Old 09-15-2011, 07:20 PM   #91
Underboning OP
Underboning's Avatar
Oddometer: 720
Originally Posted by DaBinChe View Post
Good to see you well on your way.
Besides a few fastener issues on my AK trip the other main thing that got me was the dreaded flooded engine. Once I got back to CA I took off the evap system which I think was the main cause of the flooded engine. Seems like the float needle was acting up too when I checked. Also the auto petcock wouldn't close so I ended up putting on a inline petcock. Never had an issue afterwards.
I'm surprised you didn't loctite many of the fasteners that are coming off. I loctited every thing except the swing arm and exhaust nuts, which were the only two that I had issues with. Not a single one that was loctited came loose.
The clutch on down shifts was always more jerky then up shifts. What I did to smooth out the shift was to let the engine rev down a little before I down shifted.
Seems like you rear tire lasted a little longer then mine did...guess those gravel roads wears out tires much faster then pavement.
I finally picked up a tube of blue loctite here in Toronto and plan to use it from now on. Anything that loosens up is getting a squirt. I had a bad experience once with loctite and have been kind of leery of it since. I used the blue on a rear suspension bolt on one of my TZs many years ago, not realizing it was actually an aluminum bolt. After I sheared off a 4 inch long shouldered bolt, It took more than a month to get a replacement from Japan. After that I just stuck to safety wiring. I had originally planned to do some safety wiring on the Symbas but decided against it as I didn't know what bolts I might need frequent access to and didn't want to carry wiring pliers as well. I've also been unimpressed with the durability of some of the bolt heads on our bikes, which also made me a little nervous about loctite. But no more, I hear the wisdom of the masses and will be using loctite (sparingly) from now on!
I haven't removed the evap system but did disconnect the fuel line from the canister to prevent the flooding from overfilling. I suspect that the issue on Re's bike was the petcock, I tried to find an inline petcock before we left but couldn't in the short time we had. We haven't had another problem since but we are keeping an eye on it.
I have high hopes (but low expectations) of the tire life on the Gazelles, I haven't heard too much good about their longevity. We had a replacement tire for the front also, but didn't put them on in Ohio. So we still have a spare each, we'll see which wears out first.
Underboning is offline   Reply With Quote
Old 09-16-2011, 09:18 AM   #92
Packer
Packer's Avatar
Location: Scotland, wonderful biking when it's dry (rarely)
Oddometer: 333
Heat is your friend. Heat gun and about 120 degrees centigrade, it all melts and lubes the bolts on the way out. Admittedly a bit difficult in the middle of the Veld but a magnifying glass (spare spectacles in your bag?) and some African sun will probably do the job as well.
Packer is offline   Reply With Quote
Old 09-18-2011, 03:08 AM   #93
Underboning OP
Oddometer: 720
Made it to Cape Town yesterday morning, spent the day getting to our accommodations, doing a bit of walking around and sleeping for 13 hours last night. we are just glad to be off of the planes. 22.5 hours on a plane with only a 3 hour layover to break up the flights is too much. The bikes are supposed to arrive today (fingers crossed) and we should be able to pick them up tomorrow (Monday). It is raining a bit today and is only about 60 degrees, who knew we'd need our wool baselayers for Africa? Now off to find a couple of gas cans.
Old 09-18-2011, 10:39 PM   #94
damasovi
damasovi's Avatar
Oddometer: 2,627
Wow!
amigos I wish you the best for this trip, I have been reading and I am now up to page 5, I have to stop sleeping and/or working to read faster!!!!
I all ready mention to my wife that maybe I will not be buying that v-strom but might go for a 100-125 cc bike, and it is your fault!
Keep it safe!!! and keep writing! and we will be reading along!
damasovi from Mexico
damasovi is offline   Reply With Quote
Old 09-19-2011, 05:25 AM   #95
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,445
Woohoo!! Good luck on procuring the gas cans. Looking forward to the Africa updates.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 09-19-2011, 02:35 PM   #96
Underboning OP
Oddometer: 720
9/15 – 9/19 Africa!
9/15 and 9/16
Thursday morning we got up and repacked our luggage for the plane. We stuffed our Ortlieb duffels into the Pacsafe sacks for the first time in anger, and they fit! We had to return the car by 1pm, but our flight didn't leave until 10:45 pm. We hoped to be able to check our bags at 1 and have the afternoon to visit Toronto via public transport, but no luck. Instead, we sat in the Toronto airport for over 10 hours. Our flights were relatively uneventful, just long. From Toronto to Abu Dhabi was 11 ½ hours in flight followed by a 3 hour layover. Our flight to Cape Town went via Johannesburg, so it was 8 hours to Joburg, a 1 hour layover, and 2 more hours to Cape Town. This was our first flight on Etihad, and overall, we were impressed. The seats have good leg room, the food was excellent, the flight attendants wear cute hats and tight little skirts.
9/17
We arrived in Cape Town around 8am, breezed through immigrations and customs, hit the ATM, and hopped the MyCITI bus into downtown Cape Town and arrived at the Cat and Moose Backpackers' Hotel by 10am. This is the place that Fishfund and company spent a month earlier this year while waiting for their bikes. Hopefully we will have better luck. When we checked in, John remembered Nick and Luke and laughed about their misadventures. They apparently made quite an impression here. While we dozed some on the plane, we were still very tired, so we took a 3 hour nap before heading out to see some sights. Cape Town is a strange place. The poverty, high rate of unemployment, and racial tensions makes for an uncomfortable mix. Some areas of the city are very beautiful, but I feel like I have to be constantly aware of our surroundings, which lessens the enjoyment. Still tired, we hit the bed early and (accidentally) slept for 13 hours. The biggest surprise is how chilly it is here. I thought Africa was supposed to be hot! Today's high was only 65 degrees and the overnight low was in the upper 40s.
Accommodations and food also seem like a poor value compared to southeast Asia.
9/18
After a long night's sleep we woke to a gray , rainy, and chilly morning. We are glad we brought wool base layers and fleece pullovers. With our Marmot rainjackets over top, we are staying reasonably warm (but I thought this was Africa?!?). Originally we had wanted to tour some museums, but most of them were closed since it was Sunday, so our quest instead, was for a gas can. The staff at the guesthouse made some suggestions, but we had no luck at the 3 stores we visited. We can't seem to find either an auto parts store or the equivalent of a Wal-Mart. We really need a gas can for tomorrow because, after signing up for the shitty wifi, British Airways cargo website informed us that our bikes had arrived at noon today!!!! We spent the rest of the day consulting the maps and guidebooks while planning our next week or so of travel. In the name of science, we retired to our room in an attempt to determine if, like water in the sink, anything else spins in the opposite direction now that we are south of the equator. The results were inconclusive, so we have planned further testing!
After dinner we stopped out at a local bar to enjoy our first Carling Black Labels before hitting the bed early, as tomorrow will be a busy day.
9/19
We got up early this morning and gathered all the tools and paperwork we would need for our trip to the airport. Re found the number for Swissport Cargo, who handle British Airways cargo handling, and called and confirmed that our cargo was ready and waiting for us. John was finally back on duty at the front desk and pointed us to apparently the only store in Cape Town that carries gas cans. We walked the ¾ mile to the store, then another ½ mile to the nearest gas station, then another ½ mile to the bus to take us back to the airport. With 4 liters of gas in our new can, we rode to the airport. Around 10am we arrived at the passenger terminal, and Re got directions to Swissport, and we walked another ¾ mile to the cargo building. Along the way, we collected a number of strange looks from the workmen and passersby as we trudged along the highway with our backpacks and our gas can. We found our way to the counter at Swissport Cargo and procured our paperwork. Our next stop was the neighboring Customs building, where our journey was almost interrupted. The guard escorted us to Room 39, where we met Susie, who looked none too happy to see us. We passed our paperwork through the slot in the counter, and after examining it, she told us we would need a broker to complete the transaction. Luckily I was in the process of pulling out our Carnet documents at the time, and upon spying these, she asked whether we had Carnet. After finding out that we did, her mood changed entirely, and she said it would be no problem. She filled out some paperwork for us to take back to Swissport and told us to bring the bikes back when they were uncrated. We returned to the Swissport counter with papers in hand, turned them over, paid the 195 Rand (about $26.50 USD) handling fee, and took the papers to the warehouse. Here is where we met several of our new best friends. Chief among them was Karim, a supervisor in the warehouse. He immediately took us under his wing, due in no small part to Re's charming ways and quick humor.
For insurance reasons, we could not uncrate the bikes inside the warehouse, so Karim brought our crate to the parking lot and proceeded to help us uncrate the bikes. Over the next hour and a half or so, we had a rotating cast of at least 7 helpers who “assisted” us with reassembly.
Apparently we were the funnest thing going that day, as we attracted new friends from the warehouse and from the customers who came to pick up their own freight. The bikes went back together relatively easily, but it may have been faster with fewer people involved! Both bikes fired up immediately and don't appear to be any worse for their trip. We were a little concerned about how to dispose of our crate, but one of our helpers asked what we were going to do with it and was overjoyed when we told him it was his for the taking. After a quick test ride around the parking lot, we rode over to Customs, where Susie came out to do her inspection of the bikes. Back inside to have our Carnets stamped, and we were on the road by 2pm. We were surprised how easy and pleasant an experience this was: we cleared Customs ourselves and reassembled the bikes in less than 4 hours and had a good time to boot!
It was exciting to actually pull out onto the main roads on another continent. We got a lot of bewildered looks from people in passing cars as we made our way down the N2 into the center of Cape Town. A 100cc bike may not be much in the kingdom of motorcycles, but as we cruised down the roads we'd walked earlier today, I realized it's a hell of an upgrade from walking. Back at the Cat and Moose, John held the front gate open for us as we rode down the hallway and into the courtyard, where our bike sit safely tonight. Tomorrow we plan to hit the museums we missed on Sunday before we head south to Hermanus on Wednesday.
Old 09-19-2011, 03:00 PM   #97
petefromberkeley
Oddometer: 3,292
You've done it now Let the good times roll!
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside.
petefromberkeley is offline   Reply With Quote
Old 09-20-2011, 06:07 AM   #98
Packer
Packer's Avatar
Oddometer: 333
Warning, aliens in Africa
The cold may have something to do with the fact that the only thing between Cape Town and Antarctica is the Southern Ocean!
What a great adventure. Remember that a charging elephant can achieve 25-30mph, a rhinoceros can manage around 35mph and a cheetah 60mph so don't you folks upset the local quadrupeds.
Hope you have a massive amount of fun, I'm envious.
Old 09-22-2011, 05:20 PM   #99
engineer1984
Oddometer: 42
To think that right now you two are in S. Africa travelling on two 100cc motorbikes is surreal. I write this from a cube farm in Houston between working as an engineer and waiting to take a welding class. : )
I wish you all the luck. You two seem to be the perfect match.
Cheers,
Andrew
engineer1984 is offline   Reply With Quote
Old 09-25-2011, 10:01 AM   #100
Underboning OP
Oddometer: 720
Made it safely into Namibia today. Checking e-mail using the gas stations wifi. No wifi to be found in northern SA. Will hopefully post more RR when we reach Windhoek (or sooner).
Old 09-25-2011, 12:04 PM   #101
Circle Blue
Here and There
Circle Blue's Avatar
Oddometer: 59
Very glad for the brief update. Been thinking of you and am grateful to know you are making way.
Circle Blue is offline   Reply With Quote
Old 09-25-2011, 03:36 PM   #102
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,144
Excellent report, thanks for sharing. I love little bikes, a lot, and have been thinking about getting something even smaller than my 250.
Will you all be riding to India, or doing Southern Africa and then shipping the bikes to India? Did I miss this detail somewhere?
My KLR650
Matt's Trippin' in Peru
sandalscout is offline   Reply With Quote
Old 09-27-2011, 12:42 PM   #103
Underboning OP
Oddometer: 720
Cheers,
Andrew
How long have you been reading RRs here? It took about 4 years of reading about other people's adventures before we decided we had to do it. Be careful or you may find yourself in the middle of something stupid, too! Thanks for the good wishes.
Old 09-27-2011, 12:49 PM   #104
Underboning OP
Oddometer: 720
We are loving the little bikes but I must confess that I sometimes wish for 150ccs or more, especially here in southern Namibia where it is a loong way between places.
We will be shipping the bikes to somewhere in India from somewhere in Africa (most probably Dar or Mombasa or Durban). It is impractical and/or impossible for us to reach India by land. As Americans we can't travel through Iran (and Pakistan would be no picnic) which leaves the "Stans", which is a really long way and each country requires a letter of invitation and expensive visa. I wish we could do it by land but we'd still have to ship the bikes from India or Nepal to Thailand by air since Burma is closed to overlanders and China requires that you ride with a government minder at $100 per day. Since our budget is $75 per day....
Old 09-27-2011, 01:07 PM   #105
sandalscout
blah blah blah
Oddometer: 2,144
Yeah, I can imagine that in wide open spaces, more ccs would be nice.
That's one of the biggest issues with RTW trips as Americans. I always read these reports by Brits and Aussies where they get to go through Iran, it stinks that we have to make such huge detours!
Good luck!
My KLR650
Times are GMT -7.   It's 02:24 AM.
