Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 323 votes, 4.94 average. Display Modes
Old 02-04-2012, 04:49 PM   #1561
tommu56
tommu56's Avatar
Oddometer: 1,407
I have a rural off grid cabin on solar and most of the time excluding wire size the reason to use high voltage to the charge controller is to maximize the time you can get power out of the panels.
Think early morning, and late evening, or cloudy day the 12v panels doesn't get enough sun to make 12v each but they are making 7~8v each then it charges at reduced rate (better than nothing).
The charge controller takes advantage of this and takes the 14-18v and converts it to 12v to charge the battery in essence trying to get as much of a charge that it can squeak out.
I'm running 600watts of panels, outback charge controller 1800AH L16 batteries and outback inverter.
This runs my 450ft well, and some lights, and some small appliances, radio, and TV.
I'm another electrician and I've trouble shot some bad installed solar setups and most of the time Ive found under sizes wires, poor battery maintenance, and not living with in the size of the system.
tom
tommu56 is offline   Reply With Quote
Old 02-04-2012, 04:50 PM   #1562
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,901
All that chain slapping makes me just cringe.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 02-04-2012, 05:08 PM   #1563
tommu56
tommu56's Avatar
Oddometer: 1,407
Originally Posted by pfb View Post
Lots of emergency vehicles (Firetrucks, ambulances) use automatic chain systems. Mountain volunteer fire departments really love them. You wouldn't think they would work well, but actually are pretty awesome. I think ONSPOT even makes one specifically for the Sprinter chassis, so no fabrication work.
Not cheap, but a lot less expensive than making your sprinter a 4x4
Hey, the instachain video even has a Sprinter in it!
As an EX Chief Engineer for 20 years at a volunteer fire co the above chains just don't cut it if you lock up a tire they don't get spun under the tires and cant stopped (ABS helps but isn't the cure)
for quick on off we prefer cable chains
security chain
I can have them on in about 5 minuets with the 2 back hooks you don't have to drive on them just wrap them around the tire and hook them together put the tightener on.
and better performance is reinforced Vbar
tom
Old 02-04-2012, 05:17 PM   #1564
Rodzilla
Horny as Hell
Rodzilla's Avatar
Oddometer: 1,633
Geek you might want to look at auto sock as well
COHVCO/COTPA/BRC/USA-ALL/ARRA/AMA/Moab Parnership
COHVCO Supporter
Rampart Range Motorcycle Management Committee(RRMMC) Past President/VP
Certified SAE J1287 sound tester
Rodzilla is offline   Reply With Quote
Old 02-04-2012, 06:17 PM   #1565
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,033
Holy heck those automatic chain devices look like a maintenance nightware.
I didn't even know they existed.. pretty neat design idea.
HBN: If I had all those batteries in the sprinter, I wouldn't need an engine
Old 02-04-2012, 06:24 PM   #1566
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,517
Well, in CO, lots (if not all) of the mountain departments spec'ed them on pretty much any engine built in the last 10 years. 5 minutes delay to chain up (if your incredibly fast, 15 is probably a closer estimate) is a pretty big additional delay on the already not-super-fast response for the mountain VFD's.
Are four fully chained up tires better than two auto-chains in severe weather? Absolutely.
...Until you hit a dry road, or if the chains are sitting in a box instead of on the tires.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb screwed with this post 02-04-2012 at 06:31 PM
pfb is offline   Reply With Quote
Old 02-04-2012, 06:28 PM   #1567
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,517
Originally Posted by Geek View Post
automatic chain devices ...
Now that you know, you are going to see them on all kinds of medium duty trucks! Even if they are not engaged, you can spot some of the chain segments under the truck.
Maintenance is fairly simple. A pneumatic actuator to rotate them into position and apply controlled pressure on the chain roller wheel against the sidewall. The action of throwing the chain is driven by the tire itself.
Old 02-04-2012, 07:03 PM   #1568
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,100
Time to learn about ways to get myself unstuck if I get it wrong again like I did today... luckily I got it stuck in Nederland and not in the middle of nowhere.
A good LSD such as a trutrac if available, or selectable locker along with quality snow tires & a winch up front perhaps? Reciever mount portable winch be even better, use it front or back & leave it at home when not needed.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 02-04-2012, 08:26 PM   #1569
Alti Tude
Alti Tude's Avatar
Oddometer: 256
We used automatic chains on the trucks I used to drive hauling money for the Fed. I always loved em, but they really don't do too good in reverse either. The best part though is cruising by the chain up areas on I70 while everyone else has to stop and throw iron. In normal use, on normal roads, they work just fine.
Alti Tude is offline   Reply With Quote
Old 02-04-2012, 08:47 PM   #1570
ian408
Oh?
ian408's Avatar
Oddometer: 14,606
I noticed a delivery truck next to me today. No nasty diesel smell. No noise at all. All electric box truck.
Be curious to know what the range is for one of those.
ian408 is offline   Reply With Quote
Old 02-04-2012, 08:49 PM   #1571
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,033
Ian: the ones here in Boulder go 120 miles on a charge
Old 02-04-2012, 08:54 PM   #1572
ian408
Oh?
ian408's Avatar
Oddometer: 14,606
Thanks. That's first one I've seen.
Old 02-04-2012, 09:44 PM   #1573
RLK
4,949
RLK's Avatar
Oddometer: 6,516
What happened to the stock wheels? If they're still around you could stud tires on them. Its quite a magic carpet you are running around in these days!
RLK is offline   Reply With Quote
Old 02-04-2012, 09:53 PM   #1574
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,033
Hey Matt!
It has been far too long since we hung out with that dog while you changed your oil....
Old 02-04-2012, 10:57 PM   #1575
Hardware02
Hardware02's Avatar
Oddometer: 3,412
The auto chains look neat but I suspect you may be losing some ground clearance.
What about a locker (would also help during summer softroading) and studded snow tires?
A winch would also be a useful addition year round.
"These instructions are at our present level of
knowledge. Legal requirements do not exist.
Technical issues subject to change."
Hardware02 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 05:55 AM.
