Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 08-29-2011, 05:47 PM   #181
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,599
Originally Posted by vfrgreg View Post
Which one? Both new?
The WOLFMAN bag in the picture? :/
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 08-29-2011, 07:24 PM   #182
vfrgreg
vfrgreg's Avatar
Oddometer: 788
There was two bags in the picture
G2
R1200RT
vfrgreg is offline   Reply With Quote
Old 08-29-2011, 07:54 PM   #183
backwoodsKLR
Oddometer: 9,599
Generally, when someone takes a pic to show off something, they put it in the foreground and center of the shot... not many people take a picture to show off an item and hide behind other items where it is partially obstructed. Also, I guess I assumed that mentioning that I called Wolfman luggage, that it somehow be a clue as to which bag I was posting about. I apologize if my post and included picture were too confusing to be understood. :)
2013 Tiger 800XC
Old 08-29-2011, 08:10 PM   #184
vfrgreg
vfrgreg's Avatar
Oddometer: 788
Bahahahahaha! I knew what you meant. Just thought it was ironic the two bags were set that way in the picture :-)
G2
R1200RT
Old 08-30-2011, 08:16 AM   #185
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Your next post will be about how you got heat stroke tryin to get the hose out of the rear wheel
Not to mention it will be like trying to suck a golfball thru a garden hose. The only problem I see is you need to install a cath & piss bag to keep from stopping every 10 minutes.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 08-30-2011, 08:20 AM   #186
DavidQ
We Don't Rent Pigs
Oddometer: 2,059
You realize this is Supah we are talking about.? He claims to be able to suck start a Harley.:ymca
2001 1150GS / Ural Hack
2011 990 Adv R
Colorado / Utah 2010
Colorado / Utah 2011
NM, CO, UT, AZ 2012
DavidQ is offline   Reply With Quote
Old 08-30-2011, 09:54 AM   #187
Supahflid OP
Wheelieless
Oddometer: 3,741
Whoah! I never made such a claim! I do find it easy to draw a slug of water through those hoses though.
Supahflid is offline   Reply With Quote
Old 08-30-2011, 11:54 AM   #188
Trophy1298
Vicarious Cowboy
Trophy1298's Avatar
Oddometer: 5,512
Originally Posted by Supahflid View Post
Whoah! I never made such a claim! But I do find it easy to start a leaf blower that way.
I'll be back....
Trophy1298 is offline   Reply With Quote
Old 08-30-2011, 02:18 PM   #189
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,710
On today's episode of Short Attention Span Garage we have hand guards and skid plate.
Hand guards:
Would have been done while Jackie was cooking dinner (Tacos ). Thanks to one stubborn bar end weight, it took longer.
Done!
Next up, skid plate.
Easy enough, except for the kickstand bolts. Those things were a bitch, right Backwoods?
Done:
Less ground clearance, but I won't worry about following Peaches anymore.
Anticyclone is offline   Reply With Quote
Old 08-30-2011, 02:23 PM   #190
backwoodsKLR
Oddometer: 9,599
Almost made my neighbor cry... I'd have never gotten the bolts out of the stand without his help and the impact driver! Let me know how you like the hand guards. I don't like the "custom" ones on my Wee and don't know if he took them off because of the fancy end weights and throttle lock or just did not like them. I wonder if I could get a stock set back on with the throttle lock... Oh, and how you like that pipe?!?! I looked up what those cost new and doubt it will be on my farkle list any time soon!!!
2013 Tiger 800XC
Old 08-30-2011, 02:37 PM   #191
Anticyclone
Oddometer: 5,710
Too early to say how much I like the hand guards. I'll get back to you after a drop or two and some cold rain.
I LOVE the pipe. It was sort of a consolation prize after we decided a new bike was not in the cards at this time. 15 lbs lighter and no noticeable loss of power down low. Noticeable power increase above 5000 rpm. The welds are a thing of beauty!
I have put the quiet insert back in since we last rode together. I can't tell a difference in power with it in. It is a little louder than stock with the insert, just right. Without the insert it's just right for waking up the neighborhood! A little farty, but in a good way. I'll probably continue to switch it in and out depending on my mood.
FYI: The stock hand guards are just plastic. No metal backbone to provide protection for the levers. They break when you drop it.
Old 09-01-2011, 12:31 PM   #192
backwoodsKLR
Oddometer: 9,599
Wolfman rocks. My new bag came with wrong harness... called and they sent the proper strap 2 day air.... big box for a little strap!
2013 Tiger 800XC
Old 09-03-2011, 06:37 PM   #193
Switchblade315
Switchblade315's Avatar
Oddometer: 5,699
First impression of the ZF1. stupidly responsive. suspension is a little stiff for me. I'm a little lighter then Slaw, going to have to adjust it a little. it's really quite, handles nice and I almost don't have enough butt to get it up on the center stand.
Fun i think so. more when i can actually ride it.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 09-03-2011, 07:09 PM   #194
tslaw
aged n00b
tslaw's Avatar
Oddometer: 2,643
I cranked the preload up in the shock - stock setting should be good for you (there is a spanner wrench in the tool kit). Center stand is technique, but mass helps (funny, I never had that problem).
tslaw is offline   Reply With Quote
Old 09-03-2011, 07:13 PM   #195
Switchblade315
Oddometer: 5,699
yeah i was looking through the manual when i gt back to see how to adjust it. I'll play with it over the next few weeks. And at 140lbs I don't have the mas for the center stand. i lost 12lbs wile i was down with my back. I've gained 5 back so far.
Times are GMT -7.   It's 03:44 AM.
