03-21-2013, 06:46 AM
#2551 |
oot & aboot
Oddometer: 26,164
I have rust specs appearing on my rear doors already
![]() Where sand/gravel swirels behind the van and pits the paint - since there is no clear coat or anything I have little rust flecks appearing. New paint my be on my schedule sooner than later to nip it in the but before any real damage occurs.
www.motogeek.com |
03-21-2013, 06:48 AM
#2552 | |
Oddometer: 100
I want the Ford to be a winner, but the lack of wheelbase options, GVRW, possible bad MPG. There is no way in my book. The plus' are possible 4x4, modern interior and cheap. That said, I will be placing an order for a new sprinter within the next month. |
03-21-2013, 07:21 AM
#2553 | |
oot & aboot
Oddometer: 26,164
Footnote: if I were not using this van as a daily driver for my business (i.e. a dedicated play toy) I would buy the 170".
www.motogeek.com |
03-21-2013, 07:40 AM
#2554 | |
equitem casus
Oddometer: 2,634
What I heard...
I got my used Sprinter from my local Mercedes dealer. *The salesman said* that Sprinters made under the Dodge and Freightliner brands, while made here in the USA, were made to US specifications. We were talking about the rust on my van. From this I assume he meant that the German specifications for quality are higher. I don't know if this has any merit or not. I can't compare to the durability of European made vans. Interesting concept, none the less.
Think beyond yourself.~ap blog Max the Motorcycle - children's book written by Mrs. FTB SmugMug Photo Gallary |
03-21-2013, 07:58 AM
#2555 | |
Observant as never
Oddometer: 1,075
![]() I still think owners should complain more because it's not a cheap vehicle, and having vehicles 2-3 years old with surface rust is not acceptable in my books... Ko
no snowflake ever feels responsible for the avalanche... |
03-21-2013, 08:10 AM
#2556 | |
oot & aboot
Oddometer: 26,164
It is the same for european and domestic. Fact about all sprinters: If you buy the basic white - even a brand new one right now - it is just a coat of paint without any type of clear coat or anything. Any type of nicks (including gravel pitting from the tires etc which is what I have lots of because I travel a lot of dirt in mine) and you are on bare metal - which will rust quickly/easily. If you buy a sprinter with an upgraded paint job ($600-990 option in a color at time of order depending on metal flake, etc) then they clear coat the paint after they paint it - so you end up with a much better lasting paint job. I knew this fact going in with my white van - but I figured if I was going to wrap it for my business then white was the best color - or if I decided not to wrap it, the money I saved in my initial purchase price could go towards a quality aftermarket paintjob when the rust started to appear - which is why I have a bee in my bonnet right now The bottom of the NCV3s (the stuff out of sight) is completely "gooped" in a kind of rubbery soft rhinolining'esque coating that nicely protects all of the underside. I don't know if the T1Ns have this or not. You can see that rubbery coating on my van in this photo: ![]() Hope this helps. ![]() p.s. full disclosure: I've not bothered to wax my van (the damn thing is as big as a house.. it'd take 2 days
www.motogeek.com |
03-21-2013, 11:51 AM
#2557 |
equitem casus
Oddometer: 2,634
Replace the glow plugs every 50k
![]() They can get nasty to remove if you're not careful. My plug #4 had its connection to the wire harness rusted and seized. Two of the plugs needed some persuasion to be removed from the engine head. I've seen it suggested in some manual that the glow plugs should be changed every 50,000 miles to prevent problems. They are not cheap, but better than the alternative. I just had a thorough service done since I don't know when it was last completed. All glow plugs, filters, fluids changed. Had to replace the tail pipe. Leaf spring needed some service to realign and re-torque. And a state inspection. Now I know where it stands for maintenance. It's ready to roll for another couple hundred thousand miles (currently at 158k).
03-21-2013, 12:30 PM
#2558 |
oot & aboot
Oddometer: 26,164
Can I just pull the plugs and lube/anti-seize them and put them back in?
My van is under warranty to 100k - I wonder how I could convince them to do it under warranty
www.motogeek.com |
03-22-2013, 08:24 AM
#2559 |
equitem casus
Oddometer: 2,634
P rated tires...
I thought I'd share this with you guys...
I just got back from my local tire shop. I replaced all four tires with new ones. The rear tires that were on the van when I got it looked new. The front ones were dry and cracking. I thought I only should replace the front tires...until the tire guy showed me the rating on the rear tires. They were P rated (passenger car), not LT rated (light truck) like it should be for a vehicle of this capacity. That could have been extremely dangerous. And...because I was unaware of the rear tire rating, I inflated them to 70 PSI as per the sticker on the B pillar. P rated tires should only be inflated to 41 PSI. All sorted out now. These ones are LT rated - Firestone Transforce AT.
03-22-2013, 08:36 AM
#2560 | |
Observant as never
Oddometer: 1,075
However, LT rated doesn't mean much- I always go for E rated tires, as in 10 ply. Ko
03-22-2013, 09:05 AM
#2561 |
oot & aboot
Oddometer: 26,164
I run e-rated as well... but I load the van pretty heavy at times.
My van weighed 5440lbs completely stripped/empty.
www.motogeek.com Geek screwed with this post 03-22-2013 at 09:10 AM |
03-22-2013, 12:26 PM
#2562 | ||
Oddometer: 2,482
My friend has those on his Superduty that he uses to pull trailers (owns a trailer biz) all over the midwest. Last night, he was telling me he weighed his truck and it showed just over 8200lbs. He says those tires wear like iron. At least, with an LT tire, you're getting heavier sidewalls, which are more stable than a passenger tire. Furthermore, the weight rating is going to be much higher, irregardless of what ply you choose.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
03-23-2013, 04:32 AM
#2563 | |
Rally Dreamer
Oddometer: 1,588
that can be a bit dangerous! Glad you caught it. I had the same thing happen to me several years ago on a used F350 that I bought. I assumed I needed to do some suspension work on it because it drove like crap but turns out it was just the sidewall flex. Once I put on proper tires it drove great. I suspect you will notice some handling improvements on the van too.
follow my journey: Dreaming of Dakar Special thanks to my sponsors: Freedom Cycle of Concord NH BRP Renazco Racing MX1West Help support my racing addiction and look cool doing it! Buy a T-shirt or hat from the Dakar Dream Store |
03-23-2013, 06:41 AM
#2564 |
No, not that Trixie
It's been quite a while, so i thought somebody should chime in:
Geek, you suck.
---------------------------------------------------- One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors. - Plato The important thing is this: To be able at any moment to sacrifice what we are for who we could become! Charles Dubois |
03-23-2013, 10:25 AM
#2565 | |
All idiot, no savant
Oddometer: 8,299
| Thread Tools | |
