View Results: Definite Committed Interest in this bracket?
950 SE-R 18 13.74%
990, 950 ADV 113 86.26%
Voters: 131. You may not vote on this poll
Old 08-21-2011, 02:36 PM   #31
stuj
stuj's Avatar
Oddometer: 33
Originally Posted by charlie264 View Post
Thanks for the offers to be Adventure guinea pig, the design as it is will fit the Adventure as is, as the mounting points are identical to the SE, i.e. frame, engine layout are the same. All I will need to do is fit a plate to an adventure, mark and measure the material that will need to remove to accommodate the Adventure skid plate, which will be minimal and wonít affect the strength but will use two mounting points instead of three, but the design was intended to prevent rotation in the event of a hard hit and damaging the generator case cover. This will also be suitable for an SE with a Tourtech skid plate.
If enough interest I will go ahead and have a batch made up, SE and Adv, but Iím not doing this as a business prospect, just offering to help out fellow inmates, Iíve paid for mine. It was heat painted today so hopefully will install tomorrow and Iíll take some more picks.
I'm interested in a bracket to fit my 990 ADV, when you have them ready, pm me or something ;)
stuj is offline   Reply With Quote
Old 08-21-2011, 03:43 PM   #32
Peanuts
Peanuts's Avatar
Oddometer: 1,693
Pay up. There is no flex between off and on the side stand, even with me pulling on one handed extra weight onto the side stand.
Thats good news. Get one tried on an Adventure :)
Peanuts is offline   Reply With Quote
Old 08-21-2011, 08:33 PM   #33
offtheback
Chocolate Starfish
offtheback's Avatar
Oddometer: 356
Keep me in the loop for Adventure.
"It's not tragic to die doing what you love" Patrick Swayze - Point Break
2014 R1200GS.. The rest don't matter
offtheback is offline   Reply With Quote
Old 08-22-2011, 06:59 AM   #34
Bannisdale
....snowing now!
Bannisdale's Avatar
Oddometer: 209
I'm in...
If it will fit with the BDCW skid plate (which I'm sure it will) I'll have one.
Glad to see someone in the UK can finally supply this vital piece of kit.
Cheers
Tim
If you can keep your head when all about you are losing theirs, it's just possible you haven't quite fully grasped the situation...
Bannisdale is offline   Reply With Quote
Old 08-23-2011, 01:00 PM   #35
Peanuts
Peanuts's Avatar
Oddometer: 1,693
That lower bolt is where the sump guard bolt goes on the Adv, thats why the Blackdog has no mount there...
so when will you have the Adv version ready please?
Old 08-23-2011, 02:33 PM   #36
charlie264 OP
charlie264's Avatar
Oddometer: 8,367
Originally Posted by mcmann View Post
A Fender washer and 6mm longer bolt should work:
Why not mount the top left bolt into the side case for additional support (bottom bolt reversed/counter sunk like it is now to protect the bottom of the case from cracking). It would take a heck of a blow with double steel supports to cause enough flex in the top bolt to crack the case ???
You could do that, an added bad design is the alignment. I can only assume KTM didnít use shouldered bolts to gain more tolerance. The third bolt goes through the frame, case and frame so kind of sandwiching the fragile case material. Iíd rather bend the side stand plate or break the stand itself rather than cause any damage to the case. Thatís a major rebuild or weld job.
Old 08-24-2011, 02:00 PM   #37
charlie264 OP
charlie264's Avatar
Oddometer: 8,367
Do you have a ball park price (dollars) for the SE plate and two counter-sink/tapered front bolts . . . if you decide to make a batch?
I should find out this week.
Old 08-24-2011, 03:55 PM   #38
Pitster
miniac
Oddometer: 348
I could use one..
www.pitsterpro.com Pitster Pro, Mini Bikes, Pit bikes and Play bikes, Side x Side, ATV
www.nomadrider.com Adventure luggage and gear
Pitster is offline   Reply With Quote
Old 08-28-2011, 08:30 AM   #39
D K
Oddometer: 482
I would be interested for my SE as well, so long as I get it before my trip...
D
'13 EC300 Racing
í07 950SE - sold
í08 950SE - sold
í09 FE570 - sold
D K is offline   Reply With Quote
Old 09-01-2011, 09:29 AM   #40
charlie264 OP
charlie264's Avatar
Oddometer: 8,367
Just to keep everyone in the loop, the SE plate is being machined up now. Then off to the miller to be countersunk and painted, so a total of three companies just to make this side stand relocater. There was a minimum order so that will give only a few plates to start with, hopefully should start producing the Adv plates next week.
Old 09-11-2011, 01:54 PM   #41
Peanuts
Peanuts's Avatar
Oddometer: 1,693
Any news?
I am interested in the Adv version, but happy to take an SE version and machine out the sumpguard area.
Old 09-11-2011, 02:43 PM   #42
charlie264 OP
charlie264's Avatar
Oddometer: 8,367
Originally Posted by Peanuts View Post
Any news?
I was putting the finishing touches to the Adv relocater today along with inmate ACP, nice guy. I should have the first batch of SE plates completed this week, there was a misunderstanding with the engineering company, I asked for a test piece first out of 1mm steel to match, I received a 6mm plate 7 days later, so I am waiting for the first order and then to be milled.
I’m very happy with the Adv design; it’s been designed to accommodate the standard Adv and G-IT sump guard, I see no reason why it wouldn’t match with others sump guards. Many thanks to ACP for his time, a top bloke and for the tea, coffee and use of his Adv S making this all possible, as I said before, I only originally intended to make some for the SE, but due to the interest and PM’s I’ve received....
Hopefully, as things are progressing at a faster pace now, I will be able to get a plate to you this week or next. I’m keen to get as much feedback as possible.
It will be 6mm steel, not 8mm, I’ve steered away from stainless or high tensile, hopefully this will give a point of give with a big off, preventing, limiting damage elsewhere.
I bent my SE’s standard side stand pivot plate like a banana in a crash; luckily the case was fine, if it had been made of tensile steel, I’m not sure I would have been as lucky. The main bolt going through the case, I’m still undecided whether to use an 8.8 grade bolt or 10.9. 8.8 would have a better chance of failure in a crash, what do you think?
charlie264 screwed with this post 02-25-2012 at 02:48 AM
Old 09-12-2011, 09:40 AM   #43
Aquanout
Hooliganantic
Aquanout's Avatar
Oddometer: 748
Still too close to the case for my liking. I went aft of the foot peg, also made it adjustable.
Aquanout is offline   Reply With Quote
Old 09-13-2011, 04:36 PM   #44
zedtours
zedtours's Avatar
Oddometer: 370
Originally Posted by Waterbaby View Post
Hi I would be interested in one of your brackets if it would it fit a 950Adventure 2003 with G-IT sump guard.
the BD one will not fit as the 03 frame is different
2nd that I'm in surrey. Would not a piece of heavy duty rubber mounted behind the plate act as shock absorber if any bending took place?
zedtours is offline   Reply With Quote
Old 09-13-2011, 04:57 PM   #45
charlie264 OP
charlie264's Avatar
Oddometer: 8,367
That’s a good idea, will need testing. Personally I think there is enough flex in the side stand its self, it’s going to take some real abuse to bend this relocater. The prototype was fitted with ACP's G-IT Sump guard.
charlie264 screwed with this post 09-13-2011 at 05:35 PM
Times are GMT -7.   It's 12:48 PM.
