Old 10-22-2011, 01:47 PM   #31
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 783
The first real ride....
Still not turning right as easy as I would like..
left turns are no probs..but tight right turns
yer are fighting it..long right turns are OK..
The leaning is great..long sweeping turns
yer don't know the side car is there. just
lean as normal & around yer go... When
the lean limiter bottoms out it just move
yer weight across & turn the bars...
On rough trails the car can move up/down
as the car wheel hits bumps with no efect
on the bike.. just stand on the pegs as normal..
Now just a few finishing touches... top frame/lid
on the bin..mud guard & lights...
Pete-NZ is offline   Reply With Quote
Old 10-23-2011, 04:26 PM   #32
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 5,143
Pete-NZ, Looks successful. I missed how the lean limiter works. Would you please post a close up photo of it? Thanks
Vince @ SWFL or WNC
2015 Ural cT 2012 Dong Fang DF250RTB-A
Bar None is online now   Reply With Quote
Old 10-25-2011, 09:46 PM   #33
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,733
I thought you'd bent the sidecar chassis as you hit the trees. I understand, now.
Any thoughts on alterations since the off? Or maybe alterations to riding, given that you've found some limits to what it will do?
The photos in the other thread explain the motivation for fuilding it better than any words can. Beautiful location to hit the scenery
rayb Crash Dummy (no testing involved)
Old 10-25-2011, 09:53 PM   #34
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 492
Thumb
Originally Posted by Pete-NZ View Post
A leanning car on a dirt bike is really a unknown..
I have not seen another unit.. So I thought I would
give it a go...If it proves to be no good I can relpace
the slideing limiting struts & soilidly mount it...
Pete
OK .... seems like the thing to do now.
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 10-25-2011, 10:36 PM   #35
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 783
other than that one hickcup...
there was a small slip on the bank off the track
when I went around it the car wheel droped of the
side of the track... Bike/car has only got a 900mm track..
For normal rideing the car almost dosn't exsisst..
The car weighs 60/70lbs?..hell I carryed it up the
bank after I removed it..not drag...carry
rideing along a rough track yer can watch the car going up
& down with no movement of the bike...
I'm going to give it a bit more lean to the right..right hand turns
arn't as easy as left turns... plus I'm going to try a steering damper
on the limiting strut to carm its action down a bit...
I'm very happy with it... Now I know it works. I will get the finishing
touchs done..mudguard / top on the bin / lights etc...
Pete
Old 12-21-2011, 05:29 AM   #36
SETHZILLA!
Oddometer: 5
Any more progress on the lid/lights/mudguard Pete? Pics?
SETHZILLA! is offline   Reply With Quote
Old 12-23-2011, 11:26 AM   #37
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 783
Got a mudguard & small light on... Lid.. will prob have a cover made..
also increased the lean... On the road yer don't know the car there, just
lean as yer normaly would.. it's only tight corners going to fast that
gives probs as yer run out of lean.. As long as you are aware of it
slow down theres no probs..I don't think the steering has got any heavyer
with the car on...
On the dirt ... again yer don't really know the cars there , It happy to go up
& down over bumps with no efect on the bike...
Old 02-06-2012, 09:58 AM   #38
Empty Pockets
SnOOb
Empty Pockets's Avatar
Oddometer: 13
Question Well done
Very good work on the side car! i like the addition of the front fender on the side wheel. It ties the bike together. Have you used it for any excursions yet?
Empty Pockets is offline   Reply With Quote
Old 02-08-2012, 08:43 PM   #39
Trailrider ZA
Trailrider ZA's Avatar
Oddometer: 65
Excellent!
www.trail-rider.co.za
Trailrider ZA is offline   Reply With Quote
Old 02-08-2012, 08:55 PM   #40
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 783
yes I have had it on a few rides..
Quite easy to ride... And a lot better
than packing the gear on the bike,,
http://i1244.photobucket.com/albums/gg563/petenz1/SSA41774.jpg[/IMG][/IMG]
Pete-NZ screwed with this post 02-09-2012 at 12:38 PM
Old 02-08-2012, 10:22 PM   #41
squee22
Oddometer: 116
I love it. Any more closeups would be apreciated. I wonder whether I can build something similar for a kl250 sherpa.
squee22 is offline   Reply With Quote
Old 02-11-2012, 03:28 PM   #42
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 783
Theres no reason why not...
just keep in mined the mounting points
have to be under the centre of the bike
in line with the wheel centres...
car on the right side would be easyer
as you don't have to clear the chain...
Old 02-11-2012, 03:30 PM   #43
squee22
Oddometer: 116
like this video?
http://www.youtube.com/watch?v=s2y6rdJqD4k
http://www.youtube.com/watch?v=-oJd4OiwODE
Old 02-12-2012, 04:55 AM   #44
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
I love this idea. I am going to try it on my XR650L.
1Bonehead is offline   Reply With Quote
Old 05-07-2012, 02:02 AM   #45
turkey380
turkey380
Oddometer: 53
leaner
G`Day I made a leaner on my R100RS .Ditched the limiting rod. Made a stop on sidecar frame to stop left hand fall on bike,and a chain to hold bike from touching ground for right side . Works so well.Been up very rough dirt roads bike handles better than solo.On road I can hold off most solo`s through the corners. Max
turkey380 is offline   Reply With Quote
Times are GMT -7.   It's 12:35 PM.
