Thread Tools Rating: Thread Rating: 256 votes, 4.93 average. Display Modes
Old 01-18-2014, 12:46 PM   #3331
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,485
Pin Gauge do you any good for copying the corners?
http://www.lowes.com/pd_14154-56005-...ductId=1016371
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 01-18-2014, 01:18 PM   #3332
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,485
You can also get these that are up to 107" long.
http://www.woodcraft.com/category/5/...Templates.aspx
I like the pin gauges but I have only seen them up to 12" so if you want to do the whole wall at once you need the long ones the woodworking guys use.
06 Ural Patrol
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
Old 01-18-2014, 01:43 PM   #3333
pvangel
Team AARP
Oddometer: 2,600
Originally Posted by Geek View Post
Hard to tell the width in the photo... Is that stuff this?
.mobile
Yes, Thats it!
pvangel is offline   Reply With Quote
Old 01-18-2014, 05:00 PM   #3334
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
+1 - was just about to post pics of contour gauge - template your radiuses, router quality ply with staggered length parallels then bridge, screw and glue. Lots of labor but geek worthy result. If confusion, blame authors time zone.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 01-20-2014, 02:01 PM   #3335
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
This is a lot more difficult than it should be...
curves suck.
My delusions of perfect, curved, inset, seamless window sills are quickly receding.
I think I might cheat and do the equivalent of "crown molding" to make it easier (i.e. hide imperfections.)
Old 01-24-2014, 04:36 PM   #3336
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
2 minutes into this video they demonstrate how the computer pulses the brakes when you are stuck (related to what we were talking about)
If you haven't seen it.. after that they do an ASR demo.. pretty cool:
Old 01-24-2014, 07:18 PM   #3337
ducnut
Oddometer: 3,320
I'm convinced you posted that video so YT would post up this suggested video.
http://www.youtube.com/watch?v=TFArrMWlg74
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 01-25-2014, 05:38 PM   #3338
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
The Mrs. and I got a few hours in on insulating today..
The final layout will be:
van skin - d-amplifier - MLV soundbarrier - recycled denim - reflectex (air sealed for vapor barrier) - internal wooden wall - closed cell foam - interweave fabric
fully insulated the "pocket" where the door latch goes - because it it right by our heads when sleeping I took extra time to insulate and seal it as well as possible:
The outer layer of reflectex is being sealed:
The ceiling is generally tricky to insulate - and some of the most important insulation of all (keeping the heat out in the sumemr). With the ceiling I bought this stuff that is a pre-laminated sheet/thermal barrier
which then gets contact cemented to the ceiling:
...and then reflectexed-bonded down to the wall's seal.
I'll then spray "expandable foam" into the spars themselves.
I think I'll also line the back side of each ceiling panel with reflectex as well so there is a double layer of insulation in the ceiling with an airpocket between.
Still a long ways to go.. including disassembling each door and stuffing it with insulation.
This is definitely going to make the camping at the Elephant Ride this year (in 2 weeks) a lot warmer!
Last year it was something like -15 degrees overnight and the Espar ran full tilt all night.
Old 01-28-2014, 11:00 AM   #3339
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
22 deg. Heat set to 72. Fan speed as low as it'll go and it's hot in here. Woot!
.mobile
Old 01-28-2014, 12:18 PM   #3340
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
congratulations
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 01-28-2014, 04:43 PM   #3341
TooFast
TooFast's Avatar
Oddometer: 1,250
Ouchy
Those long extended fan mounting screws.... have you and Tweety been able to avoid hitting your heads on those?
TooFast is offline   Reply With Quote
Old 01-28-2014, 05:20 PM   #3342
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
The are higher than the spar.. when the ceiling goes in there is a fan shroud that then goes over the ceiling and all of that disappears.
Old 01-28-2014, 05:53 PM   #3343
Audaciter
Audaciter's Avatar
Oddometer: 7,020
Doh. The legend himself beat me to it!
- Kris
Audaciter is offline   Reply With Quote
Old 01-29-2014, 02:05 PM   #3344
TooFast
TooFast's Avatar
Oddometer: 1,250
They named me "TooFast" for a reason, you should have known!
Old 01-29-2014, 02:25 PM   #3345
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
Problems in the bedroom?
Thread Tools
Times are GMT -7.   It's 01:47 AM.
