Old 02-09-2013, 05:21 AM   #271
The Dogger
Oddometer: 143
Cheers deejay
That's got it off , thanks. Can you confirm that part no. 6 in your diagram is a washer or grommet that fits in the oil filter? ie when you replace the oil filter that washer is already in place ?
Now to remove the clutch.......any pointers there greatly appreciated
Cheers
The Dogger screwed with this post 02-09-2013 at 05:22 AM Reason: speling
The Dogger is offline   Reply With Quote
Old 02-09-2013, 05:25 AM   #272
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Originally Posted by The Dogger View Post
Cheers deejay
Cheers
Yep, thatīs it, itīs already in place in every filter.
For removing the clutch basket you can either order a tool from Ebay, mineīs from EBC, cost about 20 USD I believe.
Or what some people do is wedge a penny or some other type of SOFT (you DONīT want to damage the teeth) coin in between the gears so they are stuck while you apply pressure to the bolts.
It wouldnīt be my way of doing it, but apparently it works
Edit: One of these http://www.ebay.com/itm/390527909921...470021&vxp=mtr
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 02-09-2013, 01:39 PM   #273
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,262
Cheers deejay
Cheers
Originally Posted by mcma111 View Post
Gun on the new clutch hub. Who ever disassembled the engine broke one of the spring posts off. Doh
Clutch hub holder. With all of the plates in place you hold the hub like this as you gun the nut on. Easy Peasy. Trick #6
The clutch can be gunned off, the same way Steve shows to gun it on.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-09-2013, 01:45 PM   #274
mcma111 OP
mcma111's Avatar
Oddometer: 12,295
Wow. Thanks Walter.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-09-2013, 02:00 PM   #275
The Dogger
Oddometer: 143
Walter
Yeahbut......I saw those photo's , but there must be a stage before that ( in the removal procedure ) that prevents the whole shebang from turning while the 4 bolts are removed ...........
That's what I was after......I had seen the penny trick on here before , and when I tried it I couldn't get it to jam up without falling out. Hence , asking for advice
I don't have access to an airgun , is that likely to be a problem ?
EBC clutch holder ordered and an it's way
Old 02-09-2013, 02:12 PM   #276
mcma111 OP
mcma111's Avatar
Oddometer: 12,295
Clutch Removal
You remove the four bolts that hold the springs and outer clutch hub and the nut on the main shaft are right there. Gun the nut off and the whole clutch hub comes off. All you have to do is grasp the clutch assy to keep it from spinning as you gun it off. No gun? Then you will need a clutch hub holder as you wrench it off.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-09-2013, 02:51 PM   #277
The Dogger
Oddometer: 143
OK , got it , thanks
Old 02-09-2013, 05:46 PM   #278
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Yep, clutch tool would be the way to go, for us non-privileged people
deejay_xr screwed with this post 02-09-2013 at 05:53 PM
Old 02-09-2013, 06:02 PM   #279
mcma111 OP
mcma111's Avatar
Oddometer: 12,295
You can never have enough tools.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-09-2013, 06:05 PM   #280
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Correct !
And I'm well on my way, the problem remains that nice tools tend to be expensive...
Old 05-07-2013, 07:24 PM   #281
JSeward
Oddometer: 40
Question piston direction
OK, the bottom end is done. Now for the top end.
Make sure the cylinder is really clean. Yes, there was some black stuff on the cloth after I wiped down the cylinder.
Put a ring in the cylinder and push it down 1" with the piston
Checking ring end gap. With Wiseco piston sets it seems like I never have to file fit the rings.
Put one of the wrist pin keeper clips on and apply some assembly lune
Lube the rod
Pin in place and the other pin keeper clip in
Ring compressor with a couple of pieces of 3/4" ply to hold the piston still while I install the cylinder
Oil them bolts
And the washers, per the factory service manual
Torquing down the cylinder. 36lbs in 2 steps
Hi Brilliant thread, has helped me heaps with my NX650 rebuild/custom. Just a query, though, does it matter that the arrow on the piston in the photos is pointing to the exhaust rather than the inlet ? manuals I've read says needs to point to the inlet, and now I'm a bit confused. Spose it depends on the piston geometry? i.e. if its symetrical it doesnt matter
CHeers
JSeward is offline   Reply With Quote
Old 05-07-2013, 08:33 PM   #282
mcma111 OP
mcma111's Avatar
Oddometer: 12,295
Different pistons have different marking. The piston pictured is a Wiseco and there is a small arrow pointing toward the exhaust.
This is my other XRL with a JE piston. Bigger valve pockets on the intake side:
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-10-2013, 04:06 PM   #283
JSeward
Oddometer: 40
Thanks for clearing that up. The piston I am looking at it a flat top and I am pretty sure it's a wossner but can't find any info on the direction of the arrow
Cheers
JSeward screwed with this post 05-10-2013 at 04:21 PM
Old 06-15-2013, 01:20 AM   #284
Notabiker
Notabiker.. really!
Location: Used to be middle of Alaska, now 400 miles south!!
Oddometer: 28
I'm always of mind that the money you spend on tools to do it yourself will pay for themselves in not having to pay someone else to do work later on down the road. This thread has been helpful, I'm in the process of tearing down my xrl that overheated in a +40mph headwind trying to do 65+ with less than optimal jetting DOH! As soon as I started slightly slowing down and more throttle didn't do anything I hit the kill switch and let it cool, rode back the 20 miles keeping to 4th and using a little 1/2 choke just to make certain. That was two summers ago (not counting this one) and it was fine except for the slight burning oil smell on decel. Until this spring when it decided to smoke up a two stroke style storm while accel during warmup. My machine shop here has the jug and it's barely scuffed up with one small groove that they say will hone out just fine. Just shined up the skirt a hair and ordering new rings soon. Oh and valve stem seals as that could be part to blame. Stupid thing is sitting in the garage with an unlucky 5777.2 miles on it. I think next time I'm going with a Doctor, just have to reinforce that gangly oil cooler hanging off the side :) (Gotta justify the welder somehow right!)
Oh and a xr650r style CS sprocket. Is there any issues with chain alignment or is it all good?
Notabiker is offline   Reply With Quote
Old 06-15-2013, 02:18 AM   #285
AndyCBR
Oddometer: 122
The chain alignment will be off a little but not enough to worry about.
It is common to have to possibly do a little bit of dremel or die grinder beveling on the side of the sprocket that faces the engine in order for it to seat fully and allow the keeper to hit the slot (remember you are installing the R sprocket backwards).
Hope this helps.
2012 Super Tenere/2009 crf450x/2006 sm610/2003 xr650l/1990 cbr1000f
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles." - Jeff Cooper
AndyCBR is offline   Reply With Quote
Times are GMT -7.   It's 08:10 AM.
