11-19-2011, 07:59 PM
#886 |
oot & aboot
Oddometer: 25,746
www.motogeek.com |
11-19-2011, 08:43 PM
#887 |
oot & aboot
Oddometer: 25,746
I think we've decided to change things up a bit. We really love the light color and warmth the maple brings to the interior.
We're going to do the entire floor in the maple hardwood as well as the cabinet ends (like we've done so far). I bought more than enough to do the job twice.. so if it wears over the years I can completely replace it easily (and it has a 55 year warranty ).Then we'll use some indoor/outdoor (rubber backed) carpet throw rugs on top. This will make clean up super easy; being able to remove the rugs to beat them and sweep the hardwood underneath. I'm going to keep a 6 foot by 24" rubber isle roll-out for when I put a dirt bike in or for when I'm putting the mountain bikes in all muddy. We're going to change the walls between the bed and the overhead cabinets and cover them in matching vertical carpet (i..e creating something flarespace compatible). I'm still undecided on cabinet doors. My inclination at this point is to get a few cabinet frames/ends done and then try a few different solutions and see what looks best.
www.motogeek.com |
11-19-2011, 08:51 PM
#888 |
More wag; less bark
Oddometer: 11,800
Gotta say that I like the clean look you've got going so far.
11-19-2011, 09:25 PM
#889 |
oot & aboot
Oddometer: 25,746
we're doing 6 doors overhead (4 driver's side, 2 passenger side) and then 5 rear cabinet lower doors.. and then who knows how many in the kitchen and slider cabinet.. probably another 5.
I gotta admit.. I just spent the last hour searching tambour again It is hard to find quality/nice stuff.. but it is ~$9 for a 5/8" by 8 foot slat (that's $9 PER slat ).i.e. the overhead doors alone would be ~$1000 ![]() What are "face frame doors" geode? Have a link or some pics? ![]() ![]() ian: Thanks
www.motogeek.com |
11-19-2011, 10:18 PM
#890 |
Tambour router bit set
If you're interested in making the tambour doors - they are pretty simple as long as you take your time and make sure everything is laid out correctly. Here is a link to Rockler.com that sells the router bit set to make your own tambour pieces.
http://www.rockler.com/product.cfm?p...filter=tambour This way you could use the same maple wood you have for the sides of your cabinets to match. Rockler has a bunch of other pieces tambour related that may help you. Either Rockler.com or Woodcraft.com is a great source of wood working things. I have a bunch of other companies I use to get pieces for cabinet making. Maybe with making your own pieces you could use the 8020 as the track. Rockler sells the cable and spring for the tambour doors but I'm not sure that would be a great choice in a vehicle. |
11-20-2011, 06:02 AM
#891 |
oot & aboot
Oddometer: 25,746
Thanks for the info!
![]() Of course I'm an idiot so I want "aluminum" slats ![]() Searching "rv tambour" brings up tons of airstream links. Apparently the old airstreams had tambour rollers overhead. Here's a video I found.. the slats I'd love to use would look just like these: but unfortunately.. those are the ones I've only been able to find for $9/slat ![]() Maybe I could route my own... and then paint them to look like that...
www.motogeek.com |
11-20-2011, 06:08 AM
#892 | |
oot & aboot
Oddometer: 25,746
"Honey.. the furnace room needs a tambour door eh?
www.motogeek.com |
11-20-2011, 06:24 AM
#893 | |
oot & aboot
Oddometer: 25,746
8020 makes a bunch of different hinge options that'll allow us to mount the hinges right in the track. On the lower cabinets the doors will likely have to be "inset" so that I leave the 8020 grooves exposed facing the isle. One of my goals with the 8020 is to have a collection of "click ins" that can be used in the isle as bike holders, motorcycle mounts, mounting rails, etc. I'm still garnering this fantasy that I can roll a dirtbike into the van and go "click!" and walk away with it securely in place. I'm envisioning a custom machined piece on the bike that an 8020 bracket snaps onto. Maybe I should just buy an 8020 RAM ball and a really long arm and clip to the RAM balls on my handlebars (j/k) ![]()
www.motogeek.com Geek screwed with this post 11-20-2011 at 06:34 AM |
11-20-2011, 06:28 AM
#894 |
What could go wrong?
Oddometer: 1,654
Damn it Geek. Like I need more ideas.....
'00 XRV750 Africa Twin, '99 CRM250-AR, '88 TLM220R, '77 TS-50 Death is more universal than life; everyone dies but not everyone lives. -A. Sachs "Get on with living or get on with dying" Paul Rodden 71 years old Diesel RV build |
11-20-2011, 09:25 AM
#895 |
Oddometer: 1,490
11-20-2011, 12:01 PM
#896 |
oot & aboot
Oddometer: 25,746
I picked up a quiet shop vac this morning.. much quieter than the last one I had.
I spent the morning cleaning/rearranging the garage to perform better. I got side tracked trying to figure out how to get my drill press's chuck to stop wobbling and haven't even touched the van yet.It is up to a balmy 37 degrees now... was below freezing when I started this morning.
www.motogeek.com |
11-20-2011, 01:57 PM
#897 |
oot & aboot
Oddometer: 25,746
www.motogeek.com |
11-20-2011, 01:59 PM
#898 |
oot & aboot
Oddometer: 25,746
Cheryl spent the day "damplifying". Thanks sweetie!
![]() ![]() ![]() Her next task is to put LLP in all of the same places.. It is too cold to use the spray glue.. hopefully over the thanksgiving holiday we'll get time.
www.motogeek.com |
11-20-2011, 02:03 PM
#899 |
oot & aboot
Oddometer: 25,746
I did some experimenting
![]() ![]() ![]() ...and in the sun ![]() ![]() ![]() I need to take the floor out again (this was mainly a test just to see if we liked the look).. but we're both very happy with the results... we love the warmth of the wood's color. I probably won't put the floor back in until we're near done to avoid wear & tear during construction.
www.motogeek.com Geek screwed with this post 11-20-2011 at 02:08 PM |
11-20-2011, 02:19 PM
#900 |
Charlaridian
Oddometer: 10,296
Ed, that floor looks beautiful!
2008 Yamaha WR250R ![]() 2004 Gas Gas 300 Raga Replica 1977 Yamaha DT-100 |
| Thread Tools | |
