Thread Tools Rating: Thread Rating: 282 votes, 4.94 average. Display Modes
Old 01-31-2012, 02:16 PM   #1501
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,834
I usually grab fuel when the light comes on. I want to say we did around 500 miles one tank on our long trip but I was starting to sweat near the end of it
Old 01-31-2012, 03:57 PM   #1502
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,518
Hey Geek, still want that receiver tube? Since you've already mounted the hitch, I'm guessing not.
Re: fridge, I missed the details. Are you going thermoelectric, or compressor? A compressor would take quite a bit of power.
Solar: I installed a pair of 80W panels on my trailer. Even after a cold night with the furnace blower running most of the time, the dual batteries are recharged by mid-morning. Get a decent controller to maximize battery life and charging efficiency. I got 3x80W (one spare) panels for $300 on Craigslist, then spent another $300 on a controller. With excess capacity, you don't have to worry about aiming the panels. Panels are mounted on compliant fixtures on the roof. Fake wood from PVC is a wonderful building material. Light, won't ever rot, and can be cut/glued like nothing else.
I hope you can make our spring Utah trip. Bring extra water and we'll provide showers.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 01-31-2012, 04:55 PM   #1503
troidus
Oddometer: 15,706
Originally Posted by drc42 View Post
That's what I figured but would hate to get stranded. Might go a little longer on fuel on my trip to South Carolina this weekend, let's hope I don't learn that for some reason my van only has a 2 gallon reserve
Now, how far have you actually pushed yours on fuel? Learning from my own mistakes is good, learning from yours would be much better
Just toss a 5 gallon can of diesel in the back and go drive 'till you can't go any more. Then hope you're not more than 5 gallons away from a diesel pump.
troidus is online now   Reply With Quote
Old 01-31-2012, 05:14 PM   #1504
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,834
Generally speaking you don't wanna run Diesel's out of gas.
I know its a huge no-no in heavy equipment/tractors (you end up having to prime the lines, etc).. anyone know if it is as big of a deal in a passenger diesel?
Old 01-31-2012, 05:29 PM   #1505
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 751
I'm not sure about the common rail diesels, but my cummins needs the injectors primed after you run it dry.
boardrider247 is offline   Reply With Quote
Old 01-31-2012, 07:47 PM   #1506
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,717
I was warned against running my 'Stroke outta 'gas.' Seems bad things happen when you do.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 01-31-2012, 07:51 PM   #1507
Cycle61
wannabe
Cycle61's Avatar
Oddometer: 347
M
Fuel is used to lubricate the injectors, if I recall correctly. It's kinda bad, but not catastrophic bad.
Cycle61 is offline   Reply With Quote
Old 01-31-2012, 08:12 PM   #1508
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,504
cycle the key multiple times, then do it some more before you try to start it. Even then, it'll have to crank for a while.
all-in-all. Not the best idea
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 01-31-2012, 08:20 PM   #1509
OaklandStrom
Oddometer: 1,612
The trick is to figure out how to re-prime the pump. The best plan is to do it in a warm dry, lit garage. Then, when you run out of fuel on a dark, wet night on the freeway, it's much easier to deal with.
OaklandStrom is offline   Reply With Quote
Old 01-31-2012, 09:00 PM   #1510
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,880
Thats kind of odd that you would have to do this kind of shit in 2012. check the manual, i bet it will prime on its own.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 02-01-2012, 06:42 AM   #1511
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,834
The other issue with big diesels (dozers, excavators, tractors & such) is that the fuel tanks over time build up sediment in the tanks so when you run them try you tend to clog everything up with crap.
I learned this lesson the hard was as a teenager working at an airport when I ran some equipment out of diesel. I thought it was no big deal but my foreman was pissed and I soon learned why...
btw.. you can run heavy diesel equipment on Jet A if its what you have
Old 02-01-2012, 06:50 AM   #1512
Cycle61
wannabe
Cycle61's Avatar
Oddometer: 347
Spend some time on an aircraft carrier...EVERYTHING runs on JP-5, and most of it is turbine-powered.
Yes, turbine powered forklifts.
Think on that for a while.
Old 02-01-2012, 06:51 AM   #1513
tpirocz
i do what i want
tpirocz's Avatar
Oddometer: 228
its not so much of an issue anymore. they prime pretty quickly. the possibility of sediment getting into the lines is more of an issue.
older merc's were a bitch to start after a fuel filter change. new stuff is cake.
they will also run on transmission fluid...don't do this is the garage tho...
have have no moto
tpirocz is offline   Reply With Quote
Old 02-01-2012, 10:14 AM   #1514
Alti Tude
Alti Tude's Avatar
Oddometer: 256
my 08 Cummins just needs 5 or 6 power cycles with the key to prime the system. Big rigs though can be a pain in the butt, especially on the side of I70, in the winter, with wind blowing nearly hard enough to blow the truck over, after the asshole co driver with the mechanical skills (and personality) of a cockroach runs the rig out of fuel...
Alti Tude is offline   Reply With Quote
Old 02-01-2012, 06:58 PM   #1515
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
My '07 Duramax has a big aluminum pump that you have to pump up then bleed air out of a screw a few times to prime it.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 09:54 AM.
