Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 12-14-2012, 07:51 AM   #571
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,565
Now you need to make a rear mud guard to protect the shock. I just super glued a heavy duty tube to the battery box & zip tied the bottom to the dog bones. If you decide to screw something to the battery box, then be sure to move stuff out of the way first.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 12-14-2012, 07:55 AM   #572
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,490
Please tell me this is purely a cautionary note and not the voice of experience talking.
Later,
Michael
"If I can't pass at a reasonable speed I do it unreasonably." - jdmetzger
Anticyclone is offline   Reply With Quote
Old 12-14-2012, 08:06 AM   #573
RoyQ
RoyQ's Avatar
Oddometer: 2,152
Originally Posted by backwoodsKLR View Post
quoted for reference....
Your welcome and you are the guy who told me T63's go 4500 miles. I can barely get 1500 on a DR650 rear 80% off road. You may get more than 1500 but it won't be quality mileage off road because they will be rounded off and border line bald by then. Plus the triumph has more go than that KLR. Surprisingly my DR literally killed the T63 on the rear in no time.
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
WERA Expert #826
RoyQ is offline   Reply With Quote
Old 12-14-2012, 08:08 AM   #574
RoyQ
RoyQ's Avatar
Oddometer: 2,152
This reminds me of the guy who was going to mount his tag on the underside of his GSXR rear fender only he drilled the holes right through is ECU in the process.
'11 GSXR750
WERA Expert #826
Old 12-14-2012, 08:22 AM   #575
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,443
The T-63's on my KLR will go 4500 on rear and 9000 on front. Must be the rider or the DR... Guess that is where the "YMMV" variable comes in to play.
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 12-14-2012, 08:43 AM   #576
RoyQ
RoyQ's Avatar
Oddometer: 2,152
I guess so. I am typically easy on tires so maybe that DR had more power than I thought. I have a brand new T63 rear still in plastic that I guess I'll sell since I don't plan on using them anymore. Bikes for sale anyway.
'11 GSXR750
WERA Expert #826
Old 12-14-2012, 08:48 AM   #577
backwoodsKLR
Oddometer: 9,443
Our of curiosity, what PSI were you running on the T63s? I was running them real low at first but found they last much better when around 28-30 instead of 18-25... But I got tired of airing up and down when I transitioned from off road to on road.
2013 Tiger 800XC
Old 12-14-2012, 09:00 AM   #578
RoyQ
RoyQ's Avatar
Oddometer: 2,152
I grew tired of the air up down thing and ran 29-30 rear and 25 front all the time even in CO. Rear gets real hot on pavement for any distance. My rear just evaporated with 250 miles in CO on it and the rest locally. At 1500 it's pretty much gone for off road on pavement it's still ok but going quick. I ended up with a extra one because they were on BO nationwide at the time and I bought one from kickstand. Never canceled the one I had ordered on BO and it showed up in OCT.
So I was stuck to run another rear but just decided to sell the bike since I just don't use it and for the most part can go same places on Super T if I need to. The DR to me felt just as big off road as the Tenere. I am leaning toward K60 Scouts on Super T but gotta wear out a new Michelin anakee 2 first.
'11 GSXR750
WERA Expert #826
Old 12-14-2012, 09:03 AM   #579
backwoodsKLR
Oddometer: 9,443
I almost went the K60's on the Tiger, but the 150 size has an annoying solid strip down the middle that causes them to wobble and follow asphalt snakes. DQ suggested dropping to the 140 that didn't have the solid center rib, but I just went full knobby to see how I like them.
2013 Tiger 800XC
Old 12-14-2012, 09:19 AM   #580
RoyQ
RoyQ's Avatar
Oddometer: 2,152
Yep they have a nasty vibration on the Tenere under braking. I am still going to try them eventually even knowing that. The shaft drive roars now leaning left or right once the rear tire cups a little on the edges. I've learned to live with it for 15k miles. The Anakee II's have been great tires, used them in CO and UT but I aired them down, had to it was all over the place until I did that. Get 8k on a rear and front will go 2 rears I'm sure. Great thing about them is they are sportbikeish on the street up in the mountains. I've dragged everything but my sidebags and they are only about inch off the pavement.
'11 GSXR750
WERA Expert #826
Old 12-14-2012, 09:37 AM   #581
Rob Dirt
Rob Dirt's Avatar
Oddometer: 2,565
Not me.
Some guys bought a universal mud sling that acerbis sells & mounted it with screws. They mentioned how easy it would be to screw something up on the inside.
I just glued an old HD tube on mine. I can't believe it's still on there after 12k+ miles.
BW, did you figure out why your Tiger is hopping at 40?
Heart of Dixie
Old 12-14-2012, 09:40 AM   #582
backwoodsKLR
Oddometer: 9,443
Not me.
I did not notice it this morning on the way to CSC, but that is only 12 miles on new knobbies. Will have to see if it was just the Pirelli Scorpion...
Need to get my rear flap installed soon... I've seen an aftermarket rear hugger fender but figure it will just fill up with mud, if I get in any...
2013 Tiger 800XC
Old 12-14-2012, 10:06 AM   #583
Rob Dirt
Rob Dirt's Avatar
Oddometer: 2,565
Those brake when used off tarmac. Do some research before you spend money on that type.
Heart of Dixie
Old 12-14-2012, 08:16 PM   #584
Trophy1298
Vicarious Cowboy
Trophy1298's Avatar
Oddometer: 5,506
I make it a point not to agree with Roy... So i say they will be good for about 1502miles.
FWIW, the BMW can get about 3500 out of a T63 rear b4 people start telling me I need a new back tire. I almost never air down either.
I'll be back....
Trophy1298 is offline   Reply With Quote
Old 12-15-2012, 10:57 AM   #585
Switchblade315
Switchblade315's Avatar
Oddometer: 5,454
I wonder if you could make something that would give more room for mud but would serve the same purpose out of some of that plastic you can get to make molds for tactical uses. you know you heat it and then mold it to the shape you need, stuff isn't hard to work with and it's fairly strong.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Times are GMT -7.   It's 06:41 PM.
