Thread Tools Rating: Thread Rating: 304 votes, 4.94 average. Display Modes
Old 12-11-2011, 12:13 PM   #1096
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
On the bottom, the cutting occurs on some of mercedes sound damping squares...
This stuff has to all be removed and cleaned up
BEST. INVENTION. EVER.
Basically a 20,000 hz eletric scraper
it allowed me to clean that gooey mess off in seconds... literally like scraping butter off of a plate.
I'm sure with a hand scraper it would have taken me an hour and a lot of sweat/arm fatigue.
It appears that mercedes puts those sound pads on BEFORE they paint the van
That's bare metal underneath....
Old 12-11-2011, 12:16 PM   #1097
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Got the drill out and created the 16 holes. Deburred everything and then gave it all a good wipe down with alcohol.
The alcohol felt really good in all my fresh metal shavings cuts
taped it all off and then primed it all. (inside and out)
also painted the aluminum re-enforcement strips
...and this is how the van sits at this very minute.
The temperature has made it up to a balmy 43 degrees and I'm letting the primer dry for an hour or so while we eat lunch.
Then, on to phase 2... installing the fan
Geek screwed with this post 12-11-2011 at 12:24 PM
Old 12-11-2011, 02:59 PM   #1098
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,751
Its fixin to get cold out. Its already dark here in NoVA.
You have fan or do you still have a big ass hole in yer roof?
Oh, and someone pass the popcorn! The only way this could get better is if we were all around the van heckling ahem helping.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 12-11-2011, 03:22 PM   #1099
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
It all went horribly wrong!
Old 12-11-2011, 03:25 PM   #1100
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,095
RUH ROHHH
Indigestion?
Or the vent?
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus screwed with this post 12-11-2011 at 04:11 PM
Ruffus is online now   Reply With Quote
Old 12-11-2011, 03:28 PM   #1101
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,282
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 12-11-2011, 03:29 PM   #1102
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,210
Missed one of the beer breaks?
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 12-11-2011, 04:13 PM   #1103
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Originally Posted by Ruffus View Post
RUH ROHHH
Indigestion?
Or the vent?
Nah.. the vent is perfect. s
It is this white shit all over my fingers.. I can't get it off!
Old 12-11-2011, 04:14 PM   #1104
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Old 12-11-2011, 04:17 PM   #1105
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Maxxair Fan Installation continued (& concluded )
So taking the mounting bracket, I put butyl tape around being sure to cover every screw hole.
I then put a bead of 230 around the inside of butyl tape (probably overkill.. but I consider it one more layer of cheap insurance against leaks)
Into the hole the frame goes - making sure to keep the mounting nuts to the sides (that the fan bolts to) and then laying the aluminum re-enforcement strips in place:
I put a big dollop onto the top threads of each screw as I put them in the hole
Then once things were all bolted down (careful not to overtighten and squeeze the butyl out) I put a bead around the outside of the ring and a dollop on the head of each screw.
Then onto the roof with the fan itself.
The fan slides easily into the hole and is mounted with a simple set of 4 screws - 2 on each side
Down inside you can see everything mounted up. I'll trim the extra bolt length off if need be when doing the ceiling but I don't think they'll be an issue
..because this sleeve goes over the unit and mounts flush to the ceiling.. someday.. when I have a ceiling?
The sleeve is 4 inches deep.. you trim it to whatever you need it to be.
Pretty simple wiring.. just a postivie and negative (note the BLACK WIRE IS POSITIVE on the fan!!! )... and voila!
Works like a champ :
There are controls on the fan itself as well as the remote control.
This particular model has 10 speeds, can blow in or out, or can be used as a ceiling fan with the lid closed. You can also open the lid without the fan if you want ventilation.
Due to its design you can also leave it open while driving if you want as well as in the rain.
Old 12-11-2011, 04:19 PM   #1106
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Vent closed:
Old 12-11-2011, 04:20 PM   #1107
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
Vent open:
.. yeah I know the poor thing needs a bath
Old 12-11-2011, 04:46 PM   #1108
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,039
Originally Posted by geode View Post
let cure, then start up belt sander, apply fingers carefully to moving belt.
Problem solved.
///safety third///
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 12-11-2011, 05:26 PM   #1109
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,786
Slip some of these over those bolts before you poke a hole in yer head.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 12-11-2011, 06:47 PM   #1110
Sutherngintelmen
around the bend
Oddometer: 1,210
Looking good, Geek
Thread Tools
Times are GMT -7.   It's 03:04 AM.
