Old 09-11-2011, 04:30 PM   #16
Homerb OP
Oddometer: 204
TRX850 Adventure bike build
I'd love to elephant man, but very few XTZ750s were sold in Australia, and used parts are even rarer. Theres a number of other twin disc 21inch front end I could use; Triumph tiger, yamaha xtz660, etc. Its just a matter of waiting for something decent to come up on ebay, or at auction etc.
Homerb is offline   Reply With Quote
Old 09-12-2011, 04:41 AM   #17
notaduc
Oddometer: 14
This is great!
I just got a TDM 850 motor and am looking to build a frame similar what you have done with the TRX frame here. Ill be watching closely! Any photos you have will be great inspiration....
Good work.
notaduc is offline   Reply With Quote
Old 09-12-2011, 04:42 AM   #18
notaduc
Oddometer: 14
Oh, what exhaust header is that? Is it the stock TRX?
Old 09-12-2011, 05:27 AM   #19
Homerb OP
Oddometer: 204
Hi Notaduc, no that exhaust isn't stock, it was built by the previous owner. The frame is heavily modified too. The stock trx frame looks a lot different.
Old 09-12-2011, 06:24 AM   #20
notaduc
Oddometer: 14
Yea, I have been studying what I can find on the TRX frame, I dont want to duplicate it, just make something actually more similar to what you have. That TRX project blog is amazing btw...
Old 09-19-2011, 02:28 AM   #21
Homerb OP
Oddometer: 204
Well the engine is in the frame, and most of the electrics are connected and working. Most, but not all. Still got to get the indicators to fire up, and connect the brake light switches.
The front end has been a major job. I definitely wanted a low front mudguard ala the XTZ750, but the DR650 forks had no mounting points on the fork legs, none whatsoever. So how to mount the low front guard?
Ended up making some clamps out of 3mm aluminium bar, annealing it to allow for easier bending, and fitting it using 6mm high tensile bolts and nuts. Ended up looking like this. Pretty happy with the result, though a major pain in the arse to fit. Actually took four whole days to make and fit these little buggers.
Old 09-19-2011, 02:29 AM   #22
Homerb OP
Oddometer: 204
Next was fitting the 300mm front disc. The front disc needed to be 300mm so I could use the four pot Brembo caliper, except of course no-one makes a 300mm disc that will fit onto my front wheel. I bought a piece of 6mm aluminium plate and cut out a spacer to mount to the wheel which I could bolt the disc to. It also offset the disc by 6mm which helped the caliper clear the spokes.
Old 09-19-2011, 02:30 AM   #23
Homerb OP
Oddometer: 204
Then fitted the Brembo caliper. Combined with the bigger disc, I'm hoping for enough braking to not need to fit a twin disc front end.
Old 09-19-2011, 02:32 AM   #24
Homerb OP
Oddometer: 204
This is how she looks at the moment. Hoping to get the tank and headlight cowl back from the painters tomorrow, then fit the carbys and polish and fit the pipe.
Old 09-19-2011, 06:01 AM   #25
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Nice looking build you've got there. I've got a stock ktm brembo with a 300mm disc on the Dirt Ninja round about 400lbs and it stops fine.
Any plans for luggage?
Old 09-27-2011, 02:08 AM   #26
Homerb OP
Oddometer: 204
Well got the electrics sorted, and the exhaust is painted and the new muffler fitted. Carbys are on, brakes fitted and bled,
still waiting for the painting to be done, This week hopefully.
Old 10-01-2011, 01:01 PM   #27
toastmuncher
I be new round here! Ello
toastmuncher's Avatar
Oddometer: 617
It actually started out like this.
I think youll find this what what it DID look like.
Guzzi 1100 callifornia stone 2003
Guzzi 1100 california hedingham hack 1994
Ducati GT1000 2006
Suzuki GN250 hack, 'the tiddler'
Matchless g3ls 350 1954 and AJS Model 14 250 1961. IBA 40526
toastmuncher is offline   Reply With Quote
Old 10-01-2011, 01:17 PM   #28
toastmuncher
Oddometer: 617
Not sure how strong those front caliper bolts are, Id have a look at that.
I sound like a right pessimist, The bike looks great and I would start a job with such a fine bike at the end of it.
Ducati GT1000 2006
Old 10-02-2011, 05:48 PM   #29
Homerb OP
Oddometer: 204
Thanks Toastmuncher, which bolts are you referring to? The allen head bolts or the gold coloured hex heads?
Old 10-02-2011, 05:52 PM   #30
Homerb OP
Oddometer: 204
Heres how she looks now. Nearly done.
Times are GMT -7.   It's 07:03 PM.
