Old 08-10-2011, 07:03 PM   #61
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,115
Originally Posted by MightyZeus View Post
will do!
i promise
1Bonehead is offline   Reply With Quote
Old 08-11-2011, 07:51 PM   #62
Break_Syncro
Oddometer: 189
Thanks Steve, extremely good info, great pics, and valuable tricks!
Awesome ADV Fellow!
Break_Syncro is offline   Reply With Quote
Old 08-12-2011, 12:09 AM   #63
Keith
Slabbing it
Keith's Avatar
Oddometer: 903
That sure was a neat photo essay, nice pics.
Is it me or were those cases still really dirty when you put them back together? The cylinder was so nice and clean in comparison.
That's a lot of sealant on that cam cover gasket.
Random Crap
Keith is online now   Reply With Quote
Old 08-12-2011, 04:30 AM   #64
mcma111 OP
mcma111's Avatar
Oddometer: 11,909
Correct on all points.
The cylinder and head were bead blasted at the machine shop.
The sealant. I let it dry a day and peel it off like a rubber band. Inside it actually stays in place. I have done this many times with no problem.
This is my motor from a recent build.
Blasting the cases
Clear coating them
Center cases cleared and clutch/stator cases powder coated
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-12-2011, 10:31 AM   #65
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 518
Steve,
Do you coat the motor with anything post bead blasting?
TE610
TLR200
farrington300 is offline   Reply With Quote
Old 08-12-2011, 03:03 PM   #66
mcma111 OP
mcma111's Avatar
Oddometer: 11,909
Originally Posted by farrington300 View Post
Steve,
Yes. Dupont 222 mid coat something or another. Shoot it straight out of the can. Here is what I shot:
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-12-2011, 07:20 PM   #67
mcma111 OP
mcma111's Avatar
Oddometer: 11,909
Stick A Fork In It
Where was I???
Oh yeah, last Saturday after a long day in the garage i stopped for the day with the engine almost completed.
This is where I left off
So Sunday 22manyrides came down from Sacramento to have me open his XR600 engine to find the source of a second gear whine.
Found it
OK, so it's a shitty picture of the gear teeth all pitted. For a better pic go look on the Call All XR600!!! thread
It turned out that with the gear giving up a bunch of material the piston picked up a couple of pieces and took them for a ride. Up 'n down, up 'n down they went and the cylinder got a couple of nice gouges in it. Off to Engine Dynamics goes his cylinder and piston. Back comes a honed cylinder and the piston. A new set of standard bore rings are on order and as of now his engine looks like this after I went through my stash of transmission gears and picked out two second gears and reassembled the lower end. What's up with two second gears you ask?? Well if one gear is bad or damaged it will fuck up it's mate. I didn't even have to look at the other gear as I could FEEL the rough edges of the gear that the pictured gear caused.
When doing these builds I leave the clutch cover off to make getting the cam chain on the drive gear easier. Trick # I forget...
Anyhow here is the engine in question. All done.
As you can see the rocker cover has some sealant oozing out. I will wait until it drys and pick it off like a rubber booger.
Not pictured is the customers carb that I am doing Dave's Mods to. 55/160 jets are the order of the day to take into account the 101mm 10.5CR Wiseco piston.
So this brings us to the end of this build. I called my customer and she is on her way right now to pick up her freshly refurbished engine. She and her significant other will finish the engine installation.
Until next time, Steve in SF
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-12-2011, 07:44 PM   #68
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,442
Nice Instuctional thread Steve, First Class,
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 08-12-2011, 10:09 PM   #69
mcma111 OP
mcma111's Avatar
Oddometer: 11,909
Thanks Big
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-13-2011, 06:03 AM   #70
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Any thoughts on what caused the gear to go bad like that?
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 08-13-2011, 07:10 AM   #71
mcma111 OP
mcma111's Avatar
Oddometer: 11,909
Gear Noise
John
To much riding in the one gear. Last year I bought an XR600 engine from Southern California that ran in the desert that had a bad third gear set. This gear is from a Northern California engine, slightly slower average speeds is my guess. With the exception of these bad gears both engines were spotless inside so it wasn't bad oil.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-13-2011, 07:21 AM   #72
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,598
Thanks Steve, I can't wait to scratchout again!
Sourjon...
Thoughts on gears?
Well, it's a N Cal bike, they get used in the high country alot and 2nd gear is the MOST used.
That's the theory anyway. But I am disapointed a little.
I bought that 600 late last year from a 1 family usage.
It was billed as a well maintained, un-adulterated, low milage bike. And it looked and ran like it.
I had a chance to look it over carefuly, and ride it shortly. Gear sounds didn't jump out at the time,
but it was shortly after taking posession that I noticed, (like day 1).
And I rode it on 4 trips after. Grinding all the while.
Such a nice one, I gotta have this fixed.
And reguarding the grind...if you hear it, you know what it's leading to.
Leads to total distruction of your ride.
Gremlins floating round throughout the oil system.
But who really knows why this happened...
Might be it was run low on oil at some point, but the motor had never been apart before. So it wasn't fried.
Over heating? I'm still guessing as my bought new 92 which has been ridden all through the mountains in second gear...
never developed any grinding.
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 08-13-2011, 07:50 AM   #73
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Hmmm.... I wonder. Bad gear from the start maybe? Here's the cam from my original motor. Bad casting? 28K mi and the rest of the motor looked very good. I hadn't noticed any noises or issues when I swapped but found this when I pulled the cover. The rocker still looked fine. I wonder if this gear might have had the same problem from the factory. It is under a lot more load than the cam.
John
Old 08-13-2011, 07:55 AM   #74
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by 22manyrides View Post
Sourjon...
Thoughts on gears?
Gremlins are never a good thing inside an engine :) See my reply to Steve.
John
Old 08-14-2011, 12:50 PM   #75
farrington300
No wait....What?
Oddometer: 518
Hey guys,
I am getting ready to pull my motor out of the frame. All bolts and wires removed... Two questions. Im guessing the the motor comes out of the right side of the bike? And second, is it possible to do it by yourself, or should I call in help. Can I lay the bike on its side and sort of drop the motor out with gravity?
TE610
TLR200
Times are GMT -7.   It's 06:09 PM.
