Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 324 votes, 4.94 average. Display Modes
Old 11-15-2011, 08:35 AM   #796
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
With the number of deer around here I really should get a nudge bar... I've been trying to reduce the number of things I stick on the outside of the van due to aerodynamic drag = reduced mpg.
General consensus seems to be that a roof rack alone on a Sprinter costs it about 2mpg
Old 11-15-2011, 09:12 AM   #797
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
Connectors = 8020 versatility?
standard t-slot nut. allows you to slide whatever you are fastening to it anywhere along the channel that you like
"roll-in" t-slot nut with spring-loaded ball. If you have your assembly all together and want to add something later without taking it apart.. these guys roll into the channel without needing an end to slide in
these guys are the opposite.. giving you a stud anywhere along the channel you want to attach an item:
These guys are the strongest corner anchor 8020 makes. They do require some drilling/machining to countersink. I'll be using these on the main corner intersections of the bed to make sure it is strong enough.
These other connectors are ones I've shown before - I'll be using them for various intersections:
I actually bent one of these $9 jobbies
with all of these connectors.. bolt lengths become pretty important. You need bolts that go in far enough to fasten securely but not so far that they bottom out in the t-slot.
Old 11-15-2011, 09:50 AM   #798
tweetie
tweetie's Avatar
Oddometer: 2,065
Originally Posted by Bonnie Abbzug View Post
Yay! Einstein!!!!
Yeah, he's pretty special. Especially at midnight when he's tearing up the apartment and my arm playing Spidy Cat.
He's a good kitteh even when he is a demon spawn.
tweetie is offline   Reply With Quote
Old 11-15-2011, 10:25 AM   #799
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,821
That's about right on my S320 too. Add bicycles and it gets much worse.
For example: trip from NoVA to Denver... Set the cruising control at 74mph and went toodling down the road. Got 24mpg
On the trip back from Denver to Nova, I had 3 bikes and an extra pair of wheels on the top. Set the cruising control at 65mph and got 20-ish mpg
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 11-15-2011, 10:27 AM   #800
Gummee!
Gummee!'s Avatar
Oddometer: 28,821
Paul at HDB couldn't make you up any of those for less?
M
Old 11-15-2011, 10:34 AM   #801
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
M
Yeap, hitch racks rule for gas mileage and reduced wind noise.
EJ_92606 is offline   Reply With Quote
Old 11-15-2011, 10:44 AM   #802
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
M
Paul's a very busy guy.. he has better things to do.
That said I did get some aluminum stock from Paul so I can make more myself
Old 11-15-2011, 10:45 AM   #803
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
Is it bad when 3 people who work at Home Depot have gotten to know you buy name... and you get asked "how's the van build going?" when you walk in?
...another $53 in bits
Old 11-15-2011, 10:55 AM   #804
troidus
Oddometer: 16,289
Get some of this to save your bits:
http://www.yardstore.com/browse.cfm/4,5588.html
troidus is online now   Reply With Quote
Old 11-15-2011, 12:38 PM   #805
Bonnie Abbzug
Property of Hayduke
Bonnie Abbzug's Avatar
Oddometer: 10,349
I can't believe he hasn't grown out of that yet! We have to lock Malo in the back room at night, or we'd never get any sleep. He's 9 yrs old, so maybe some cats just never grow out of that!
Bonnie Abbzug is offline   Reply With Quote
Old 11-15-2011, 01:05 PM   #806
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
Ed, forgive me if I'm over-thinking (or even more likely under-thinking), but you are taking into account the natural expansion and contraction of wood with changes in temperature and humidity, right?
I can just see a now-perfectly-sized plank shrinking and pulling out of the slot(s) or expanding and buckling or causing mount deformation.
Brad Felmey is offline   Reply With Quote
Old 11-15-2011, 01:14 PM   #807
Brad Felmey
Oddometer: 5,002
Originally Posted by geode View Post
I thought he wrote that they picked maple as their wood of choice. maple is very stable and I think fairly unlikely to buckle the 8020.
I am an ignoramus when it comes to the material properties of wood. We didn't really study it much in college materials science class.
Old 11-15-2011, 01:38 PM   #808
ducnut
Oddometer: 3,321
the number one thing I can tell you about wood ...
if someone knows you turn wood on a lathe for fun, and that you collect chunks of logs to turn into bowls and such, and they give you a chunk of camphor tree ...
DO NOT TURN IT!!
instant chemical bomb goes off the moment your turning tool hits the chunk as the sap / liquid sprays everywhere and shuts down your lungs.
damhik
(thank gawd the shop door was 4' away, and already open)
Maybe that was their "inside joke".
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 11-15-2011, 02:02 PM   #809
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
I get those comments there too.
but I never get in and out for $53.
Yeah I just bought some washers and M6 nuts... oh.. and a big ass drill bit
Previous 3 times have been $800+ each time
Old 11-15-2011, 02:03 PM   #810
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 32,062
I have.. and I'm leaving more than the prescribed amount of expansion space.
I think they said something like a 1/4" of expansion over a 22 foot room...
Thread Tools
Times are GMT -7.   It's 09:54 PM.
