Thread Tools Rating: Thread Rating: 223 votes, 4.92 average. Display Modes
Old 09-29-2013, 12:50 PM   #3091
bouldergeek
Filthy, poor KLR dweeb
bouldergeek's Avatar
Oddometer: 1,074
Originally Posted by pfb View Post
Nice! You need to start thinking about an epic trip (Denver to Tierra del fuego?) with your bride, bikes, Yeti and Sprinter.
Currently reading this thread from Tierrra del Fuego. I concur.
Man, do I wish that I had that kit down here!
Sent from my GT-P7510 using Tapatalk 4
Partir loin et découvrir quel air l'humanité respire... voyager... aller toujours plus loin... - Les Nubiennes, "Voyager"
From the End of the Earth to the End of the Road: South Pole to the Darien
bouldergeek is offline   Reply With Quote
Old 10-14-2013, 02:16 PM   #3092
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
Building an Adventure Van
The time has come...
edit: not that time
Way back when I was looking to turn my aluminum wheels black, a bunch of folks mentioned plasti-dip.
For those wheels I went with powder coat.
I think it is going to be a snowy winter around here this year and my BFGs are pretty much done. So I'm going to throw the stock steelies back on the van with the original tires (which are supposed to be pretty good in the snow and have less than 7k on them).
The issue is.. in my mind, all wheels should be black - and the silver steelies are some of the ugliest wheels ever
Time to give plasti-dip a try.
Old 10-14-2013, 02:24 PM   #3093
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
Its also time to get started on the hinged cabinet doors (as opposed to the sliders I've already put in).
Holy crap I had no idea there were so many type of cabinet hinges
faceframe... frameless...full overlay.. half overlay.. inset.. shock absorbing... etc. I just want hinges that screw into 15 series 80/20 with an M8 bolt on one side and wood on the other side. Open when I pull and close when I push. Is that too much to ask?
Old 10-14-2013, 02:59 PM   #3094
James Adams
Misplaced
James Adams's Avatar
Oddometer: 9,865
I'm interested to see how it holds up to your brand of abuse winter!
James Adams is offline   Reply With Quote
Old 10-14-2013, 03:02 PM   #3095
TooFast
TooFast's Avatar
Oddometer: 1,192
What's the beef with sliders? (curious before I build mine)
Some Neo magnets outa keep those hinged doors closed even with that stability software working away
TooFast is offline   Reply With Quote
Old 10-14-2013, 03:41 PM   #3096
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
the slider doors? no beef.. love 'em!
All of the overhead cabinets have sliding doors and they work great.
The lower cabinets (under the counter tops) do not have the width for a slider door... (one cabinet is 10" wide for example) so a hinged door will work better in that situation.
For example the cabinet space to the right of the fridge door in this photo (which in the photo has a couple of solid boards - but will be a fully functional two shelf cabinet) needs a hinged door:
old photo:
Old 10-14-2013, 04:14 PM   #3097
Big Bird 928
Oddometer: 2,568
old photo:
What type of door do you want to have on the cabinet? one that sits inside the channel (like the boards you pointed out next to the refrigerator) or over the front of it (like most kitchen cabinets have)?
If you really want to get slick and techie, make that spot a partial cabinet and make a motorized slider drawer on the bottom complete with dog bowls for your puppy.
Originally Posted by Smithy View Post
Didn't take me long to sort out the derpapotomous tactic again.
Big Bird 928 is offline   Reply With Quote
Old 10-14-2013, 04:26 PM   #3098
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
THe bottom of that cabinet area has two 10 inch subwoofers in it - so only the top 2/3 will be cupboard space.
Ideally I'd like recessed doors kinda like how the wood is. The goal is to keep the entire isle "snag free".
Old 10-14-2013, 04:33 PM   #3099
Big Bird 928
Oddometer: 2,568
Ok, so I am thinking a "Push pop" cabinet setup is what you are looking for along with the recessed doors and concealed hinges, I will see what I can come up with.
What does the inside look like for a hinge to attach to? Is there wood there to bore a ressess in to?
Big Bird 928 screwed with this post 10-14-2013 at 04:46 PM
Old 10-14-2013, 05:00 PM   #3100
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
Push pop is exactly what I'm aiming to do.
The issue is there is not wood to mount the "cabinet" side to.. (i.e. I can't bore one of those big holes) - because it'll be mounting into a t-slot on the 15-series 8020. (i.e. 1.5" square)
i.e. the cabinet corners are made of this stuff:
So basically my mounting option is the slot facing the cabinet opening (as the slot behind it contains the cabinet wall).
In some of the cabinets I might have the option to mount to the wooden wall - but then the hinge would have to have the ability to step out and around the aluminum 1.5" corner piece.
Old 10-14-2013, 05:21 PM   #3101
Big Bird 928
Oddometer: 2,568
ok, thanks. I may have to call my friend the cabenet maker for ideas, that may take a while as first we have to talk about some model A's and T's then 8n's and flatheads in general... you get the idea.
Old 10-16-2013, 06:50 AM   #3102
ducnut
Oddometer: 3,316
Stumbled onto this and immediately thought of you.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 10-16-2013, 06:59 AM   #3103
epicday
epicday's Avatar
Oddometer: 69
How do you like it?
I did mine when I first got the van and I love it. I even plastidipped the rear emblem on the back door and the wheels on my trailer..... Great stuff. Hope that you like it.
edit: not that time
epicday is offline   Reply With Quote
Old 10-16-2013, 10:01 AM   #3104
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,461
We have hit a cold spell so I'm stuck waiting until it warms up enough to spray.
I'm seriously considering doing the back doors on the Van as well... they have small little rust specs from all the rock chips (I drive on gravel roads a lot).
Old 10-16-2013, 10:36 AM   #3105
tweetie
tweetie's Avatar
Oddometer: 2,056
This is what happens when you get bored? We end up with a multicolored van?
tweetie is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:35 PM.
