Thread Tools Rating: Thread Rating: 256 votes, 4.93 average. Display Modes
Old 12-15-2013, 08:33 AM   #3211
Audaciter
Audaciter's Avatar
Oddometer: 7,027
Originally Posted by Geek View Post
Hey where were you yesterday?
Grinding a new Tier 7 TD...
.mobile
Helping one of my soldiers move....in a snow storm.
I did find another one of your videos though. This isn't quite as hard hitting as the unboxing above, but close.
- Kris
Audaciter is offline   Reply With Quote
Old 12-16-2013, 10:06 AM   #3212
ducnut
Oddometer: 3,320
The great thing about that fabric is the weave isn't such that it shows not being perfectly lined with the edge of a panel. I think it's a great choice and looks really nice and factory.
I'm guessing, a finishing washer/screw system would look pretty nice and be absolutely secure.
I'm not sure push fasteners could be used, without a foam underlayer to hide its appearance under the fabric. Then, you'd have to find a style that's long enough and completely flat across the head. Of course, installing the panels and not allowing the fastener to push out against the fabric could be a challenge, too.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 12-16-2013, 10:31 AM   #3213
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,494
I agree. Push fasteners would be non-servicable also.
Could pop a hole, soldering iron on the fabric after wrapping, then use those Honda style plastic rivets. Would save lots of time on riv-serts
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 12-16-2013, 10:48 AM   #3214
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,695
One of the biggest headaches on this project is sourcing what I need.
3 local lumberyards.. none carry 1/8" plywood.
none carry 1/8" closed cell foam sheets.
I did manage to find this contact cement that was recommended
Old 12-16-2013, 10:49 AM   #3215
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,695
Originally Posted by TooFast View Post
Can you show a backside pic of the wedge cuts vs stretching and stapling?
Seems as though flatter the better for mounting/appearance - maybe even glue the panels in place and not have numerous fasteners showing?
Having a hard time seeing how batting would improve anything except hold moisture
Here arethe original two corners... in the next post I'll show some more stuff I just tried
Old 12-16-2013, 11:03 AM   #3216
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,695
Experimentation.
Since I don't know what I'm doing, I am trying to pick pieces that do not really matter, and that are less expensive to screw up. Even with the part I attempted today, there is probably $30 worth of materials on the line if it goes wrong.
Education is expensive
I figured my "next easiest" piece to try would be one of the lower door panels:
Not having any luck finding 1/8" ply locally, I thought I would give some 1/8" masonite a try
I traced the shape onto the masonite with a sharpie:
1 minute with the table saw, 5 minutes with the band saw and 1 minute with the drill press and I have this:
Checking to make sure which side of the masonite faces outward:
Cut out a big enough piece of interweave
Spray it with contact cement, let it sit a few minutes
...then start folding over and stapling
First corner I tried this.. seemed to work ok:
For this concave curve I just cut slits and pulled:
Tried just cutting slits on this and pulling too
Pneumatic stapler is making life sooooooo good (I would have hated to try and hand press staples into masonite)
Flipped it over and.... saw that there is a big wet stripe where I put the contact cement on too thick
Other than that it came out great. Whether that wet spot will go away when the cement dries? No idea.
I guess I'll know in a few hours.
Oh well, lesson learned, be more careful with the cement (especially when it is cold and I'm working below its recommended temperature. Perhaps I need to warm the glue cans up in some hot water first
Used a punch to locate the holes
and used the stock press fasteners to mount the panel on the door
The results:
Old plastic on the left, new tweed on the right:
This photo reminds me... I need to grow a pair and cut the holes for the back windows still
So there it is.
If the cement stripe doesn't dry/disappear, I've spent $30 on more education.
If it does dry.. it looks good!
Geek screwed with this post 12-16-2013 at 11:10 AM
Old 12-16-2013, 02:00 PM   #3217
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,206
Can I ask why you are replacing the panels and not just covering the OEM ones ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 12-16-2013, 02:37 PM   #3218
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,695
The OEM panels are coroplast... When we bought the van it didn't have windows so the coroplast panels are not the right shape for what we are doing.
This particular panel I could have just covered but I specifically wanted to use it as a test for working with the Masonite which I'm hoping to build the walls and ceiling with.
.mobile
Old 12-16-2013, 03:22 PM   #3219
TooFast
TooFast's Avatar
Oddometer: 1,253
Oh well, lesson learned, be more careful with the cement (especially when it is cold and I'm working below its recommended temperature. Perhaps I need to warm the glue cans up in some hot water first quote
If the garage is too cold, why aren't you working adhesives on the kitchen counters, living room, etc? Kitchen ovens work great for heating/hardening spray paints, etc....
TooFast is offline   Reply With Quote
Old 12-16-2013, 07:25 PM   #3220
SafetyThird
SafetyThird's Avatar
Oddometer: 424
Because when I do that I have to sleep in the garage
SafetyThird is offline   Reply With Quote
Old 12-16-2013, 07:44 PM   #3221
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
That panel looks nice. Masonite is not my favorite material. . . if you could get 1/8" baltic birch, that stuff is really the shit for what you're doing- around here the hardwood/cabinet maker supply place has it for $10 per 5'x5' sheet. The other option is (nominal) 1/4" birch ply in 4x8 sheets, it's usually more like 3/16" or even a bit thinner, it's definitely not 1/4".
Have you tried any panels with a thin foam behind the fabric or with the padding you got?
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 12-16-2013, 07:53 PM   #3222
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,695
The local lumberyard has 1/4" ply (which is 3/8) but it is quite a bit heavier than the masonite and not nearly as flexible (I need to be able to match the curves of the ceiling/walls).
We haven't tried any foam backing yet. Apparently OSV uses 1/8" ply with 1/8" closed cell foam glued to it.. then the fabric.. that said I can't find 1/8" closed cell foam fabric sheet anywhere locally and am hesitant to order $100+ worth of the stuff without testing it first.
Chicken & Egg.
Old 12-16-2013, 08:04 PM   #3223
mcook0525
mcook0525's Avatar
Oddometer: 29
In my limited experience of working upholstery, that glue spot should clear up. I've seen and done much worse, and they all disappeared.
mcook0525 is offline   Reply With Quote
Old 12-16-2013, 08:13 PM   #3224
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,032
...as long as it wasn't <15C when the glue was applied, it'll just disappear completely.
Well, really, I have no idea.
505 XC-F DUKE 690
James Adams is online now   Reply With Quote
Old 12-16-2013, 08:40 PM   #3225
slackmeyer
slackmeyer's Avatar
Oddometer: 3,125
Chicken & Egg.
Yeah. All I can say is that if there's a local place that does hardwood/cabinet grade plywood, that's where I'd head to look for some nice 1/8" ply. I'd send you some, but I get the feeling that shipping plywood is not going to be economical
I see a lot of stuff packed in the thin (1/16 or 1/8") closed cell white foam, especially appliance parts. Maybe some of that would give you an idea of the look if you thought you wanted to try it. And These guys have 1/8" foam pretty cheap.
Zak
ktm
old bmw
others
Thread Tools
Times are GMT -7.   It's 04:10 PM.
