Thread Tools Rating: Thread Rating: 188 votes, 4.90 average. Display Modes
Old 11-12-2011, 06:51 PM   #751
arapaho
arapaho's Avatar
Oddometer: 110
Digging this....
I just moved home to Boulder after waaay too long elsewhere. I showed this thread to my wife, and she gave the thumbs up. We had a diesel VW camper when we lived in Europe and I had an older poptop aircooled bus "before wife", so I'm not too surprised.
We are looking at a different setup though, since we're a family of four. Need to have a place for the kids to sleep too. But I'm following your build with eager eyes.
If I see you in town, I'll give a wave or if you're stopped, say hello.
arapaho is offline   Reply With Quote
Old 11-12-2011, 07:39 PM   #752
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,861
Originally Posted by Geek View Post
That's beautiful man!
See? And today I didn't accomplish such beautiful things. Only cruise control & speedometer. Put the two of us together and we'd have one hell'of a beautiful, drivable and cost effective rig!
I love your build. Next one I do will probably be a full-up build: drive line, body & interior...... I'd better enjoy what I've done so far first.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 11-12-2011, 08:07 PM   #753
jake28
Riding to the horizon.
jake28's Avatar
Oddometer: 391
Does 80/20 make a specific router bit to match their material?
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS
jake28 is offline   Reply With Quote
Old 11-12-2011, 08:29 PM   #754
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,288
Dunno.. good question.
With 15 series the slot is basically about 8 mm wide. With 40 series it is about 9mm wide.
Make your panels less than that width and they'll slide in.
I'm just using the router with a square cut bit on the router table to take enough thickness off the edge so it'll slide in.
It'd be pretty cool to actually be able to route a "t-slot" and lock the panel into the housing!
If your panels are quite a bit thinner than that, 8020inc does sell "panel gasket" which is basically a piece of rubber that goes in the slot to keep your panels from rattling around.
Geek screwed with this post 11-12-2011 at 08:34 PM
Old 11-12-2011, 08:52 PM   #755
Lovin' it Strom
Now low fat!
Lovin' it Strom's Avatar
Oddometer: 2,823
What about routering a slot running the length of the board and inserting a peice of T channel to slide into the frame channel, tap and nail or screw from the hidden side to lock in the t-channel. Get this done with a biscuit bit. Let's see if I can present a graphic to explain.
XXXXXXXXXXXXXXX____0
XXXXXXXX0010000000000
XXXXXXXXXX1XXXX''''''''''''0
This should give the best strength and durability and is easier. Set your depth cut so the aluminum channel is flush with the finished side of the board and fine sand to match perfectly. Seal it with lacquer to finish.
When we leave a place a part of it goes with us and a part of us remains
Lovin' it Strom screwed with this post 11-12-2011 at 08:57 PM
Lovin' it Strom is offline   Reply With Quote
Old 11-12-2011, 09:51 PM   #756
jake28
jake28's Avatar
Oddometer: 391
Lovin' it Storm, good attempt at the graphic representation. I was with you until the screw from the backside, which I don;t understand how you could do. With the router at the correct level, I think you could sandwich the aluminium T bar and the wood tightly enough that the screws would not be necessary.
Old 11-12-2011, 09:59 PM   #757
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,288
ok.. instead of geeking on stuff I've already figured out.. how about you hoseheads explain to me the best way to do 80/20 openable panel doors and fold-able bed frames
Right now the idea is that the passenger side rear-cabinet has a 90 degree hinge on top with a 27" panel that folds up and clips to the top cabinet when the bed isn't in use (and stores the bedding/bed out of sight)... then folds down across the isle and completes the bed platform (but I'm not quite sure how it connects to the 80/20 on the other side )
Old 11-12-2011, 10:00 PM   #758
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,490
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 11-12-2011, 10:04 PM   #759
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,288
That's the opposite Paul... you'd need a male instead of the female in the wood to join the extrusions
Old 11-12-2011, 10:11 PM   #760
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,288
At the moment.. I think Cheryl & my feeling is that all vertical surfaces will be the maple.
All horizontal surfaces will have carpet (including the ceiling).
We're still debating the carpet color: grey or dark brown.
The other color we're teething on is the accent color; orange or green
Tonight's "in van layout" seems to have the isle width at about 27".
This would mean my 950 will not fit inside although any dirtbike (like my 610; which most are smaller than) would fit easily and mountain bikes will fit fine
Old 11-12-2011, 10:30 PM   #761
Lovin' it Strom
Now low fat!
Oddometer: 2,823
Go with all appliances being in light yellow, orange walls and green shag.
I was saying put a nail or screw in to be sure the T-channel won't pull loose from the wood if it were to be pulled on. Just the most secure way esp when talking about a lot of temperature and humidity changes along with vibration and such these will be subject to.
As for a fold up bed, have you looked at wall bed hardware and design ques?
Old 11-12-2011, 10:37 PM   #762
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,490
The bottom two pictures... T-bolts into threaded inserts. How thick are the panels going to be?
Old 11-13-2011, 12:22 AM   #763
troidus
Oddometer: 14,273
Sounds like you need a full-width bed for the adults, and swing down bunks (one each side) above the main bed for the kids. Or, put the kids above the cockpit. Or modify the sides so the window panels can push outboard when parked and put the kids there.
troidus is offline   Reply With Quote
Old 11-13-2011, 08:07 AM   #764
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,815
Travertine floors for the win!
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 11-13-2011, 08:37 AM   #765
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,856
Needs more mirrors.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:09 PM.
