Old 10-02-2011, 11:39 PM   #31
toastmuncher
I be new round here! Ello
toastmuncher's Avatar
Oddometer: 677
Originally Posted by Homerb View Post
Thanks Toastmuncher, which bolts are you referring to? The allen head bolts or the gold coloured hex heads?
It doesnt look like either are high tensile, but, the hex heads look like a definate candidate for upgrade.
Guzzi 1100 callifornia stone 2003
Guzzi 1100 california hedingham hack 1994
Guzzi 1000 lemans 5
Guzzi 700 V7 details-mystery
Matchless g3ls 350 54, Ariel 650 huntmaster 56. IBA 40526
toastmuncher is offline   Reply With Quote
Old 10-03-2011, 01:28 AM   #32
Homerb OP
Oddometer: 471
Actually the hex heads are high tensile, but I'll take your advice and replace the socket heads with high tensile as well.
Meant to say, I played rugby in Chepstow back in '82 on a tour. Nice town, had a ball as I remember!!!
Homerb is offline   Reply With Quote
Old 10-03-2011, 01:45 AM   #33
toastmuncher
Oddometer: 677
I was struck by the plateing colour, happy to take the mistake on the chin though. A big rugby town this, you will have played some of my family in 82, small world eh?
Bike looks great by the way.
Guzzi 1000 lemans 5
Old 10-09-2011, 03:45 PM   #34
Homerb OP
Oddometer: 471
TRX850 Adventure bike build
The single piston KLR650 rear caliper is crap! I'm going to see if I can fit the KLR twin piston front caliper on the rear.
Well after a day spent on the grinder and welder I got the twin piston caliper painted, fitted and bled. Took it for a run tonight and a definite improvement on the oldAttachment:
caliper. Bike pulls effortless wheelies in first gear too by the way
I'll have to look at a better heatshield for the pipe though, gets a bit hot on the calf while sitting and the thigh when standing.
Off to try and get the bike through rego tomorrow. Wish me luck.
Old 10-09-2011, 05:22 PM   #35
andyhol
volcano rider
andyhol's Avatar
Oddometer: 153
good luck for a cool project
current rides: tiger 200 and cb200 scrambler in indo
90 yamaha xtz750 super tenere, 98 honda vtr 1000 firestorm in the uk
andyhol is offline   Reply With Quote
Old 10-09-2011, 05:25 PM   #36
AJxr
#395
AJxr's Avatar
Oddometer: 950
amazing
12 CRF250X - 01 CR250R
Help Plan the Toughest offroad route across the USA
AJxr is offline   Reply With Quote
Old 10-10-2011, 01:25 AM   #37
Homerb OP
Oddometer: 471
The beast is on the road!!! Goes like stink. Rear shock needs setting up, as I bottomed out a few times on big bumps.
Old 10-10-2011, 10:38 PM   #38
Adrian V
Oddometer: 520
Pictures...
I can't see that last picture, got any more of the finshed bike?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 10-12-2011, 12:49 AM   #39
Homerb OP
Oddometer: 471
Heres a few pics of the finished bike. Just got a sheepskin seat cover to fit and its all done.
Old 10-12-2011, 12:50 AM   #40
Homerb OP
Oddometer: 471
Other side
Old 10-12-2011, 12:52 AM   #41
Homerb OP
Oddometer: 471
Swiss cheese effect on the heatshield
Old 10-12-2011, 12:53 AM   #42
Homerb OP
Oddometer: 471
My mate, waiting for a ride!
Old 11-03-2011, 06:31 PM   #43
Homerb OP
Oddometer: 471
UPDATE: Well after riding the TRX around for a few weeks, a few small issues have arisen, as expected.
1. The 5mm plate I made to mount the front caliper on the rear broke. I drilled one of the mounting holes too close to the edge of the plate and the forces exerted by the caliper broke the plate at the bolt hole. Made a new one out of 6mm plate, and so far so good.
2, Ordered a rear master cylinder kit from the US before I swapped the rear calipers, so I fitted that when it arrived.
3. The rear shock is toast. Its a Technoflex from the Netherlands and apparently is worth $1800!! I found a bloke in Penrith, (Sydney) who has the bits to rebuild it, and he'll also sort out the DR650 forks while its there.
4. The motor goes great and sounds awesome. My mate who owns a 650 V Strom took it for a ride and couldn't believe how good it went. Small problem though. At about 3500 rpm in top gear, the bike felt like it was running out of fuel. Drop down a gear and it ran fine. But of research on the TRX850 forum suggests I've got worn emulsion tubes in the carbys. Pulled them apart and sure enough jets are worn oval. Ring Yamaha and get quoted $400 for two needles and two jets!! Bugger that, so bought titanium needles, nickel plated jets and two carby kits from Factory Pro in the US for just under $175 delivered. Waiting on them to arrive now and then I can put it all together and put some miles on it.
5. Don't know if I'll bother with the sheepskin as the XJ6 seat is actually a lot more comfortable than it looks.
I'll post a link to some footage on you tube if I can figure out how to tranfer it from my camera onto the computer!
Hows this? Took it for a ride to a cafe near Kulnura a few weeks ago. 40-50 bikes parked there enjoying the sunshine and having a coffee., when a bloke walks up to me and recognizes the bike from the ADV forum! Small world.
Old 11-03-2011, 08:46 PM   #44
ktmklx
ktmklx's Avatar
Oddometer: 703
NIce job on the bike. That KLR fairing looks pretty good on that bike! Where did you get the heat shield? I need one like that.
ktmklx is offline   Reply With Quote
Old 11-03-2011, 08:56 PM   #45
Homerb OP
Oddometer: 471
Thanks Ktmklx, the heatshield was on it when I bought it. I drilled some holes in it for extra cooling. I have seen them on a website, its called pipe guard. Comes in several nifty colours. Where are you located? This is an Australian company
http://mcsonline.com.au/index.php?op...=79&Itemid=137
Times are GMT -7.   It's 10:17 AM.
