bar with a cheater and pop it loose...and it will pop when it lets go. no thread locker from the factory, it takes in excess of 300# of torque to loosen. do NOT have the transmission in gear. |
08-19-2012, 07:51 AM
#111 | |
I don't ride much.
Oddometer: 950
Awesome - thanks for the info! I'll give her a whirl in a bit.The sprocket is smaller than stock, that's the reason I thought it may be loctiteededed - previous owner had played with it.
08-19-2012, 03:34 PM
#112 |
I don't ride much.
Oddometer: 950
OK, thanks to JD for the tip - new sprocket is in!
Big difference - pretty much what I was looking for. Bike is now very rideable at all legal speeds. Last week I took the laptop out to the bike and hooked the Power Commander up. I leaned out the very top end so that now it revs through *almost* the entire rev range smoothly, leaned out a little bit of the mid range, but mostly just smoothed out the transitions. End result is buttery smoothidity. Went out to Julian today with a couple of guys and hit up a couple hundred of some back country roads. EDIT: New seat was realllly nice to have. =) ![]() A couple hundred miles and I have three more things to add to the list: make mirrors match (one broke, used some random other one that was laying around - the stock ones blow donkey chunks), beef up tail light mounting, and shield the air filter from all the junk the rear wheel kicks up. Also, picked up a new project bike yesterday.
--------------------- KLRE650 Build thread. Ryca Scrambler Build. __________________ Krasniewski screwed with this post 08-20-2012 at 05:21 PM |
08-19-2012, 03:57 PM
#113 |
Wishing I was riding RTW
Oddometer: 2,418
Great! Get that new project bike all done up so I can buy the KLRE from you! Thanks
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
08-20-2012, 05:11 PM
#114 |
I don't ride much.
Oddometer: 950
Ok, hit up the taillight mount today.
Old - thin, flimsy stock plastic cut up to fit. My bad for doing it in a hurry the first time. ![]() New, angle-aluminum for stability: ![]() The hard bag mounts flex a bit too, maybe those will be redesigned someday. I was going to redo the whole mount for license plate too, so I bought some alu, then changed my mind when I got home and used what I already had. BUT - I did get sick of not having the right tools for even basic stuff. In light of so much garage work recently, and my next bike being another project instead of a nice, new power machine, I felt entitled to a drill press and a band saw. Home Depot has really gone down the shitter in terms of tools here - they didn't even have a metal cutting band for the only size band saw they sell due to switching suppliers. Whatever, they give me a 10% discount, so I'll deal with it and go back later or pick up the right blade elsewhere. Point is - I'm stoked. ![]() ![]() Put it together and hooked it up, and it's certainly not top quality, but I think they'll do just fine. ![]() I still need to figure out a way to protect the air filter. I need a rear hugger or a sheet of plastic or alu - I could have picked that up today... I need to start carrying a note pad or at least using a shopping list. ![]() EDIT: I really need to build or buy a work bench.
08-24-2012, 07:29 PM
#115 |
I don't ride much.
Oddometer: 950
Add to the 'to do' list - make a new rear brake lever and bleed the rear brake. It's OK but feeling a bit weak. Also, hook up the horn. Two little things I keep forgetting about.
Just writing it down here so I remember...
08-25-2012, 08:47 PM
#116 |
Oddometer: 621
Hey Kras...
Are you in base housing at NASNI ? I was there a long time ago and the pix from your garage looked like a place I lived before. How many traps ? I retired w 700 in the A6. |
08-29-2012, 08:40 PM
#117 | |
I don't ride much.
Oddometer: 950
Heyo - not on base - just a rental out in town. ![]() Less than 80 traps in my books - just startin' out and the traps don't come fast in the COD being day only and multipiloted. 700 ain't too shabby though! It's certainly something to aim for. ![]() Back off leave today - I'm hoping to work on the new tank a bit as well. Also, the Ricor shock came in, but it's labeled as needing two washers for model year up to 2007 - so I'll have to call tomorrow and see if she needs to be sent back or if I just skip the washers for 08+... hopefully the latter. EDIT: Shock is good to go - just wiithout the washers. On an unrelated note - I got two pairs of gloves in while I was away on some vacay! That makes me happy - got a great deal on some almost new SP3's and bought some new Cortech dirt gloves for the heat. Both will replace the same models that have been used and abused to utter ruin. The SP3's lasted for a LONG time - those were goat skin IIRC, these don't seem as sturdy, but the price was right. =)
--------------------- KLRE650 Build thread. Ryca Scrambler Build. __________________ Krasniewski screwed with this post 08-30-2012 at 09:42 AM |
08-30-2012, 10:37 PM
#118 |
I don't ride much.
Oddometer: 950
Ok, got the horn hooked up and a new fuse in, but the horn sucks. Not sure where I got it, but I need a new one. this thing sounds like it's covered in a wet sock... like a bus's brakes... like a sick goose. It's horrible.
![]() I had one KLR mirror and one Ducati Monster mirror before. The other Monster mirror was reverse treaded, so I cut off the threads and got to commission my tig for her first legit use. Simple stuff, just weld on threads from a bolt with standard twist. ![]() Got my new tank tig'd up as well. 95% of the job was cake, then the last little bit is always a kick in the nuts, especially since I'm not so good with the welder. Anyway, holds gas, looks a bit better than my other botch job. It's not as good as would have liked, but them's the brakes. Shock is up next for install. I also found the factory plastic bash guard - I might hack that up for some air filter protection. I like the size and plastic type - I'm thinking cut to size, punch some holes, and zip tie to the sub-frame and call it a day. I also want to sweeten up the fuel map a little bit...
08-31-2012, 05:43 PM
#119 |
I don't ride much.
Oddometer: 950
![]() Put the new shock in + little guard for the air cleaner = ![]() Travesty of a tank: See and compare to pic above to see how much tank I cut off. ![]() After some thought, I decided that my filler rod was far too thick. A pro could probably hack it, but it's more than my simple mind can handle. Actually, I knew it right away, but what are you going to do, stop and go the store? No. You just fuck away the project over your obstinance. Lesson learned, buy thinner rod and feed faster. The real tragedy of it all is that I got sunburn, and I think it's from welding. If you think welding in short sleeves is dumb, you should see my heel since I was also welding in flip-flops. The real awesome mod today was wiping the windscreen clean. To add to the list - my grips are loose. I usually use friction tape and gasoline to set them in place. Now would be a good time to order some heated grips or elements to go under the grips. And finally - excuse the picture if it's wonky - I can't figure out how to keep it upright. Edited for no reason.
--------------------- KLRE650 Build thread. Ryca Scrambler Build. __________________ Krasniewski screwed with this post 08-31-2012 at 07:27 PM |
09-08-2012, 07:38 PM
#120 |
I don't ride much.
Oddometer: 950
Out of town for a bit for some school.
Got bored and ordered some steel braided brake lines. That will give me something to look forward to in regards to the bike.
