01-20-2013, 10:51 PM
#256 | |
Oddometer: 2,953
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-21-2013, 12:09 AM
#257 | |
Ivanych
Oddometer: 213
I ordered the new spring for installation in my old XR500R motor. I think this will work, I'll watch when he comes. |
01-21-2013, 03:06 AM
#258 |
Oddometer: 8,005
I would use the later spring. I have only heard of one failing on a fellas XR600. The transmission would not shift at all. Matter of fact I have it on my list of tid-bits I need for when I assemble my CW engine.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
01-23-2013, 09:08 PM
#259 |
Oddometer: 196
Great thread Dave. The backlog of parts you have for these engines, which is mentioned once or twice, begins to give me an idea of the relationship you have with them.
Thanks for the service to the community.
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead) Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com |
01-24-2013, 04:25 AM
#260 |
Oddometer: 8,005
Dave? Who's Dave???
01-24-2013, 05:27 AM
#261 |
Oddometer: 1,626
Hey man.....Dave's not here.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
01-24-2013, 07:30 AM
#262 |
Oddometer: 196
Oops. That was the last thing I did before going to bed... it was late! Substitute "Steve" into above comments, and leave the meaning otherwise unchanged!
01-24-2013, 08:14 AM
#263 |
Oddometer: 3,963
too late now man, the damage is DONE!
jajajajajajajajja
01-24-2013, 10:00 AM
#264 |
Oddometer: 196
Sorry for calling you Dave, Steve. No one likes that sort of thing. My apologies.
01-24-2013, 12:28 PM
#265 |
Oddometer: 8,005
No worries. For some reason most people I say my name to when on the phone reply DAVE?
01-24-2013, 04:58 PM
#266 | |
Oddometer: 196
Anyway, like I said before... Great thread!!
01-31-2013, 06:04 PM
#267 |
Oddometer: 2
Massively informative thread
I am in the market for a 2001 XR650L and it was a great thing to view this thread.
I can get the bike for 600 bucks but it needs a rebuild as the owner states there was an oiling failure. With this pictorial I can tear open the engine with confidence and I will hopefully find less damage than the owner suspects. One thing I cannot tell from the post is whether or not the connecting rod is OEM or not. I know the crank is pressed but the fiche for this bike shows the rod and crank as one part number. If it is aftermarket where did you get it? There seems to be a lot of hopping up on these engines but I want to go for a stock and hopefully cheaper rebuild. |
01-31-2013, 06:36 PM
#268 |
Oddometer: 8,005
The rod was replaced with a Pro-X rod kit.
Different engine but the same rod kit.
01-31-2013, 07:49 PM
#269 |
Oddometer: 2
Now to make a list for this do you have any other vendors?
I ask because I do not readily trust local resources and you have done this many times before.
149.99 for the crank pin and rod is super cheap from my point of view. All in all it looks as if fixing this is like working on a really big wristwatch. |
02-09-2013, 04:00 AM
#270 |
Oddometer: 82
Right Crankcase cover/clutch/camchain
Hi Steve
I'm in the process of removing the right side crankcase cover. I've followed the steps in the Clymer manual,Brake pedal , kickstart and bolts plus the 3 nuts at the bottom all off. The manual then states to simply remove the cover , taking care not to lose the locating dowels. Mine won't budge. I've applied a little heat and tapped lightly with a rubber mallet..........nothing. Can you shed any light please ? Can I give it mighty smacks ? I'm not clear on where exactly these dowels are. I'm replacing my camchain . Do I need a clutch holder tool , or do you have a trick way ? I've read this excellant thread a few times , which has inspired me to delve into this myself rather than farm it out , but I am worried about causing damage due to any hamfisted bodgery on my partMany thanks for any tips Cheers Stu The Dogger screwed with this post 02-09-2013 at 04:01 AM Reason: Poor wording |
