Old 10-28-2011, 10:20 AM   #46
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,846
Originally Posted by Fab418 View Post
Here's a teaser:
Dude, that yellow thing was gettin' it!! and you were gone!!
Old 10-28-2011, 10:57 AM   #47
Fab418 OP
Pig ridin'
Oddometer: 173
The driver of that yellow thing is no beginner either. Pretty decent work in the rough stuff. I was ridding on worn tires and he was on a fresh set of Heidi's. But he did catch up on the smooth stuff; my clutch is badly slipping from a blown gearbox seal.
All in all, this is a serious off road setup. The stiffer springs are in the mail too.
Fabrice
TCAT traveler: If ever in need near Saguenay, Quebec; have tools, will help. PM me.
http://www.fabricetremblay.ca
My HPF: 21 inch-mx forks R11GS conversion
Fab418 is offline   Reply With Quote
Old 10-28-2011, 11:19 AM   #48
MotoKaw
MotoKaw's Avatar
Oddometer: 160
Here's a teaser: ***
More please, and some handling observations?
Bob
MotoKaw is offline   Reply With Quote
Old 10-28-2011, 11:27 AM   #49
Fab418 OP
Pig ridin'
Oddometer: 173
Bob
The handling is like ridding some big wide enduro bike. If feel that steering lock is somewhat limited compared to what it was and it's a bit annoying when doing a u-turn. But I can slide it around now so it's even. Before the swap, this bike was nearly unridable in thick and rutted sand, now it just blast through with ease. The other amazing thing is how much I can lean the bike when cornering compared to what it would be before. Overall, I feel a zillion times more confident when riding off-road since the conversion.
More vids when I put the .65 springs in.
Fabrice
Old 10-29-2011, 08:04 AM   #50
Kawidad
Kawidad's Avatar
Oddometer: 3,804
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Old 11-14-2011, 02:01 PM   #51
Fab418 OP
Pig ridin'
Oddometer: 173
Springs!
I got this in the mail a couple of days ago.
Unfortunately, I also have a strange noise coming from the left cylinder and snow is coming soon so I won't be able to try this in a near futur. On the bright side, the build's going to progress more than in summer.
I'm wondering if anyone have an idea about which front master cylinder I could use. I replaced the YZ rotor by this kit from EBC:
I now have a single rotor but a master cylinder from a twin rotor bike which results in a short stroke, hard-to-pull lever. The YZ master and lever won't fit because the lever must clear the turn signal and starter switch assembly. Basically, I would need a master from a single rotor road or DS bike. Any Ideas are welcome. Here's a pic of the master and lever:
Fabrice
Old 11-15-2011, 06:38 AM   #52
Mr. Canoehead
Eat Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,092
I think that the master cylinder off a F650 would work and fit with the BMW switchgear.
Sent from my Droid Tablet using Tapatalk
2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover
"Not all who wander are lost" - JRR Tolkien
Mr. Canoehead is offline   Reply With Quote
Old 11-15-2011, 08:01 AM   #53
Fab418 OP
Pig ridin'
Oddometer: 173
Thanks! I'll be looking for one.
Fabrice
Old 12-19-2011, 08:45 PM   #54
gristone
gristone's Avatar
Oddometer: 28
Much better!
The welded arms:
All this torque and shear talk and the thing that everyone is missing here is that the 2 stock pieces of tube steel that were used to brace the stock headstock back to the engine (the ones you just reinforced) are extremely susceptible to buckling under load-- especially due to their geometry. This gusseting that you have done with the additional pieces of tube connected back to a wider point on the engine will certainly help, but the thing that would really ensure long term success would be a horizontal tube spanning between the two stock tubing braces at the midspan-- that and making the upper connection between the steel and aluminum a bit more robust. I would bore a hole through the entire aluminum piece underneath where the 10.5mm bolts connect and run a rod straight through and connect it to the new tubing pieces that you put on there.
Anyway, nice job! looks like a blast on dirt-- I have yet to get mine out in the dirt. I have SM wheels on it and it handles beautifully over NY's effed up potholed streets so I can imagine in the dirt it will rip.
gristone is offline   Reply With Quote
Old 12-20-2011, 11:45 AM   #55
Fab418 OP
Pig ridin'
Oddometer: 173
Originally Posted by gristone View Post
..the thing that would really ensure long term success would be a horizontal tube spanning between the two stock tubing braces at the midspan-- that and making the upper connection between the steel and aluminum a bit more robust. I would bore a hole through the entire aluminum piece underneath where the 10.5mm bolts connect and run a rod straight through and connect it to the new tubing pieces that you put on there.
Thanks for the feedback gristone. Theses ideas where discussed and put aside because: the bracing between the top tubes makes them difficult to remove and I was lazy for more complex work that would allow it to disassemble easier for the first part.
The second idea would have been really interesting if it wasn't for the fact that the aluminum part is hollow so you would have to bore a bigger hole than weld-in a thick tube which is rather time consuming and a bit tricky to manage heat and get a proper weld job done.
Right now, I've hammered the thing harder than I ever did with the stock setup so we're going to take everything appart and use penetrating liquid to find any defect in the aluminum part and have a close inspection plus a weighting session to compare it to the stock setup.
Anyway, theses two ideas are on the top of the list should something needs to be done to make this stronger.
Must be a blast when traffic let's you open it!
Fabrice
Old 06-27-2012, 11:24 AM   #56
Fab418 OP
Pig ridin'
Oddometer: 173
A little update
No I'm not dead nor the project stopped.
I blew a crank bearing this fall plus a gearbox bearing and I've been busy with other things so the GS sat there for quite a while but summer is here and I'm itching for a ride so...... I got an airhead That I converted (almost done) to cafe racer.
I had to ride something and I always wanted to have something less messy than all the dirt bikes I owned in the past and the GS of course which was never near being a show bike. Not a bad thing IMO.
First ride on the airhead was not very long as I got stuck in 2nd gear after about 10km.... I then learned about the strength, or lack of it, of the shift pawl spring. So before turning my attention to the GS, I had another tranny to do; a 74.
So here's where I'm at:
GS gearbox has new balls in, a new dashboard with dual xenon headlights is near completion and I have a 40k engine waiting on a palet to find a new home. A few pics:
The dashboard and lights:
The current state of the build, airhead in the back:
Fabrice
Old 06-27-2012, 07:16 PM   #57
RedRaptor22
Oddometer: 133
I just can't believe you painted that nice aluminium steering head, if anything it should have been shown the proper respect it deserves by applying a fine glossy brush job and some clear coat.
RedRaptor22 is offline   Reply With Quote
Old 06-28-2012, 05:31 AM   #58
Fab418 OP
Pig ridin'
Oddometer: 173
I liked it better unpainted too.... Since I want to check it with penetrating fluid, I might as well sandblast it again, who knows..
Fabrice
Old 06-29-2012, 02:57 PM   #59
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 6,812
www.GravelTravel.ca Canadas Source For Overland Routes
Tales From The Bivouac Rally Print Publications
TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada
Deadly99 is offline   Reply With Quote
Old 06-30-2012, 05:24 PM   #60
Whale Rider
Oddometer: 90
Hey Fab you must have been riding the ass off it to destroy a gearbox and engine still looks good like the dash and headlight change. Her is mine still working on it but good things take time.
WR
Bike1 by boGSer, on Flickr
Whale Rider screwed with this post 06-30-2012 at 05:30 PM
Whale Rider is offline   Reply With Quote
Times are GMT -7.   It's 08:09 AM.
